查看: 2538|回復: 0
小車占空比PWM程序
ID:195124 發表于 2017-5-12 22:50 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
#define uchar unsignied char
#define  uint unsignied int
unsigned char dj1=0;
unsigned char dj2=0;
sbit ENA=P0^0;   //A電機使能端
sbit ENB=P0^1;    //B電機使能端
sbit B1=P0^2; //L298N引腳驅動
sbit INT2=P0^3;
sbit INT3=P0^4;
sbit INT4=P0^5;
unsigned int t;
/*void delay(uint x)     //延遲1ms
uint i,j;
for(i=0;i<x;i++)
for(j=0;j<120;j++);
void forword()   //小車前進
B1=0;
INT2=1;
INT3=0;
INT4=1;
dj1=15;   //A輪小車占空比
dj2=15;  //B輪小車占空比
void inital()    //初始化程序
TMOD=0X01;      //0.5ms
TH0=(65536-500)/256;
TL0=(65536-500)%256;
EA=1;
ET0=1;
TR0=1;
void timer0() interrupt 1
t++;
if(t<dj1)
ENA=1;
ENA=0;
if(t<dj2)
ENB=1;
ENB=0;
if(t>20)
t=0;
inital();
  forword();
