查看: 3524|回復: 0
合泰單片機HT66F70A LCD12864液晶屏驅動c語言
ID:205348 發表于 2017-6-1 12:22 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <HT66F70A.H>
#include "delay.h"
#define IO_12864   _pc //定義12864的數據端口
#define IO_12864_C   _pcc
#define RS_12864  _pd5 //定義命令數據寄存器選擇端
#define RW_12864  _pd6 //定義定義讀寫控制端
#define E_12864   _pd7  //定義使能端
#define RST_12864  _pd4 //定義復位端
//#define CS2   _pd3
//#define CS1   _pd2
void delay_12864(unsigned int ); //延時子函數原型
/*void busychk_12864(void); //忙檢測子函數原型*/
void wrtcom_12864(unsigned char); //寫命令子函數原型
unsigned char reddat_12864(void); //讀數據子函數原型
void wrtdat_12864(unsigned char); //寫數據子函數原型
//void choose_12864(unsigned char i);        //選屏
//void drawpic_12864( unsigned char*); //繪圖子函數原型
//void drawdot_12864(unsigned char,unsigned char,unsigned char);//畫點子函數原型
//void drawrec_12864(unsigned char,unsigned char,unsigned char,unsigned char,unsigned char);  //畫矩形子函數原型
void clnGDR_12864(void); //清空GDRAM子函數原型
void inputchars_12864(unsigned char,unsigned char,unsigned char*);//輸入短字符串子函數原型
void scroll_12864(unsigned char*); //輸入長字符串卷動子函數原型
void initial_12864(void); //12864初始化子函數原型
        unsigned char  uctech[] = {"wweerrtt"};
        _pcc=0;
        _pdc=0;
        //_pcpu=0xff;
        _pc=0;
        _pd=0;
        initial_12864();
        clnGDR_12864();
   inputchars_12864(1,1,uctech);
        /***********        延時子程序,最大延遲時間為65ms***************/
void delay_12864(unsigned int del){
unsigned int i;
for(i = 0; i < del; i++){;}
        /***************忙檢測,若忙則等待,最長等待時間為60ms**********/
//void busychk_12864(void){
//unsigned int timeout = 0;
//IO_12864_C=1;/////////
//E_12864 = 0;
//RS_12864 = 0;
//RW_12864 = 1;
//E_12864 = 1;
//while((IO_12864 & 0x80) && ++timeout != 0); //忙狀態檢測,等待超時時間為60ms
//E_12864 = 0;
        /****************寫命令子程序*********************/
void wrtcom_12864(unsigned char com){
//busychk_12864();
IO_12864_C=0; ///////////////////////////
delay_12864(5000);////////
E_12864 = 0;
RS_12864 = 0;
RW_12864 = 0;
E_12864 = 1;
IO_12864 = com;
delay_12864(5000); //使能延時50us!!!注意這里,如果是較快的CPU應該延時久一些
E_12864 = 0;
        /**************************讀數據子程序,返回一個字節的數據****************/
unsigned char reddat_12864(void){
unsigned char temp;
//busychk_12864();
delay_12864(5000);/////////////
E_12864 = 0;
IO_12864_C=0;/////////////////////
IO_12864 = 0xff; //IO口置高電平,讀引腳
RS_12864 = 1;
RW_12864 = 1;
E_12864 = 1;
IO_12864_C=1;////////////////////////
temp = IO_12864;
return temp;
        /*****************寫數據子程序***********************/
void wrtdat_12864(unsigned char dat){
//busychk_12864();
E_12864 = 0;
RS_12864 = 1;
RW_12864 = 0;
E_12864 = 1;
IO_12864 = dat;
E_12864 = 0;
        /***************選屏****************/
//void choose_12864(unsigned char i)//i是要寫的屏.0是左屏,1是右屏,2是雙屏;
//{        //此處在硬件上運行時i的電平全部與程序相反;
//  switch (i)                                                 //此版本為仿真版;
//    case 0: CS1=0;CS2=1;break;        //比如此處如果要在電路上運行則應該改為CS=1;CS2=0;
//    case 1: CS1=1;CS2=0;break;
//        case 2: CS1=0;CS2=0;break;
//        default: break;
                                                /************顯示圖片函數,參數時圖片的地址,圖片必須是128*64像素的逐行逐行的點陣信息。****************/
//void drawpic_12864( unsigned char   *pPicture ){
//unsigned char j, k ;
//wrtcom_12864(0x34);   //在寫GDRAM的地址之前一定要打開擴充指令集,否則地址寫不進去!!
//for( j = 0 ; j < 32 ; j++ )
//wrtcom_12864(0x80 + j) ; //寫Y 坐標
//wrtcom_12864(0x80) ; //寫X 坐標
//for( k = 0 ; k < 16 ; k++ )         //寫一整行數據
//wrtdat_12864( *pPicture++ );
//wrtcom_12864(0x88) ; //寫X 坐標
//wrtdat_12864( *pPicture++ ) ;
//wrtcom_12864(0x36); //打開繪圖顯示
//wrtcom_12864(0x30); //返回基本指令集
////畫點函數,左上角為參考點(0,0)
////右下角為(127,63),點坐標形式為(行坐標,列坐標)
////參數type用于設置畫黑點、白點或取反(黑變白,白變黑)
////type = 0為白色,1 為黑色,2為取反
////畫完點不開啟顯示,需要自行開啟繪圖顯示
//void drawdot_12864(unsigned char y,unsigned char x,unsigned char type){
//unsigned char X,Y,k; //X存儲行地址,Y存儲列地址,k存儲點在字中的位置(0~15從左至右)
//unsigned char DH,DL;
//if(y >= 0 && y <= 63 && x >= 0 && x <= 127) {
//if(y < 32){ //確定所畫點的地址行與列地址
//X = 0x80 + (x >> 4);
//Y = 0x80 + y;
//}else{
//X = 0x88 + (x >> 4);
//Y = 0x80 + (y - 32);
//wrtcom_12864(0x34); //開啟擴展指令,關閉繪圖顯示
//wrtcom_12864(Y); //寫行位地址
//wrtcom_12864(X); //寫列字地址
//DH = reddat_12864(); //假讀
//DH = reddat_12864();   //讀高字節
//DL = reddat_12864(); //讀低字節
//k = x % 16;
//switch(type){ //判斷類型,是黑點還是白點還是取反
//case 0: //畫白點
//  if(k < 8){
//DH &= ~(0x01 << (7 - k));
//}else{
//DL &= ~(0x01 << (7 - (k % 8)));
//break;
//case 1: //畫黑點
//if(k < 8){
//DH |= (0x01 << (7 - k));
//}else{
//DL |= (0x01 << (7 - (k % 8)));
//break;
//case 2: //對點取反
//if(k < 8){
//DH ^= (0x01 << (7 - k));
//}else{
//DL ^= (0x01 << (7 - (k % 8)));
//break;
//default:
//break;
//wrtdat_12864(DH); //回寫高字節
//wrtdat_12864(DL); //回寫低字節
//wrtcom_12864(0x36); //開啟繪圖顯示
//wrtcom_12864(0x30); //轉回普通指令
//                                                        /**********************畫矩形子函數,參數為(點1行坐標,點1列坐標,點2行坐標,點2列坐標,*********
//                                                        **********************線條顏色(0為白,1為黑,2對原色取反))*************************************/
//void drawrec_12864(unsigned char y1,unsigned char x1,unsigned char y2,unsigned char x2,unsigned char type){
//unsigned char largex,largey,smallx,smally;
//unsigned char i;
//if(x1 > x2){
//largex = x1;
//smallx = x2;
//}else{
//largex = x2;
//smallx = x1;
//if(y1 > y2){
//largey = y1;
//smally = y2;
//}else{
//largey = y2;
//smally = y1;
////畫4條矩形邊框
//for(i = smallx; i < largex; i++){
//drawdot_12864(largey,i,type);
//for(i = largey; i > smally; i--){
//drawdot_12864(i,largex,type);
//for(i = largex; i > smallx; i--){
//drawdot_12864(smally,i,type);
//for(i = smally; i < largey; i++){
//drawdot_12864(i,smallx,type);
//wrtcom_12864(0x30); //返回普通指令
        /*****************清空GDRAM,往GDRAM內部寫滿0x00*************/
void clnGDR_12864(void){
unsigned char j,k;
  wrtcom_12864(0x34);//在寫GDRAM的地址之前一定要打開擴充指令集,否則地址寫不進去!!
for( k = 0 ; k < 32 ; k++ ) //寫一整行數據
wrtdat_12864( 0x00 );
                                                        /***********************寫入短字符串函數,參數分別為顯示行(0~3),顯示列(0~7),字符串首地址
        字符串只會在一行顯示,超過的不顯示**********************************/
void inputchars_12864(unsigned char y,unsigned char x,unsigned char *dataaddr){
unsigned char i,address=0;
switch (y){ //設置字符顯示起始地址
case 0: address = 0x80 + x;
break;
case 1: address = 0x90 + x;
break;
case 2: address = 0x88 + x;
break;
case 3: address = 0x98 + x;
break;
default: break;
wrtcom_12864(0x30);
wrtcom_12864(address);
for(i = x;i < 8; i++){
if(*dataaddr != '\0'){
wrtdat_12864(*dataaddr++);
        /******************長字符串顯示卷屏函數**************************/
void scroll_12864(unsigned char *ser){
        //addr存儲地址的中間變量,flag卷屏地址,hang要寫數據的行,
        //over寫完字符串后繼續寫的空字符計數
unsigned char i,addr,flag,hang,over,*ptdat;
ptdat = ser; //獲得字符串首地址
over = 0; //寫入空字符串(寫完字符串后)數目初始化為0
wrtcom_12864(0x80); //寫第一行字符
for(i = 0; i < 16; i++){
if(*ptdat != '\0'){
wrtdat_12864(*ptdat++);
}else{
wrtdat_12864(0x20);
over++;
wrtcom_12864(0x90); //寫第二行字符
if(*ptdat != '\0'){
}else{
wrtdat_12864(0x20);
over++;
wrtcom_12864(0x88); //寫第三行字符
if(*ptdat != '\0'){
}else{
wrtdat_12864(0x20);
over++;
wrtcom_12864(0x98); //寫第四行字符
if(*ptdat != '\0'){
}else{
wrtdat_12864(0x20);
over++;
ptdat = ptdat - 32;
wrtcom_12864(0xa0); //寫第三行DDRAM,寫入內容為第三行字符串和第五行字符串
for(i = 0; i < 16; i++){ //寫第三行字符串
if(*ptdat != '\0'){
}else{
wrtdat_12864(0x20);
over++;
ptdat = ptdat + 16;
for(i = 0; i < 16; i++){   //寫第五行字符串
if(*ptdat != '\0'){
}else{
wrtdat_12864(0x20);
over++;
wrtcom_12864(0x0c); //開顯示
if(over > 15){;} //顯示字符不足4行,不卷動
else //顯示字符大于4行,繼續寫字符,同時開啟卷動
hang = 4;
flag = 0x01;
while(1){
switch(hang){   //設置寫入DDRAM的地址
case 1: addr = 0x80; break;
case 2: addr = 0x90; break;
case 3: addr = 0xa0; break;
case 4: addr = 0xb0; break;
switch(hang){ //設置要寫數據的下一行
case 1: hang = 2; break;
case 2: hang = 3; break;
case 3: hang = 4; break;
case 4: hang = 1; break;
ptdat = ptdat - 32;
for(i = 0; i < 8; i++){
wrtcom_12864(0x34); //打開擴展指令
wrtcom_12864(0x03); //允許輸入卷動地址
wrtcom_12864(0x40 + flag++); //設置卷動地址
wrtcom_12864(0x30);         //回到基本指令
wrtcom_12864(addr + i);
delay_12864(20000);
if(*ptdat != '\0'){
wrtdat_12864(*ptdat++);   //連續寫入兩個字節之高字節
}else{
wrtdat_12864(0x20);
if(*ptdat != '\0'){
wrtdat_12864(*ptdat++);   //連續寫入兩個字節之低字節
}else{
wrtdat_12864(0x20);
ptdat = ptdat + 16;
for(i = 8; i < 16; i++){
if(flag == 64){flag = 0;}
wrtcom_12864(0x40 + flag); //設置卷動地址
flag++;
delay_12864(20000);
if(*ptdat != '\0'){
}else{
over++;  //寫完最后一行字符,需要再卷動16次才能顯示出來。
wrtdat_12864(0x20);
if(*ptdat != '\0'){
}else{
wrtdat_12864(0x20);
if(over < 8){;}   //最后一行顯示完畢則停止卷動
else {break;}
        /***********************初始化12864子函數***********************************/
void initial_12864(void){
delay_12864(40000);
RST_12864 = 1;
RST_12864 = 0; //復位
delay_12864(500);
RST_12864 = 1;
wrtcom_12864(0x30); //設置為基本指令集動作
delay_12864(100);
delay_12864(37);
wrtcom_12864(0x08); //設置顯示、光標、閃爍全關。
delay_12864(100);
wrtcom_12864(0x01); //清屏,并且DDRAM數據指針清零
delay_12864(1000);
wrtcom_12864(0x06);   //進入模式設置
