查看: 5868|回復: 1
error C213: left side of asn-op not an lvalue單片機keil報錯
keil報錯:error C213: left side of asn-op not an lvalue
單片機源程序:
  1. #include "STC12C5A.h"
  2. #include "iodefine.h"
  3. static    void    DisplayProcess( void );
  4. static    void    PutToDispCache( uint val );
  5. static    void     sendsubf( uint sendword );
  6. static    xdata    uchar     _dispCache[4]    = { 0 };
  7. static    xdata    uchar     _recFlag    = 0;
  8. uint    _receiveword    = 0;
  9. void SBUFinit( void )
  10. {
  11.         S2SMOD     = 0x00;             //波特率無加成
  12.         S2CON     = 0x50;             //01010000 8位可變波特率,無奇偶校驗位。
  13.         ES2        = 1;                //允許串口中斷
  14.         BRTR    = 1;                //允許獨立波特率發生器運行
  15.         BRT        = 96;                //波特率=SCLK/12/(256-BRT)96----9600
  16.
  17.     while(1){
  18.         if( _recFlag == 1){
  19.             sendsubf( _receiveword );
  20.             PutToDispCache ( _receiveword );
  21.             Display( _dispCache, 0x22 );
  22.             _recFlag    = 0;
  23.         }
  24.     }
  25. }
  26. void sendsubf( uint sendword )        ///向串口發送數據
  27. {
  28.     ES2        = 0;
  29.     S2TI        = 0;
  30.     S2BUF    = sendword;             //需要發送的數據先送到SBUF 寄存器中
  31.     while( S2TI==0 );                 //等到數據發送完再進行下一句代碼
  32.     S2TI        =0;
  33.     ES2        = 1;
  34. }
  35. void receive_int( void ) interrupt 8  //串口中斷,接收數據
  36. {
  37.     if( S2RI ){
  38.          S2RI                    = 0;
  39.          _receiveword        = S2BUF;
  40.          _recFlag            = 1;
  41.     }else( S2TI = 0 );
  42. }
  43. static    void    PutToDispCache ( uint val )
  44. {
  45.     if( val > 9999 ){                //超過顯示最大值,顯示最大值9999
  46.         val    = 9999;
  47.     }
  48.     if( val < 0 ){                    //低于顯示最小值,顯示最小值0
  49.         val    = 0;
  50.     }
  51.     _dispCache[0]    = val / 1000;
  52.     val        %= 1000;
  53.     _dispCache[1]    = val / 100;
  54.     val        %= 100;
  55.     _dispCache[2]    = val / 10;
  56.     _dispCache[3]    = val % 10;
  57. }
ID:264442 發表于 2017-12-20 20:13 | 只看該作者
S2CON &= ~S2RI
