查看: 9662|回復: 3
MF RC522測試程序 射頻模塊原理圖
MF RC522視頻模塊的電路原理圖如下:
MF RC522單片機源程序如下:
  1. /**********************RC522實驗開發板例程************************
  2. *  CPU:STC89C52RC
  3. *  晶振:11.0592MHZ
  4. ******************************************************************/
  5. //實驗目的:
  6. /*-----------------------------------------------
  7.   名稱:MF RC522
  8.   內容:通過標準程序靜態顯示字符
  9.   引腳定義如下:
  10. sbit     MF522_NSS  = P1^7;                        //SDA
  11. sbit     MF522_SCK  = P1^6;
  12. sbit     MF522_SI   = P1^5;
  13. sbit     MF522_SO   = P1^4;
  14. sbit     MF522_RST  = P1^3;
  15. //蜂鳴器OR指示燈
  16. sbit     LED_GREEN  =    P2^3;
  17. ------------------------------------------------*/
  18. #include "lpcreg.h"
  19. #include "main.h"
  20. #include "mfrc522.h"
  21. #include   <STDIO.H>
  22. #include <string.h>
  23. unsigned char code data1[16] = {0x12,0x34,0x56,0x78,0xED,0xCB,0xA9,0x87,0x12,0x34,0x56,0x78,0x01,0xFE,0x01,0xFE};
  24. //M1卡的某一塊寫為如下格式,則該塊為錢包,可接收扣款和充值命令
  25. //4字節金額(低字節在前)+4字節金額取反+4字節金額+1字節塊地址+1字節塊地址取反+1字節塊地址+1字節塊地址取反
  26. unsigned char code data2[4]  = {0,0,0,0x01};
  27. unsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
  28. unsigned char g_ucTempbuf[20];
  29. void delay1(unsigned int z)
  30. {
  31.         unsigned int x,y;
  32.         for(x=z;x>0;x--)
  33.         for(y=110;y>0;y--);
  34. }
  35. void main( )
  36. {
  37.      unsigned char status,i;
  38.           unsigned int temp;
  39.      InitializeSystem( );
  40.      PcdReset();
  41.      PcdAntennaOff();
  42.      PcdAntennaOn();
  43.      while ( 1 )
  44.      {
  45.          status = PcdRequest(PICC_REQALL, g_ucTempbuf);//尋卡
  46.          if (status != MI_OK)
  47.          {
  48.               InitializeSystem( );
  49.      PcdReset();
  50.      PcdAntennaOff();
  51.      PcdAntennaOn();
  52.                           continue;
  53.          }
  54.
  55.                         printf("卡的類型:");
  56.             for(i=0;i<2;i++)
  57.                                         {
  58.                                                 temp=g_ucTempbuf[i];
  59.                                                 printf("%X",temp);
  60.
  61.                                         }
  62.
  63.          status = PcdAnticoll(g_ucTempbuf);//防沖撞
  64.          if (status != MI_OK)
  65.          {    continue;    }
  66.
  67.                                         ////////以下為超級終端打印出的內容////////////////////////
  68.
  69.                                         printf("卡序列號:");        //超級終端顯示,
  70.                                         for(i=0;i<4;i++)
  71.                                         {
  72.                                                 temp=g_ucTempbuf[i];
  73.                                                 printf("%X",temp);
  74.
  75.                                         }
  76.                                         ///////////////////////////////////////////////////////////
  77.          status = PcdSelect(g_ucTempbuf);//選定卡片
  78.          if (status != MI_OK)
  79.          {    continue;    }
  80.
  81.          status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);//驗證卡片密碼
  82.          if (status != MI_OK)
  83.          {    continue;    }
  84.
  85.          status = PcdWrite(1, data1);//寫塊
  86.          if (status != MI_OK)
  87.          {    continue;    }
  88. while(1)
  89.                 {
  90.          status = PcdRequest(PICC_REQALL, g_ucTempbuf);//尋卡
  91.          if (status != MI_OK)
  92.          {
  93.                  InitializeSystem( );
  94.      PcdReset();
  95.      PcdAntennaOff();
  96.      PcdAntennaOn();
  97.                           continue;
  98.          }
  99.                  status = PcdAnticoll(g_ucTempbuf);//防沖撞
  100.          if (status != MI_OK)
  101.          {    continue;    }
  102.                 status = PcdSelect(g_ucTempbuf);//選定卡片
  103.          if (status != MI_OK)
  104.          {    continue;    }
  105.
  106.          status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);//驗證卡片密碼
  107.          if (status != MI_OK)
  108.          {    continue;    }
  109.          status = PcdValue(PICC_DECREMENT,1,data2);//扣款
  110.          if (status != MI_OK)
  111.          {    continue;    }
  112.
  113.          status = PcdBakValue(1, 2);//塊備份
  114.          if (status != MI_OK)
  115.          {    continue;    }
  116.
  117.          status = PcdRead(2, g_ucTempbuf);//讀塊
  118.          if (status != MI_OK)
  119.          {    continue;    }
  120.                 printf("卡讀塊:");        //超級終端顯示,
  121.          for(i=0;i<16;i++)
  122.                                         {
  123.                                                 temp=g_ucTempbuf[i];
  124.                                                 printf("%X",temp);
  125.
  126.                                         }
  127.                  printf("\n");
  128.                 LED_GREEN = 0;
  129.                 delay1(100);
  130.                 LED_GREEN = 1;
  131.                 delay1(100);
  132.                 LED_GREEN = 0;
  133.                 delay1(200);
  134.                 LED_GREEN = 1;
  135.                  PcdHalt();
  136.                 }
  137.     }
  138. }
  139. /////////////////////////////////////////////////////////////////////
  140. //系統初始化
  141. /////////////////////////////////////////////////////////////////////
  142. void InitializeSystem()
  143. {
  144.         P0M1 = 0x0; P0M2 = 0x0;
  145.         P1M1 = 0x0;        P1M2 = 0x0;
  146.         P3M1 = 0x0; P3M2 = 0xFF;
  147.         P0 = 0xFF; P1 = 0xFF; P3 = 0xFF;P2 = 0xFF;
  148.         TMOD=0x21;                   //設T0為方式1,GATE=1;
  149. ……………………
  150. …………限于本文篇幅 余下代碼請從51黑下載附件…………
MFRC522測試程序_20140411173219.rar (104.75 KB, 下載次數: 49)
ID:201241 發表于 2017-5-16 10:26 | 只看該作者
能有更詳細的關于電路原理的介紹嗎?設計思路等等的
ID:375715 發表于 2019-11-20 15:45 來自觸屏版 | 只看該作者
謝謝分享
