#include<reg51.h>
sbit P2_2=P2^2;
sbit P2_3=P2^3;
sbit P2_4=P2^4;
typedef unsigned char u8;
typedef unsigned int u16;
u8 code wel[10]={0x06,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,};
void display(unsigned long);
void delay(uint);
void main(void)
display(12345678); /*輸入8位數(shù)*/
void display(unsigned long x)
uint i;
for(i=0;i<8;i++)
switch(i)
case 0: P2_2=0;P2_3=0;P2_4=0;P0=wel[x%10]; break;
case 1: P2_2=1;P2_3=0;P2_4=0;P0=wel[(x/10)%10]; break;
case 2: P2_2=0;P2_3=1;P2_4=0;P0=wel[(x/100)%10]; break;
case 3: P2_2=1;P2_3=1;P2_4=0;P0=wel[(x/1000)%10]; break;
case 4: P2_2=0;P2_3=0;P2_4=1;P0=wel[(x/10000)%10]; break;
case 5: P2_2=1;P2_3=0;P2_4=1;P0=wel[(x/100000)%10]; break;
case 6: P2_2=0;P2_3=1;P2_4=1;P0=wel[(x/1000000)%10]; break;
case 7: P2_2=1;P2_3=1;P2_4=1;P0=wel[(x/10000000)]; break;
delay(50000);
void delay(uint y)
while(y--);
測試項目.rar
2017-5-24 10:37 上傳
294.52 KB, 下載次數(shù): 3
仿真文件
