查看: 2872|回復: 4
來大佬看下LCD顯示溫濕度程序 兩個程序怎么合并在一起
ID:205360 發表于 2017-6-4 18:15 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
一個是LCD顯示溫濕度的程序如下
#include <reg51.h>
#include <intrins.h>
typedef unsigned char BYTE;
typedef unsigned int WORD;
sbit io=P2^2;
sbit rw=P2^6;
sbit rs=P2^7;
sbit ep=P2^5;
typedef bit BOOL;
uchar data_byte;
uchar RH,RL,TH,TL;
void delay(uchar ms)
  uchar i;
  while(ms--)
  for(i=0;i<100;i++);
void delay1()
  uchar i;
  for(i=0;i<1;i++);
BOOL lcd_bz()
BOOL result;
  rs=0;
  rw=1;
  ep=1;
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  result = (BOOL)(P2&0x80);
  ep=0;
return  result ;
void write_cmd(uchar cmd)
   while (lcd_bz());
  rs=0;
  rw=0;
  ep=0;
  _nop_();
  _nop_();
  P0=cmd ;
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  ep=1;
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  ep=0;
void write_addr(uchar addr)
  write_cmd(addr|0x80);
void write_byte(uchar dat)
   while (lcd_bz());
  rs=1;
  rw=0;
  ep=0;
  _nop_();
  _nop_();
  P0=dat ;
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  ep=1;
  _nop_();
  _nop_();
  _nop_();
   _nop_();
  ep=0;
void lcd_init()
  write_cmd(0x38);
  delay(1);
  write_cmd(0x0c);
  delay(1);
  write_cmd(0x06);
  delay(1);
  write_cmd(0x01);
   delay(1);
void display(uchar addr,uchar q)
  delay(10);
  write_addr(addr);
  write_byte(q);
  delay(1);
void start()
  io=1;
  delay1();
  io=0;
  delay(25);
  io=1;
  delay1();
  delay1();
  delay1();
uchar receive_byte()
  uchar i,temp;
  for(i=0;i<8;i++)
   while(!io);
  delay1();
  delay1();
   delay1();
  temp=0;
  if(io==1)
   temp=1;
    while(io);
  data_byte<<=1;
  data_byte|=temp;
   return data_byte;
void receive()
   uchar T_H,T_L,R_H,R_L,check,num_check,i;
   start();
  io=1;
  if(!io)
while(!io);
while(io);
R_H=receive_byte();
  R_L=receive_byte();
T_H=receive_byte();
T_L=receive_byte();
check=receive_byte();
io=0;
for(i=0;i<7;i++)
delay1();
io=1;
num_check=R_H+R_L+T_H+T_L;
if(num_check==check)
   RH=R_H;
   RL=R_L;
   TH=T_H;
   TL=T_L;
   check=num_check;
  lcd_init();
     receive();
display(0x00,'R');
display(0x01,':');
display(0x02,RH/10+0x30);
display(0x03,RH%10+0x30);
display(0X04,'%');
display(0x40,'T');
display(0x41,':');
display(0x42,TH/10+0x30);
display(0x43,TH%10+0x30);
display(0x44,0xdf);
display(0x45,0x43);
另一個是PWN調光的程序如下
/*單片機實現PWM調節LED燈的亮度*/
#include<reg52.h>
sbit P2_0=P2^0;
sbit P2_1=P2^1;
sbit key1=P1^0;
sbit key2=P1^1;
sbit key3=P1^2;
sbit key4=P1^3;
uchar zkb,i;// zkb指占空比
uchar zkb2,i;
void time0(void) interrupt 1         //中斷函數
    TH0=(65536-10)/256;
        TL0=(65536-10)%256;
        ++i;
        if(i>10)
          i=0;
        if(i<=zkb)
         P2_0=1;
        else P2_0=0;
    if(i<=zkb2)
         P2_1=1;
        else P2_1=0;
  void delay(uchar z)
  uchar x,y;
  for(x=z;x>0;x--)
   for(y=110;y>0;y--);
void init()  //初始化函數
     TMOD=0X01;
         TH0=(65536-10)/256;
         TL0=(65536-10)%256;
         EA=1;
         ET0=1;
         TR0=1;
void keyscan()         //鍵盤掃描
           P1=0XFF;
        if(key1==0)
          delay(5);
           if(key1==0)
            while(!key1);
                if(zkb<9)
                   zkb++;
        if(key2==0)
          delay(5);
           if(key2==0)
            while(!key2);
            if(zkb>0)
                   zkb--;
         if(key3==0)
          delay(5);
           if(key3==0)
            while(!key3);
                if(zkb2<9)
                   zkb2++;
         if(key4==0)
          delay(5);
           if(key4==0)
            while(!key4);
            if(zkb2>0)
                   zkb2--;
  void main()        //主函數
    zkb=2;
        zkb2=2;
    init();
         keyscan();
有沒有大俠幫忙看下怎么合并在一起 兩個程序單獨都可以下載到板子里實現功能 想同時實現功能自己不會合并 本人學生新手小白一個 程序是網上找的 有沒有大佬幫忙合并一下 想跟著學學
ID:111634 發表于 2017-6-4 22:01 | 只看該作者
搞懂了2個程序,就能合并,搞不懂,就不能合并。
ID:207824 發表于 2017-6-4 22:10 | 只看該作者
ID:207847 發表于 2017-6-4 22:59 | 只看該作者
對的,相當于移植
ID:207847 發表于 2017-6-4 23:03 | 只看該作者
是的,相當于移植
