查看: 2003|回復: 0
四個按鍵槍聲 單片機模擬
ID:200856 發表于 2017-5-20 00:34 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include <intrins.h>
#define uint  unsigned int
sbit  BEEP= P1^5;
sbit  K1  = P3^0;
sbit  K2  = P3^1;
sbit  K3  = P3^3;
sbit  K4  = P3^2;
uchar  H_count,L_count;
void  main()
         P0=0;
        BEEP=1;
    TMOD=0x01;
    TH0=0xff;
    TL0=0xa0;
    H_count=0xff;
    L_count=0xa0;
    EA=1;
    ET0=1;
     if(K1 == 0)  TR0=1;
         if(K2 == 0)  TR0=1;
         if(K3 == 0)  TR0=1;
         if(K4 == 0)  TR0=1;
void Time0(void) interrupt 1 using 0
        BEEP=~BEEP;
        if( L_count!=0x00 )
           L_count--;
           TH0=H_count;
       TL0=L_count;
       return;
     }else  H_count--;
        if( H_count!=0xfc )
           L_count--;
           TH0=H_count;
       TL0=L_count;
       return;
        H_count=0xff;
        L_count=0xa0;
        TH0=H_count;
        TL0=L_count;
        BEEP=1;
        TR0=0;
