- #include <reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit dula=P2^6;
- sbit wela=P2^7;
- sbit led=P1^1;
- uchar flag,num;
- uchar code table[]={
- 0x3f,0x06,0x5b,0x4f,
- 0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,
- 0x39,0x5e,0x79,0x71};
- void delayms(uint xms) //延時(shí)函數(shù)
- uint i,j;
- for(i=xms;i>0;i--)
- for(j=110;j>0;j--);
- void display(uchar num) //數(shù)碼管顯示函數(shù)
- uchar bai,shi,ge;
- bai=num/100;
- shi=num%100/10;
- ge =num%10;
- dula=1;
- P0=table[bai];
- dula=0;
- P0=0xff;
- wela=1;
- P0=0x7e;
- wela=0;
- delayms(5);
- dula=1;
- P0=table[shi];
- dula=0;
- P0=0xff;
- wela=1;
- P0=0x7d;
- wela=0;
- delayms(5);
- dula=1;
- P0=table[ge];
- dula=0;
- P0=0xff;
- wela=1;
- P0=0x7b;
- wela=0;
- delayms(5);
- void ser() interrupt 4 //串口中斷
- RI = 0;
- num = SBUF; //從串口緩沖區(qū)取得數(shù)據(jù)
- flag=1;
- void init()
- SCON=0x50; //設(shè)定串口工作方式
- PCON=0x00; //波特率不倍增
- TMOD=0x20; //定時(shí)器1工作于8位自動(dòng)重載模式, 用于產(chǎn)生波特率
- EA=1;
- ES = 1; //允許串口中斷
- TL1=0xfd;
- TH1=0xfd; //波特率9600
- TR1=1;
- void main()
- led=0;
- wela=1;
- P0=0x7f;
- wela=0;
- init();
- while(1)
- display(num) ;
- if(flag==1) //標(biāo)志判斷
- SBUF=num;
- while(!TI);
- TI=0;
- flag=0; //標(biāo)志清除
全部資料下載地址:
串口實(shí)驗(yàn).zip
(21.88 KB, 下載次數(shù): 28)
2017-5-23 10:42 上傳
點(diǎn)擊文件名下載附件
