查看: 6072|回復: 4
STM32F4 ADC+DMA例程 基于MDK項目實例源碼
ID:67179 發表于 2017-5-21 18:44 | 顯示全部樓層 |閱讀模式
基于MDK項目實例
  1. #include "adc.h"
  2. ADC_HandleTypeDef    AdcHandle;
  3. void ADC1_MspInit(void)
  4. {
  5.     GPIO_InitTypeDef          GPIO_InitStruct;
  6.     static DMA_HandleTypeDef  hdma_adc;
  7.     __HAL_RCC_GPIOC_CLK_ENABLE();
  8.     __HAL_RCC_ADC1_CLK_ENABLE();
  9.     __HAL_RCC_DMA2_CLK_ENABLE();
  10.     //GPIOC2-5:ADC1-12:15
  11.     GPIO_InitStruct.Pin = GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_4 | GPIO_PIN_5;
  12.     GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
  13.     GPIO_InitStruct.Pull = GPIO_NOPULL;
  14.     HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  15.     hdma_adc.Instance = DMA2_Stream0;
  16.     hdma_adc.Init.Channel  =  DMA_CHANNEL_0;
  17.     hdma_adc.Init.Direction = DMA_PERIPH_TO_MEMORY;
  18.     hdma_adc.Init.PeriphInc = DMA_PINC_DISABLE;
  19.     hdma_adc.Init.MemInc = DMA_MINC_ENABLE;
  20.     hdma_adc.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
  21.     hdma_adc.Init.MemDataAlignment = DMA_PDATAALIGN_HALFWORD;
  22.     hdma_adc.Init.Mode = DMA_CIRCULAR;
  23.     hdma_adc.Init.Priority = DMA_PRIORITY_HIGH;
  24.     hdma_adc.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
  25.     hdma_adc.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_HALFFULL;
  26.     hdma_adc.Init.MemBurst = DMA_MBURST_SINGLE;
  27.     hdma_adc.Init.PeriphBurst = DMA_PBURST_SINGLE;
  28.     HAL_DMA_Init(&hdma_adc);
  29.     /* Associate the initialized DMA handle to the the ADC handle */
  30.     __HAL_LINKDMA(&AdcHandle, DMA_Handle, hdma_adc);
  31.     /*##-4- Configure the NVIC for DMA #########################################*/
  32.     /* NVIC configuration for DMA transfer complete interrupt */
  33.     HAL_NVIC_SetPriority(DMA2_Stream0_IRQn, 0, 0);
  34.     HAL_NVIC_EnableIRQ(DMA2_Stream0_IRQn);
  35. }
  36. void ADC1_Init(void)
  37. {
  38.     AdcHandle.Instance = ADC1;
  39.     AdcHandle.Init.ClockPrescaler = ADC_CLOCKPRESCALER_PCLK_DIV2;
  40.     AdcHandle.Init.Resolution = ADC_RESOLUTION_12B;
  41.     AdcHandle.Init.ScanConvMode = ENABLE;
  42.     AdcHandle.Init.ContinuousConvMode = ENABLE;
  43.     AdcHandle.Init.DiscontinuousConvMode = DISABLE;
  44.     AdcHandle.Init.NbrOfDiscConversion = 0;
  45.     AdcHandle.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  46.     AdcHandle.Init.ExternalTrigConv = ADC_EXTERNALTRIGCONV_T1_CC1;
  47.     AdcHandle.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  48.     AdcHandle.Init.NbrOfConversion = 4;
  49.     AdcHandle.Init.DMAContinuousRequests = ENABLE;
  50.     AdcHandle.Init.EOCSelection = DISABLE;
  51.                 ADC1_MspInit();
  52.     if(HAL_ADC_Init(&AdcHandle) != HAL_OK)
  53.     {
  54.         /* Initialization Error */
  55.         while(1);
  56.     }
  57. }
  58. void ADC1_Config(void)
  59. {
  60.     ADC_ChannelConfTypeDef sConfig;
  61.                 //channel - 12
  62.     sConfig.Channel = ADC_CHANNEL_12;
  63.     sConfig.Rank = 1;
  64.     sConfig.SamplingTime = ADC_SAMPLETIME_3CYCLES;
  65.     sConfig.Offset = 0;
  66.     HAL_ADC_ConfigChannel(&AdcHandle, &sConfig);
  67.
  68.                 //channel - 13
  69.     sConfig.Channel = ADC_CHANNEL_13;
  70.     sConfig.Rank = 2;
  71.     HAL_ADC_ConfigChannel(&AdcHandle, &sConfig);
  72. ……………………
  73. …………限于本文篇幅 余下代碼請從51黑下載附件…………
ADC DMA.rar (4.53 MB, 下載次數: 69)
ID:254078 發表于 2017-11-27 11:17 | 顯示全部樓層
新手教程 下來看看!謝謝大大
ID:394680 發表于 2018-9-7 23:10 | 顯示全部樓層
小白,求學習
ID:267330 發表于 2018-9-14 08:56 | 顯示全部樓層
單片機源程序如下:新手教程 下來看看!謝謝大大
ID:20672 發表于 2018-11-2 16:29 | 顯示全部樓層
謝謝分享~~~
