查看: 2564|回復: 0
51電子鎖
ID:204465 發表于 2017-5-24 20:35 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
uchar old1=1,old2=2,old3=3,old4=4; //Ô-ê¼ÃüÂë000000
uchar new1,new2,new3,new4;  //ÿ′ÎMCU2é¼ˉμ½μÄÃüÂëêäèë
uchar a=16,b=16,c=16,d=16; //ËíèëêyÂë1üÏÔê¾μıäá¿
uchar wei,key,temp;
bit allow,genggai,ok,wanbi,retry,k;         //¸÷¸ö×′ì¬Î»
sbit led=P1^7;
unsigned char code table[]=
{0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,
0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00,0x40};
void delay(unsigned char i)
        uchar j,k;
  for(j=i;j>0;j--)
    for(k=125;k>0;k--);
void display(uchar a,uchar b,uchar c,uchar d)
   P2=0XFE;
   P0=table[a];
   delay(5);
   P2=0XFD;
   P0=table[b];
   delay(5);
   P2=0XFb;
   P0=table[c];
   delay(5);
   P2=0XF7;
   P0=table[d];
   delay(5);
void keyscan()
    P3=0xfe;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xee:
               key=1;
                           wei++;
               break;
          case 0xde:
               key=4;
                           wei++;
               break;
          case 0xbe:
               key=7;
                           wei++;
               break;
          case 0x7e:
              retry=1;
               break;//------------
                                          while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
    P3=0xfd;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xed:
               key=2;
                           wei++;
               break;
          case 0xdd:
               key=5;
                           wei++;
               break;
          case 0xbd:
               key=8;
                           wei++;
               break;
          case 0x7d:
              genggai=1;
                           wei=0;
               break;
                                 while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
    P3=0xfb;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xeb:
               key=3;
                           wei++;
               break;
          case 0xdb:
               key=6;
                           wei++;
               break;
          case 0xbb:
               key=9;
                           wei++;
               break;
          case 0x7b:
                             if(allow)
               ok=1;
               break;
         while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
void shumima()                //¶Ô°′¼ü2é¼ˉà′μÄêy¾Y½øDD·ÖÅä
        if(!wanbi)
        switch(wei)
                case 1:new1=key;
a=key;        break;
                case 2:new2=key;
                                 b=key;        break;
                case 3:new3=key;
                                 c=key;        break;
                case 4:new4=key;
                                 d=key;
                                wanbi=1;        break;
void yanzheng()          //ÑéÖ¤ÃüÂëêÇ·ñÕyè·
        if(wanbi)         //Ö»óDμ±áùλÃüÂë¾ùêäèëíê±Ïoó·½½øDDÑéÖ¤
        if((new1==old1)&(new2==old2)&(new3==old3)&(new4==old4)){
                allow=1;//μ±êäèëμÄÃüÂëÕyè·£¬»áμÃμ½alloweÖÃò»
                a=b=c=d=17;
                else k=1;
        led=0;
                keyscan();
                shumima();
                yanzheng();
                if(allow)         //ÑéÖ¤íêoó£¬èôallowÎa1£¬Ôò¿aËø
                        led=1;
                        if(!genggai)
                                wanbi=0;
                if(!genggai){
                if(k){
                        a=16;b=0;c=d=15;
                if(genggai)          //μ±S16¸ü¸ÄÃüÂë¼ü±»°′Ï£¬genggai»á±»ÖÃò»
                        if(allow)         //èôòѾ-°ÑËø′ò¿a£¬2ÅóD¸ü¸ÄÃüÂëμÄè¨ÏT
                                while(!wanbi)        //μ±DÂμÄáùλÃüÂëûóDé趨í꣬Ôòò»Ö±ÔúÕaàïÑ-»·
                                         keyscan();
                                        shumima();
                                        if(retry)         //¶øμ±ì½2aμ½ÖØêÔ¼üS18»òÕß1رÕÃüÂëËø¼üS19±»°′ÏÂê±£¬Ôòìø3ö
                                        {        wanbi=1;
                                                break;
                                        display(a,b,c,d);
                if(ok)          //¸ü¸ÄÃüÂëê±£¬μ±ËùóDáùλDÂÃüÂë¾ù±»°′ÏÂê±£¬¿éòÔ°′ÏÂ′˼ü£¬½áêøÃüÂë¸ü¸Ä
                {                  //ÆäËûê±¼ä°′ÏÂ′˼üÎTD§
                        ok=0; wei=0;
                        genggai=0;
                        old1=new1;old2=new2;old3=new3; //′Ëê±£¬¾éμÄÃüÂ뽫±»′úìæ
                        old4=new4;
                        a=16;b=16;c=16;d=16;
                if(retry)        //μ±ÖØêÔ°′¼üS18±»°′Ï£¬retry»á±»ÖÃλ
                retry=0; wei=0;wanbi=0;genggai=0;allow=0;k=0;
                new1=0;new2=0;new3=0;new4=0;
    led=0;
                display(a,b,c,d); //êμê±ÏÔê¾
