查看: 3650|回復: 1
初始化SSD1306
ID:201303 發表于 2017-5-16 12:24 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
OLED_RST_Set();
        delay_ms(100);
        OLED_RST_Clr();
        delay_ms(100);
        OLED_RST_Set();
OLED_WR_Byte(0xAE,OLED_CMD);//--turn off oled panel
        OLED_WR_Byte(0x00,OLED_CMD);//---set low column address
        OLED_WR_Byte(0x10,OLED_CMD);//---set high column address
        OLED_WR_Byte(0x40,OLED_CMD);//--set start line address  Set Mapping RAM Display Start Line (0x00~0x3F)
        OLED_WR_Byte(0x81,OLED_CMD);//--set contrast control register
        OLED_WR_Byte(0xCF,OLED_CMD); // Set SEG Output Current Brightness
        OLED_WR_Byte(0xA1,OLED_CMD);//--Set SEG/Column Mapping     0xa0左右反置 0xa1正常
        OLED_WR_Byte(0xC8,OLED_CMD);//Set COM/Row Scan Direction   0xc0上下反置 0xc8正常
        OLED_WR_Byte(0xA6,OLED_CMD);//--set normal display
        OLED_WR_Byte(0xA8,OLED_CMD);//--set multiplex ratio(1 to 64)
        OLED_WR_Byte(0x3f,OLED_CMD);//--1/64 duty
        OLED_WR_Byte(0xD3,OLED_CMD);//-set display offset        Shift Mapping RAM Counter (0x00~0x3F)
        OLED_WR_Byte(0x00,OLED_CMD);//-not offset
        OLED_WR_Byte(0xd5,OLED_CMD);//--set display clock divide ratio/oscillator frequency
        OLED_WR_Byte(0x80,OLED_CMD);//--set divide ratio, Set Clock as 100 Frames/Sec
        OLED_WR_Byte(0xD9,OLED_CMD);//--set pre-charge period
        OLED_WR_Byte(0xF1,OLED_CMD);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
        OLED_WR_Byte(0xDA,OLED_CMD);//--set com pins hardware configuration
        OLED_WR_Byte(0x12,OLED_CMD);
        OLED_WR_Byte(0xDB,OLED_CMD);//--set vcomh
        OLED_WR_Byte(0x40,OLED_CMD);//Set VCOM Deselect Level
        OLED_WR_Byte(0x20,OLED_CMD);//-Set Page Addressing Mode (0x00/0x01/0x02)
        OLED_WR_Byte(0x02,OLED_CMD);//
        OLED_WR_Byte(0x8D,OLED_CMD);//--set Charge Pump enable/disable
        OLED_WR_Byte(0x14,OLED_CMD);//--set(0x10) disable
        OLED_WR_Byte(0xA4,OLED_CMD);
        OLED_WR_Byte(0xAF,OLED_CMD);
        OLED_Clear();
        OLED_Set_Pos(0,0);
ID:896945 發表于 2021-11-23 18:10 | 只看該作者
謝謝,//補充長度
