查看: 2147|回復: 4
BMP180設置壓力范圍控制led 在某一氣壓下不同的led燈閃爍
ID:164979 發表于 2017-5-29 20:14 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
我想設置在某一氣壓下不同的led燈閃爍,但是不好使,麻煩大神幫忙修改
  1. #define   uchar unsigned char
  2. #define   uint unsigned int
  3. #define   DataPort P0
  4. sbit      SCL=P2^3;
  5. sbit      SDA=P2^4;
  6. sbit      LCM_RS=P1^0;
  7. sbit      LCM_RW=P1^1;
  8. sbit      LCM_EN=P2^5;
  9. sbit led1=P1^5;
  10. sbit led2=P1^6;
  11. sbit led3=P1^7;
  12. #define        BMP180_SlaveAddress   0xee
  13. #define OSS 0        // Oversampling Setting (note: code is not set up to use other OSS values)
  14.
  15. typedef unsigned char  BYTE;
  16. typedef unsigned short WORD;
  17. uint pressurewarn;
  18. uchar ge,shi,bai,qian,wan,shiwan;
  19. int  dis_data;
  20. short ac1;
  21. short ac2;
  22. short ac3;
  23. unsigned short ac4;
  24. unsigned short ac5;
  25. unsigned short ac6;
  26. short b1;
  27. short b2;
  28. short mb;
  29. short mc;
  30. short md;
  31. void delay(unsigned int k);
  32. void InitLcd();
  33. void WriteDataLCM(uchar dataW);
  34. void WriteCommandLCM(uchar CMD,uchar Attribc);
  35. void DisplayOneChar(uchar X,uchar Y,uchar DData);
  36. void conversion(long temp_data);
  37. //void warn(uint pressure);
  38. void  Single_Write(uchar SlaveAddress,uchar REG_Address,uchar REG_data);
  39. uchar Single_Read(uchar REG_Address);
  40. void  Multiple_Read(uchar,uchar);
  41. void Delay5us();
  42. void Delay5ms();
  43. void BMP180_Start();
  44. void BMP180_Stop();
  45. void BMP180_SendACK(bit ack);
  46. bit  BMP180_RecvACK();
  47. void BMP180_SendByte(BYTE dat);
  48. BYTE BMP180_RecvByte();
  49. void BMP180_ReadPage();
  50. void BMP180_WritePage();
  51. void conversion(long temp_data)
  52. {
  53.
  54.     shiwan=temp_data/100000+0x30 ;
  55.     temp_data=temp_data%100000;
  56.     wan=temp_data/10000+0x30 ;
  57.     temp_data=temp_data%10000;
  58.         qian=temp_data/1000+0x30 ;
  59.     temp_data=temp_data%1000;
  60.     bai=temp_data/100+0x30   ;
  61.     temp_data=temp_data%100;
  62.     shi=temp_data/10+0x30    ;
  63.     temp_data=temp_data%10;
  64.     ge=temp_data+0x30;
  65. }
  66. void delay(unsigned int k)
  67. {
  68. unsigned int i,j;
  69. for(i=0;i<k;i++)
  70. {
  71. for(j=0;j<121;j++)
  72. {;}}
  73. }
  74. void WaitForEnable(void)
  75. {
  76. DataPort=0xff;
  77. LCM_RS=0;LCM_RW=1;_nop_();
  78. LCM_EN=1;_nop_();_nop_();
  79. while(DataPort&0x80);
  80. LCM_EN=0;
  81. }
  82. void WriteCommandLCM(uchar CMD,uchar Attribc)
  83. {
  84. if(Attribc)WaitForEnable();
  85. LCM_RS=0;LCM_RW=0;_nop_();
  86. DataPort=CMD;_nop_();
  87. LCM_EN=1;_nop_();_nop_();LCM_EN=0;
  88. }
  89. void WriteDataLCM(uchar dataW)
  90. {
  91. WaitForEnable();
  92. LCM_RS=1;LCM_RW=0;_nop_();
  93. DataPort=dataW;_nop_();
  94. LCM_EN=1;_nop_();_nop_();LCM_EN=0;
  95. }
  96. void InitLcd()
  97. {
  98. WriteCommandLCM(0x38,1);
  99. WriteCommandLCM(0x08,1);
  100. WriteCommandLCM(0x01,1);
  101. WriteCommandLCM(0x06,1);
  102. WriteCommandLCM(0x0c,1);
  103. }
  104. void DisplayOneChar(uchar X,uchar Y,uchar DData)
  105. {
  106. Y&=1;
  107. X&=15;
  108. if(Y)X|=0x40;
  109. X|=0x80;
  110. WriteCommandLCM(X,0);
  111. WriteDataLCM(DData);
  112. }
  113. void Delay5us()
  114. {
  115.     _nop_();_nop_();_nop_();_nop_();
  116.     _nop_();_nop_();_nop_();_nop_();
  117.         _nop_();_nop_();_nop_();_nop_();
  118.         _nop_();_nop_();_nop_();_nop_();
  119. }
  120. void Delay5ms()
  121. {
  122.     WORD n = 560;
  123.     while (n--);
  124. }
  125. void BMP180_Start()
  126. {
  127.     SDA = 1;
  128.   SCL = 1;
  129.    Delay5us();
  130.     SDA = 0;
  131.   Delay5us();
  132.     SCL = 0;
  133. }
  134. void BMP180_Stop()
  135. {
  136.     SDA = 0;
  137.   SCL = 1;
  138.     Delay5us();
  139.     SDA = 1;
  140.   Delay5us();
  141. }
  142. void BMP180_SendACK(bit ack)
  143. {
  144.     SDA = ack;
  145.   SCL = 1;
  146.    Delay5us();
  147.     SCL = 0;
  148.   Delay5us();
  149. }
  150. bit BMP180_RecvACK()
  151. {
  152.     SCL = 1;
  153. Delay5us();
  154.     CY = SDA;
  155.    SCL = 0;
  156.     Delay5us();
  157.     return CY;
  158. }
  159. void BMP180_SendByte(BYTE dat)
  160. {
  161.     BYTE i;
  162.     for (i=0; i<8; i++)
  163.     {
  164.         dat <<= 1;
  165.         SDA = CY;
  166.         SCL = 1;
  167.    Delay5us();
  168.         SCL = 0;
  169.     Delay5us();
  170.     }
  171.     BMP180_RecvACK();
  172. }
  173. BYTE BMP180_RecvByte()
  174. {
  175.     BYTE i;
  176.     BYTE dat = 0;
  177.     SDA = 1;
  178.     for (i=0; i<8; i++)
  179.     {
  180.         dat <<= 1;
  181.         SCL = 1;
  182.    Delay5us();
  183.         dat |= SDA;
  184.         SCL = 0;
  185.      Delay5us();
  186.     }
  187.     return dat;
  188. }
  189. /*
  190. void Single_Write(uchar SlaveAddress,uchar REG_Address,uchar REG_data)
  191. {
  192.     BMP180_Start();
  193.     BMP180_SendByte(SlaveAddress);
  194.   BMP180_SendByte(REG_Address);
  195.     BMP180_SendByte(REG_data);
  196. BMP180_Stop();
  197. */
  198. /*
  199. uchar Single_Read(uchar REG_Address)
  200. {  uchar REG_data;
  201.     BMP180_Start();
  202.     BMP180_SendByte(BMP180_SlaveAddress);
  203.   BMP180_SendByte(REG_Address);
  204.     BMP180_Start();
  205.     BMP180_SendByte(BMP180_SlaveAddress+1);
  206.    REG_data=BMP180_RecvByte();
  207.       BMP180_SendACK(1);
  208.         BMP180_Stop();
  209.     return REG_data;
  210. }
  211. */
  212. short Multiple_read(uchar ST_Address)
  213. {
  214.         uchar msb, lsb;
  215.         short _data;
  216.     BMP180_Start();
  217.     BMP180_SendByte(BMP180_SlaveAddress);
  218.    BMP180_SendByte(ST_Address);
  219.     BMP180_Start();
  220.     BMP180_SendByte(BMP180_SlaveAddress+1);
  221.     msb = BMP180_RecvByte();
  222.     BMP180_SendACK(0);
  223.     lsb = BMP180_RecvByte();
  224.         BMP180_SendACK(1);
  225.     BMP180_Stop();
  226.     Delay5ms();
  227.     _data = msb << 8;
  228.         _data |= lsb;
  229.         return _data;
  230. }
  231. long bmp180ReadTemp(void)
  232. {
  233.     BMP180_Start();
  234.     BMP180_SendByte(BMP180_SlaveAddress);
  235.   BMP180_SendByte(0xF4);
  236.     BMP180_SendByte(0x2E);
  237.     BMP180_Stop();
  238.   delay(10);
  239.
  240.         return (long) Multiple_read(0xF6);
  241. }
  242. long bmp180ReadPressure(void)
  243. {
  244.         long pressure = 0;
  245.     BMP180_Start();
  246.     BMP180_SendByte(BMP180_SlaveAddress);
  247.    BMP180_SendByte(0xF4);
  248.     BMP180_SendByte(0x34);
  249.     BMP180_Stop();
  250.   delay(10);
  251.
  252.         pressure = Multiple_read(0xF6);
  253.         pressure &= 0x0000FFFF;
  254.         pressurewarn=pressure;
  255.         return pressurewarn;
  256.
  257. }
  258. void Init_BMP180()
  259. {
  260.         ac1 = Multiple_read(0xAA);
  261.         ac2 = Multiple_read(0xAC);
  262.         ac3 = Multiple_read(0xAE);
  263.         ac4 = Multiple_read(0xB0);
  264.         ac5 = Multiple_read(0xB2);
  265.         ac6 = Multiple_read(0xB4);
  266.         b1 =  Multiple_read(0xB6);
  267.         b2 =  Multiple_read(0xB8);
  268.         mb =  Multiple_read(0xBA);
  269.         mc =  Multiple_read(0xBC);
  270.         md =  Multiple_read(0xBE);
  271. }
  272. void bmp180Convert()
  273. {
  274.         //long ut;
  275.         long up;
  276.         long x1, x2, b5, b6, x3, b3, p;
  277.         unsigned long b4, b7;
  278.        // long  temperature;
  279.         long  pressure;
  280.
  281.        // ut = bmp180ReadTemp();
  282.        // ut = bmp180ReadTemp();
  283.         //up = bmp180ReadPressure();
  284.         up = bmp180ReadPressure();
  285.
  286.       /*  x1 = ((long)ut - ac6) * ac5 >> 15;
  287.         x2 = ((long) mc << 11) / (x1 + md);
  288.         b5 = x1 + x2;
  289.          temperature = (b5 + 8) >> 4;
  290.          conversion(temperature);
  291.          DisplayOneChar(0,0,'W');
  292.          DisplayOneChar(1,0,'e');
  293.          DisplayOneChar(2,0,'n');
  294.          DisplayOneChar(3,0,'D');
  295.          DisplayOneChar(4,0,'u');
  296.      DisplayOneChar(5,0,':');
  297.      DisplayOneChar(7,0,bai);
  298.      DisplayOneChar(8,0,shi);
  299.      DisplayOneChar(9,0,'.');
  300.          DisplayOneChar(10,0,ge);
  301.          DisplayOneChar(11,0,0XDF);
  302.          DisplayOneChar(12,0,'C');    */
  303.
  304.
  305.
  306.         b6 = b5 - 4000;
  307.         x1 = (b2 * (b6 * b6 >> 12)) >> 11;
  308.         x2 = ac2 * b6 >> 11;
  309.         x3 = x1 + x2;
  310.         b3 = (((long)ac1 * 4 + x3) + 2)/4;
  311.         x1 = ac3 * b6 >> 13;
  312.         x2 = (b1 * (b6 * b6 >> 12)) >> 16;
  313.         x3 = ((x1 + x2) + 2) >> 2;
  314.         b4 = (ac4 * (unsigned long) (x3 + 32768)) >> 15;
  315.         b7 = ((unsigned long) up - b3) * (50000 >> OSS);
  316.         if( b7 < 0x80000000)
  317.              p = (b7 * 2) / b4 ;
  318.            else
  319.                     p = (b7 / b4) * 2;
  320.         x1 = (p >> 8) * (p >> 8);
  321.         x1 = (x1 * 3038) >> 16;
  322.         x2 = (-7357 * p) >> 16;
  323.          pressure = p + ((x1 + x2 + 3791) >> 4);
  324.          conversion(pressure);
  325.      DisplayOneChar(0,1,'Q');
  326.          DisplayOneChar(1,1,'i');
  327.          DisplayOneChar(2,1,'Y');
  328.          DisplayOneChar(3,1,'a');
  329.      DisplayOneChar(5,1,':');
  330.          DisplayOneChar(6,1,shiwan);
  331.          DisplayOneChar(7,1,wan);
  332.      DisplayOneChar(8,1,qian);
  333.      DisplayOneChar(9,1,'.');
  334.      DisplayOneChar(10,1,bai);
  335.      DisplayOneChar(11,1,shi);
  336.          DisplayOneChar(12,1,'K');
  337.          DisplayOneChar(13,1,'p');
  338.          DisplayOneChar(14,1,'a');
  339. }
  340. void Warn(uint pressurewarn)
  341. {
  342.   if(pressurewarn==199.97)
  343.   {
  344.
  345.      led2=0;
  346.      delay(500);
  347.      led2=1;
  348.      delay(500);
  349.   }
  350. if(pressurewarn>=199.88)
  351.   {
  352.
  353.    led3=1;
  354.    delay(500);
  355.    led3=0;
  356.    delay(500);
  357.   }
  358.   if(pressurewarn<=99.99)
  359.   {
  360.    led1=0;
  361.    delay(500);
  362.    led1=1;
  363.    delay(500);
  364.   }
  365. }
  366. void main()
  367. {
  368.     delay(50);
  369.     InitLcd();
  370. Init_BMP180();
  371.    while(2)
  372.    {
  373.      bmp180Convert();
  374.      delay(1000);
  375.      Warn(pressurewarn);
  376.    }
  377. }
ID:164979 發表于 2017-5-29 20:15 | 只看該作者
無論數值改成多少,一直都是led3在閃
