我想通過鍵盤來切換lcd的顯示界面(共四個界面),我覺得思路沒問題,可是就是實(shí)現(xiàn)不了,下面是代碼
LcdInit();
//key_return=Keyscan();
Operation(Keyscan());
Show(interface);
void T0Init()
/*void T0() interrupt 1
void Operation(uchar key)//界面切換
switch(interface)
case 1:if(key==10)
interface=2;
//運(yùn)行界面,啟動定時器,同時切換界面
if(key==12)
interface=3;//設(shè)置界面
if(key==16)
interface=1;
break;
case 2:if(key==13)
interface=4;//查詢界面
else if(key==11)
//TR0=0;
interface=1;
else if(key==12)
//TR0=0;
interface=3;
break;
case 3:if(key==10)
//TR0=1;
interface=2;
else if(key==11)
//TR0=0;
interface=1;
break;
case 4:if(key==11)
interface=2;
void Show(uchar n)
switch(n)
case 1:Interface_start();
break;
case 2:Interface_run();
break;
case 3:Interface_set();
break;
case 4:Interface_find();
break;
void refresh_date(uchar address,uchar date)
Write_cmd(0x80+address);
Write_data(date);
void Interface_start()//打開電源顯示界面
//Write_cmd(0x01);
Write_cmd(0x80);
for(num=0;num<16;num++)
Write_data(table[num]);
delay(20);
Write_cmd(0x80+0x40);//第二行顯示
Write_data(table1[num]);
delay(20);
Write_cmd(0x80+0x50);
Write_cmd(0x0c);//開顯示,不顯示光標(biāo),不閃爍
void Interface_run()//運(yùn)行界面
LcdInit();
Write_data(table3[num]);
delay(20);
Write_data(table2[num]);
delay(20);
void Interface_set()//設(shè)置界面
Write_cmd(0x80+5);
Write_cmd(0x0f);
void Interface_find()//查詢界面
refresh_date(0x40+5,table2[5]);
refresh_date(0x40+6,table2[6]);
refresh_date(0x40+7,table2[7]);
refresh_date(0x40+8,table2[8]);
refresh_date(0x40+9,table2[9]);
refresh_date(0x40+10,table2[10]);
refresh_date(0x40+11,table2[11]);
void LcdInit()
wela=0;//lcd和數(shù)碼管共用P0
dula=0;//防止數(shù)碼管干擾
lcd_en=0;
Write_cmd(0x38);//設(shè)置16*2顯示,5*7點(diǎn)陣,8位數(shù)據(jù)口
Write_cmd(0x0f);//開顯示,顯示光標(biāo),光標(biāo)閃爍
Write_cmd(0x06);
Write_cmd(0x01);//清除數(shù)據(jù),防止出現(xiàn)錯誤
Write_cmd(0x80);
void Write_cmd(uchar cmd)
rs=0;//數(shù)據(jù)/命令選擇段(h/l)
P0=cmd;
delay(5);
lcd_en=1;//使能信號,高脈沖
delay(5);
lcd_en=0;
void Write_data(uchar data_)
rs=1;
P0=data_;
delay(5);
lcd_en=1;
delay(5);
lcd_en=0;
