查看: 2046|回復(fù): 0
數(shù)碼管花樣顯示
ID:207078 發(fā)表于 2017-6-2 14:09 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include <intrins.h>
unsigned char disp[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80};
sbit CLK=P3^0;
sbit SDA1=P1^0;
sbit SDA2=P1^1;
sbit SDA3=P1^2;
sbit SDA4=P1^3;
sbit SDA5=P1^4;
sbit SDA6=P1^5;
sbit SDA7=P1^6;
sbit SDA8=P1^7;
void DelayUs2x(unsigned char t)
{while(t--);
void DelayMs(unsigned char t)
{while(t--)
   {DelayUs2x(10);
      DelayUs2x(10);
void send(unsigned char a)
   unsigned char i;
   for(i=0;i<8;i++)
      if(_crol_(a,i)&0x80)
      {SDA1=1;
  SDA2=1;
  SDA3=1;
  SDA4=1;
  SDA5=1;
   SDA6=1;
   SDA7=1;
   SDA8=1;
      else{
     SDA1=0;
  SDA2=0;
  SDA3=0;
  SDA4=0;
  SDA5=0;
    SDA6=0;
    SDA7=0;
    SDA8=0;
     CLK=0;
     CLK=1;
void led1(void)
  unsigned char x;
  P2=0x01;
         x=disp[2];
  send(x);
void led2(void)
   unsigned char x;
  P2=0x02;
         x=disp[0];
  send(x);
void led3(void)
  unsigned char x;
  P2=0x04;
         x=disp[1];
  send(x);
void led4(void)
     unsigned char x;
  P2=0x08;
         x=disp[7];
  send(x);
      void led5(void)
     unsigned char x;
  P2=0x10;
         x=disp[0];
  send(x);
      void led6(void)
     unsigned char x;
  P2=0x20;
         x=disp[5];
  send(x);
      void led7(void)
     unsigned char x;
  P2=0x40;
         x=disp[1];
  send(x);
      void led8(void)
     unsigned char x;
  P2=0x80;
         x=disp[2];
  send(x);
     led1();
     DelayMs(10);
     led2();
            DelayMs(10);
            led3();
            DelayMs(10);
            led4();
            DelayMs(10);
      led5();
     DelayMs(10);
      led6();
     DelayMs(10);
      led7();
     DelayMs(10);
      led8();
     DelayMs(10);
相關(guān)帖子
