查看: 3770|回復: 0
16X16點陣式電子顯示屏仿真程序
ID:205560 發表于 2017-5-28 10:20 | 顯示全部樓層 |閱讀模式
  1. #include<reg51.h>
  3. #define unit unsighed int
  4. #define out0 P0
  5. #define out2 P2
  6. #define out2 P1
  7. void delay(unit j)
  8. {
  9. uchar i=250;
  10. for(;j>0;j--)
  11. {
  12. while(--i);
  13. i=100;
  14. }
  15. }
  16. uchar code string[]={
  17. //漢字“東”的16*16點陣的列碼
  18. 0x00,0x08,0x88,0x48,0x28,0x18,0x0F,0xE8,0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x00,
  19. 0x00,0x20,0x11,0x09,0x05,0x41,0x81,0x7F,0x01,0x01,0x05,0x09,0x11,0x20,0x00,0x00
  20. //漢字“哥”的16*16點陣的列碼
  21. 0x00,0x02,0x02,0x7A,0x4A,0x4A,0x4A,0x4A,0x7A,0x02,0x02,0x7E,0x02,0x02,0x00,0x00,
  22. 0x01,0x01,0x01,0x3D,0x25,0x25,0x25,0x25,0x3D,0x41,0x81,0x7F,0x01,0x01,0x01,0x00
  23. //漢字“東”的16*16點陣的列碼
  24. 0x00,0x08,0x88,0x48,0x28,0x18,0x0F,0xE8,0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x00,
  25. 0x00,0x20,0x11,0x09,0x05,0x41,0x81,0x7F,0x01,0x01,0x05,0x09,0x11,0x20,0x00,0x00
  26. //漢字“哥”的16*16點陣的列碼
  27. 0x00,0x02,0x02,0x7A,0x4A,0x4A,0x4A,0x4A,0x7A,0x02,0x02,0x7E,0x02,0x02,0x00,0x00,
  28. 0x01,0x01,0x01,0x3D,0x25,0x25,0x25,0x25,0x3D,0x41,0x81,0x7F,0x01,0x01,0x01,0x00
  29. }
  30. void main()
  31. {
  32. uchar i,j,n;
  33. while(1)
  34. {
  35. for(j=0;j<4;j++)
  36. {
  37. for(n=0;n<40;n++)
  38. {
  39. for(i=0;n<16;i++)
  40. {
  41. out1=i%16;
  42. put0=string[i*2+j*32];
  43. out2=string[i*2+1+j*32];
  44. delay(4);
  45. out0=0xff;
  46. out2=0xff;
  47. }
  48. }
  49. }
  50. }
