查看: 8128|回復: 18
小車跑不了直線?是怎么回事
ID:173860 發表于 2017-6-10 12:37 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#define V_TH  0XFF
#define V_TL  0XF6
#define V_TMOD 0X01
void init_sys(void);            /*系統初始化函數*/
void f_left();  //前進左轉
void f_right(); //前進右轉
void b_left();  //后退左轉
void b_right(); //后退右轉
void forward(); //前進
void back();    //后退
void stop();    //停止
//控制小車正反轉
sbit IN1 = P0 ^ 0;
sbit IN2 = P0 ^ 1;
sbit IN3 = P0 ^ 2;
sbit IN4 = P0 ^ 3;
//控制小車轉速
sbit ENA = P2 ^ 0;
sbit ENB = P2 ^ 1;
uchar ZKB1 = 80, ZKB2 = 80; //控制輪子轉速
uchar tmp;  //存放串口數據
void main (void)
    init_sys();
    ENA = 0;
    ENB = 0;
    ZKB1 = 90;
    ZKB2 = 90;
    IN1 = 0;
    IN2 = 0;
    IN3 = 0;
    IN4 = 0;
    TMOD |= 0x20;           // 定時器1工作于8位自動重載模式, 用于產生波特率
    TH1 = 0xFD;             // 波特率9600
    TL1 = 0xFD;
    SCON = 0x50;            // 設定串行口工作方式
    PCON &= 0xef;           // 波特率不倍增
    TR1 = 1;                // 啟動定時器1
        if(RI)                      // 是否有數據到來
            RI = 0;
            tmp = SBUF;             // 暫存接收到的數據
            switch(tmp)
            case 'a':
                forward();
                break;
            case 'b':
                back();
                break;
            case 'c':
                f_left();
                break;
            case 'd':
                f_right();
                break;
            case 'e':
                b_left();
                break;
            case 'f':
                b_right();
                break;
            case 'g':
                stop();
                break;
*函數功能:對系統進行初始化,包括定時器初始化和變量初始化*/
void init_sys(void)            /*系統初始化函數*/
    /*定時器初始化*/
    TMOD = V_TMOD;
    TH0 = V_TH;
    TL0 = V_TL;
    TR0 = 1;
    ET0 = 1;
    EA = 1;
*函數功能:控制方向*/
void forward()
    IN1 = 1;
    IN2 = 0;
    IN3 = 1;
    IN4 = 0;
void back()
    IN1 = 0;
    IN2 = 1;
    IN3 = 0;
    IN4 = 1;
void f_left()
    ZKB1 = 90;
    ZKB2 = 45;
    IN1 = 1;
    IN2 = 0;
    IN3 = 1;
    IN4 = 0;
void f_right()
    ZKB1 = 45;
    ZKB2 = 90;
    IN1 = 1;
    IN2 = 0;
    IN3 = 1;
    IN4 = 0;
void b_left()
    ZKB1 = 90;
    ZKB2 = 45;
    IN1 = 0;
    IN2 = 1;
    IN3 = 0;
    IN4 = 1;
void b_right()
    ZKB1 = 45;
    ZKB2 = 90;
    IN1 = 0;
    IN2 = 1;
    IN3 = 0;
    IN4 = 1;
void stop()
    IN1 = 1;
    IN2 = 1;
    IN3 = 1;
    IN4 = 1;
/*中斷函數*/
void timer0(void) interrupt 1 using 2
    static uchar click = 0;                /*中斷次數計數器變量*/
    TH0 = V_TH;                                  /*恢復定時器初始值*/
    TL0 = V_TL;
    ++click;
    if (click >= 100) click = 0;
    if (click <= ZKB1)     /*當小于占空比值時輸出高電平,高于時是低電平,從而實現占空比的調整*/
        ENA = 1;
    if (click > ZKB1)
        ENA = 0;
    if (click <= ZKB2)     /*當小于占空比值時輸出高電平,高于時是低電平,從而實現占空比的調整*/
        ENB = 1;
    if (click > ZKB2)
        ENB = 0;
ID:177855 發表于 2017-6-10 14:01 | 顯示全部樓層
湊個熱鬧。
ID:123289 發表于 2017-6-10 18:09 | 顯示全部樓層
先不考慮程序,你的車子能跑直線嗎?
ID:209916 發表于 2017-6-10 19:36 | 顯示全部樓層
可以考慮使用PID算法
ID:189134 發表于 2017-6-10 22:20 | 顯示全部樓層
2輪的因為左右兩邊電機轉速不一致,基本上走不了直線,采用增量PID控制電機轉速可以是走的曲線平滑一點
ID:209976 發表于 2017-6-10 23:09 | 顯示全部樓層
占樓 湊個熱鬧
ID:164602 發表于 2017-6-11 09:26 | 顯示全部樓層
一般在小車,在沒有限制條件時(如尋跡等),是跑不了直線的。。
因為:(這就是技術與科學的區別了。
第一:你以為給電機的電壓是“絕對”——就是絕對一樣嗎?
第二:你的電機絕對一樣嗎?
第三:你啟動電機的時間絕對一樣嗎?
第四:電車的輪子與地面的抓地力絕對一樣嗎?這個涉及小車重心在絕對中心嗎?輪子受到壓力絕對一樣嗎?等等
第五:地面絕對一樣平整嗎?
不說了,你要生氣了。
在課本中說的科學,都是理想化的,你做技術,就是具體化的,以前書上的題,不能拿到這里來用。而且,我們用的模塊,本身便宜,精度就不是很高。
所以,正常情況下,小車自己走不了直線。
像樓上說的,你要讓小車走直線,得加好多傳感器才行。如:測個速,但千萬不要以為測出、調節到一樣的速度,小車就走直線了(平整路面差不多了),輪子打不打滑呢等等。
之所以我能說這么多,也是有經歷的。原來我也想搞這個,咨詢了專業人士,這些都是專業人士說的,還說這本身就是一個大大的研究課題。我放棄了。沒辦法,我沒那個能力。呵呵
參與人數 1黑幣 +80 收起 理由
admin + 80 回帖助人的獎勵!
ID:210066 發表于 2017-6-11 12:59 | 顯示全部樓層
看個熱鬧
ID:173860 發表于 2017-6-11 17:15 | 顯示全部樓層
謝謝大家了,我用四輪的會好點下次搞個試試。
ID:173860 發表于 2017-6-19 09:22 | 顯示全部樓層
大家好,我用另外一個程序小車可以走直,這個走不了。我說的走直線不是直線是正常的前進后退。
ID:182758 發表于 2017-6-19 09:58 | 顯示全部樓層
加油~湊個熱鬧,
ID:182758 發表于 2017-6-19 09:59 | 顯示全部樓層
用增益式PID算法試試
ID:201524 發表于 2017-6-19 10:42 | 顯示全部樓層
要實現什么功能呢
ID:212679 發表于 2017-6-19 18:48 | 顯示全部樓層
學習學習
ID:212711 發表于 2017-6-19 20:23 | 顯示全部樓層
湊個熱鬧
ID:212474 發表于 2017-6-20 11:32 | 顯示全部樓層
排除程序問題的話,很有可能是兩個輪子或電機不平行,有一定誤差,會導致小車越跑越偏。
ID:110734 發表于 2017-6-20 16:43 | 顯示全部樓層
1.小車的輪子是否直徑絕對相一致?2.程序的運行時間你看看有沒有問題?
ID:173860 發表于 2017-6-23 13:06 來自觸屏版 | 顯示全部樓層
三輪小車,視頻上不了。
ID:212728 發表于 2017-6-23 18:00 來自觸屏版 | 顯示全部樓層
HC6800-ES-V2.0 發表于 2017-6-11 09:26
一般在小車,在沒有限制條件時(如尋跡等),是跑不了直線的!!!
因為:(這就是技術與科學的區別了。 ...
好厲害的樣子,長見識了,原來還有這么多的問題
