查看: 1605|回復: 0
三燈同時點亮,白光 代碼
ID:203921 發(fā)表于 2017-5-23 15:35 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <stdint.h>
#include <stdbool.h>
#include "inc/tm4c123gh6pm.h"
#include "inc/hw_memmap.h"
#include "inc/hw_types.h"
#include "driverlib/sysctl.h"
#include "driverlib/gpio.h"
uint8_t ui8PinData=2;
void delay_Nms(uint n)
    uint i = 0;
    for(i = n;i > 0;i--)
            SysCtlDelay(SysCtlClockGet() / 3000);
int main(void)
        SysCtlClockSet(SYSCTL_SYSDIV_5|SYSCTL_USE_PLL|SYSCTL_XTAL_16MHZ|SYSCTL_OSC_MAIN);
//5分頻,使用PLL,外部晶振16M,system時鐘源選擇 main osc。系統(tǒng)時鐘40MHZ
        SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);//使能GPIO外設
        GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE, GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3);
//GPIO掛APB總線;輸出1,2,3引腳
                GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3, ui8PinData);
                //GPIO1,2,3位寫入2
                delay_Nms(100);//延時
                //delay_Nnop(1);
                GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3, 0x00);
                //GPIO1,2,3位寫入0
                delay_Nms(1000);
                //delay_Nnop(1);
                if(ui8PinData==8) {ui8PinData=2;} else {ui8PinData=ui8PinData*2;}
                //3種顏色循壞亮滅,2紅,4藍,8綠,代表三種顏色
                //三燈同時點亮,白光
