#include <reg52.h>
void displaym();
sbit en=P2^5; //1602 6管腳
sbit rs=P2^7; //1602端口 4管腳
sbit rw=P2^6;//lcd1602控制端口 5管腳
sbit num1=P1^0; //占空比加1
sbit num2=P1^1; //占空比減一
sbit num3=P1^2; //正傳
sbit num4=P1^3; //反轉(zhuǎn)
sbit num5=P1^4; //開始停止切換
sbit out=P3^4; //PWM輸出用于正傳
sbit out1=P3^7; //PWM輸出用于反轉(zhuǎn)
uint zhuansu,flag,z1,z2,m,flag_1,zheng,fan,kai;
void delay(uint z)//延時1ms函數(shù)
uint x,y;
for(x=0;x<z;x++)
for(y=0;y<110;y++);
void write_com(uchar com)//向1602寫一字節(jié)(控制指令)
rs=0;
P0=com;
delay(5);
en=0;
delay(10);
en=1;
void write_data(uchar date)//向1602寫一字節(jié)(數(shù)據(jù))
rs=1;
P0=date;
delay(5);
en=0;
delay(5);
en=1;
void init()//初始化函數(shù)
en=0;
rw=0;
write_com(0x01); //lcd初始化
write_com(0x38); //5X7顯示
write_com(0x0c); //關閉光標
TMOD=0x01; //定時器方式1
TH0=0xdc;
TL0=0x00; //定時器裝入初值
EA=1; //開總中斷
ET0=1; //定時器0開中斷
TR0=1;
EX1=1;
IT1=1; //定時器啟動
TH1=0xff;
TL1=0x9c;//定時100us
ET1=1; //定時器1開中斷
TR1=1;
write_com(0x80);
write_data('V');
write_data(':');
write_com(0x87); //第一行顯示轉(zhuǎn)速
write_data('r');
write_data('p');
write_data('m');
write_com(0xc0);
write_data('z');
write_data('h');
write_data('a');
write_data('n');
write_data('k');
write_data('o');
write_data('n');
write_data('g');
write_data('b');
write_data('i'); //在第二行顯示zhankongbi:
write_data(':');
displaym();
void keyscan() //鍵盤掃描函數(shù)
if(num1==0)
delay(5); //消除抖動
if(num1==0)
if(m<=199)
m++;
displaym(); //設定占空比加一
if(num2==0)
delay(5);
if(num2==0)
if(m>=1)
m--;
displaym(); //設定占空比減一
if(num3==0)
delay(5);
if(num3==0)
zheng=1; //正傳標志置1
fan=0; // 反轉(zhuǎn)標志置0
if(num4==0)
delay(5);
if(num4==0)
zheng=0; //正傳標志置0
fan=1; // 反轉(zhuǎn)標志置1
if(num5==0)
delay(5);
if(num5==0)
while(num5==0) ;
kai=1-kai;
void display()
write_com(0x82);
zhuansu=zhuansu*30; //將兩秒內(nèi)的計數(shù)乘以30得到轉(zhuǎn)每分
if(zhuansu/10000!=0)
write_data(zhuansu/10000+0x30); //如果轉(zhuǎn)速的萬位不為0 正常顯示否則顯示空格
write_data(' ');
if(zhuansu/1000==0)
write_data(' ');
write_data(zhuansu%10000/1000+0x30); //如果轉(zhuǎn)速小于1000 千位為空格 否則正常顯示
if(zhuansu/100==0)
write_data(' ');
write_data(zhuansu%10000%1000/100+0x30); //如果轉(zhuǎn)速小于100 百位為空格 否則正常顯示
if(zhuansu/10==0)
write_data(' ');
write_data(zhuansu%10000%1000%100/10+0x30); //如果轉(zhuǎn)速小于10 十位為空格 否則正常顯示
write_data(zhuansu%10000%1000%100%10+0x30);
write_com(0xd0); //如果沒有這句,當中斷內(nèi)的顯示函數(shù)執(zhí)行完,就會在轉(zhuǎn)速的位置顯示占空比數(shù)據(jù),導致亂碼
void displaym()
write_com(0xcb);
if(m/200%10!=0)
write_data(m/200%10+0x30); //如果占空比百位不為0則顯示百位否則顯示空格
write_data(' ');
if(m/200%10==0&&m/20%10==0)
write_data(' ');
write_data(m/20%10+0x30); //如果占空比小于10 十位正常顯示 否則顯示空格
write_data(m/2%10+0x30); //顯示個位
write_data(' ');
write_data(' ');
flag_1=0;
m=100; //占空比為100
zhuansu=0; //轉(zhuǎn)速初值0
flag=0;
zheng=1; //初始化電機正轉(zhuǎn)動
fan=0;
init(); //初始化
keyscan(); //鍵盤掃描程序
void int1()interrupt 2 //外部中斷1脈沖技術記錄電機的轉(zhuǎn)速 電機轉(zhuǎn)一圈zhuansu加一
zhuansu++;
void int2()interrupt 3 //定時器0顯示轉(zhuǎn)速
TH0=0xdc;
TL0=0x00;//定時10ms
flag++;
if(flag==200) //計時到達2s
display(); //顯示轉(zhuǎn)速
zhuansu=0; //轉(zhuǎn)速置0
flag=0;
void int3()interrupt 1 //產(chǎn)生PWM
TH1=0xff;
TL1=0x9c;//定時100us
flag_1++;
if(flag_1>199)
flag_1=1;
if(kai==1) //如果kai==1電機啟動
if(zheng==1) //電機正轉(zhuǎn)
if(flag_1<m) //小于占空比m輸出PWM=0輸出電壓為1
{out=0;
out1=1;}
out=1;
out1=1;
if(fan==1) //電機反轉(zhuǎn)
out=1;
out1=0;
else //大于m輸出PWM=1輸出電壓為0
out=1;
out1=1;
if(kai==0) //kai=0電機停止轉(zhuǎn)動
out=1;
out1=1;
