查看: 3361|回復(fù): 3
求單片機(jī)電子音樂(lè)盒的設(shè)計(jì)
ID:199559 發(fā)表于 2017-5-12 18:00 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
10黑幣
設(shè)計(jì)任務(wù):
1、查閱資料,了解單片機(jī)控制單音喇叭發(fā)聲原理
2、設(shè)計(jì)一款基于單片機(jī)的音樂(lè)盒
3、通過(guò)按鈕可以選擇不同的音樂(lè)(點(diǎn)擊按鈕切換下一首)
ID:199559 發(fā)表于 2017-5-12 18:44 | 只看該作者
#include<reg52.h>                 //庫(kù)文件
#define uchar unsigned char//宏定義無(wú)符號(hào)字符型
#define uint unsigned int  //宏定義無(wú)符號(hào)整型
uchar Count;
sbit Key=P3^4;//P3.4控制T0口中斷
sbit _Speak =P2^0 ; //訊響器控制腳  //定義一個(gè)位變量_Speak
unsigned char code SONG[] ={
//路邊的野華不要采
0xFF,0x20,0x30,0x1C,0x10,0x18,0x20,
0x15,0x20,0x1C,0x20,0x20,0x20,0x26,0x40,0x20,0x20,0x2B,0x20,0x26,0x20,0x20,0x20,
0x30,0x80,0xFF,0x20,0x20,0x1C,0x10,0x18,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,
0x20,0x2B,0x40,0x20,0x20,0x1C,0x10,0x18,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,
0x20,0x2B,0x40,0x20,0x30,0x1C,0x10,0x18,0x20,0x15,0x20,0x1C,0x20,0x20,0x20,0x26,
0x40,0x20,0x20,0x2B,0x20,0x26,0x20,0x20,0x20,0x30,0x80,0x20,0x30,0x1C,0x10,0x20,
0x10,0x1C,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,0x20,0x2B,0x40,0x20,0x15,0x1F,
0x05,0x20,0x10,0x1C,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,0x20,0x2B,0x40,0x20,
0x30,0x1C,0x10,0x18,0x20,0x15,0x20,0x1C,0x20,0x20,0x20,0x26,0x40,0x20,0x20,0x2B,
0x20,0x26,0x20,0x20,0x20,0x30,0x30,0x20,0x30,0x1C,0x10,0x18,0x40,0x1C,0x20,0x20,
0x20,0x26,0x40,0x13,0x60,0x18,0x20,0x15,0x40,0x13,0x40,0x18,0x80,0x00,
0x26,0x20,0x20,0x20,0x20,0x20,0x26,0x10,0x20,0x10,0x20,0x80,0x26,0x20,0x30,0x20,
0x30,0x20,0x39,0x10,0x30,0x10,0x30,0x80,0x26,0x20,0x20,0x20,0x20,0x20,0x1c,0x20,
0x20,0x80,0x2b,0x20,0x26,0x20,0x20,0x20,0x2b,0x10,0x26,0x10,0x2b,0x80,0x26,0x20,
0x30,0x20,0x30,0x20,0x39,0x10,0x26,0x10,0x26,0x60,0x40,0x10,0x39,0x10,0x26,0x20,
0x30,0x20,0x30,0x20,0x39,0x10,0x26,0x10,0x26,0x80,0x26,0x20,0x2b,0x10,0x2b,0x10,
0x2b,0x20,0x30,0x10,0x39,0x10,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x40,0x40,0x20,
0x20,0x10,0x20,0x10,0x2b,0x10,0x26,0x30,0x30,0x80,0x18,0x20,0x18,0x20,0x26,0x20,
0x20,0x20,0x20,0x40,0x26,0x20,0x2b,0x20,0x30,0x20,0x30,0x20,0x1c,0x20,0x20,0x20,
0x20,0x80,0x1c,0x20,0x1c,0x20,0x1c,0x20,0x30,0x20,0x30,0x60,0x39,0x10,0x30,0x10,
0x20,0x20,0x2b,0x10,0x26,0x10,0x2b,0x10,0x26,0x10,0x26,0x10,0x2b,0x10,0x2b,0x80,
0x18,0x20,0x18,0x20,0x26,0x20,0x20,0x20,0x20,0x60,0x26,0x10,0x2b,0x20,0x30,0x20,
0x30,0x20,0x1c,0x20,0x20,0x20,0x20,0x80,0x26,0x20,0x30,0x10,0x30,0x10,0x30,0x20,
0x39,0x20,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x40,0x40,0x10,0x40,0x10,0x20,0x10,
0x20,0x10,0x2b,0x10,0x26,0x30,0x30,0x80,0x00,};
void Time0_Init()//初始化函數(shù)
        TMOD = 0x01;//定時(shí)器中斷地工作狀態(tài)為1
        IE = 0x82;  //p127 中斷允許寄存器,82=10000010,IE.7位為1表示CPU開放中斷,IE.1表示允許定時(shí)器T0溢出中斷
        TH0 = 0xD8;   //為T0計(jì)數(shù)器付初值,高位TH0=0XD8,低位TL0=0XF0,65536-55536=10000,表明T0計(jì)數(shù)器計(jì)數(shù)10000個(gè)計(jì)數(shù)周期后溢出
        TL0 = 0xF0; //12MZ晶振,10ms
void Time0_Int() interrupt 1    //定時(shí)計(jì)數(shù)器T0中斷p128
        TH0 = 0xD8;  //重裝初值
        TL0 = 0xF0;
        Count++; //長(zhǎng)度加1,執(zhí)行一次,中斷計(jì)數(shù)器加一
void Delay_xMs(unsigned int x) //1MS 延時(shí)子程序
        unsigned int i,j;
        for( i =0;i < x;i++ )
                for( j =0;j<3;j++ );
void Play_Song(unsigned char i) //:歌曲播放子程序i 為播放哪一段曲目
        unsigned char Temp1,Temp2;
        unsigned int Addr=0;
        Count = 0; //中斷計(jì)數(shù)器清0
    Addr=i*165;
                Temp1 = SONG[Addr++];
                if ( Temp1 == 0xFF ) //休止符
                                TR0 = 0; Delay_xMs(100);
        else if ( Temp1 == 0x00 ) //歌曲結(jié)束符
                        return;
        Temp2 = SONG[Addr++];
        TR0 = 1;
        _Speak = ~_Speak;   //按位取反指令
        Delay_xMs(Temp1);
        if ( Temp2 == Count )
                        Count = 0;
                        break;
void main() //主程序
        Time0_Init(); //定時(shí)器0 中斷初始化
      if(Key==0){
                Play_Song(0);
                if(Key==0){
                Play_Song(1);}}else{
TR0=0;
        } //播放
這是目前的代碼,我想知道怎么通過(guò)點(diǎn)擊P3.4的按鈕實(shí)現(xiàn)切換到下一首歌曲的功能
ID:199559 發(fā)表于 2017-5-12 18:45 | 只看該作者
對(duì)了,main函數(shù)那里是錯(cuò)的,并不能實(shí)現(xiàn)切換歌曲
ID:637659 發(fā)表于 2019-11-12 19:46 | 只看該作者
代碼:
#include <reg51.h>
sbit speaker = P3^1;
sbit key0 = P2^0;
sbit key1 = P2^1;
sbit key2 = P2^2;
sbit key3 = P2^3;
unsigned char k, i;
unsigned char timer0h, timer0l, time ,num ,tempi,tempstop,tempan,temptime;
unsigned char code table[]={//我做的數(shù)碼管 數(shù)字顯示
        0x3f,0x30,0xed,0x79,
        0x72,0x5b,0x5f};
unsigned char code table[]={                //數(shù)碼管 數(shù)字顯示
        0x3f,0x06,0x5b,0x4f,
        0x66,0x6d,0x7d,0x07,
        0x7f,0x6f,0x77,0x7c,
        0x39,0x5e,0x79,0x71};
//---------------------------------1 2 3 4 5 6 7音調(diào)
code unsigned char FREQH[] = {        //TH0部分
    0xF2, 0xF3, 0xF5, 0xF5, 0xF6, 0xF7, 0xF8,                            //低音1234567
    0xF9, 0xF9, 0xFA, 0xFA, 0xFB, 0xFB, 0xFC, 0xFC,                        //中
    0xFC, 0xFD, 0xFD, 0xFD, 0xFD, 0xFE,                            //高
    0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFF                                //超高
code unsigned char FREQL[] = {        //TL0部分
    0x42, 0xC1, 0x17, 0xB6, 0xD0, 0xD1, 0xB6,
    0x21, 0xE1, 0x8C, 0xD8, 0x68, 0xE9, 0x5B, 0x8F,
    0xEE, 0x44, 0x6B, 0xB4, 0xF4, 0x2D,
    0x47, 0x77, 0xA2, 0xB6, 0xDA, 0xFA, 0x16
code unsigned char song[][150]={                                //歌曲
{3,2,2, 3,2,2, 3,2,2, 1,2,1, 3,2,2,        0,0,0, 5,2,2, 0,0,0,
5,1,2,        0,0,0, 1,2,1,        0,0,0, 5,1,1,        0,0,0, 3,1,2,        0,0,0,
6,1,2, 7,1,2, 7,1,2, 6,1,2, 5,1,2, 3,2,2, 5,2,1, 6,2,1,
0,0,0, 4,2,1, 5,2,1, 0,0,0, 3,2,1, 0,0,0, 1,2,1, 2,2,1,
7,1,2, 0,0,0, 1,2,2, 0,0,0, 5,1,1, 0,0,0, 0,0,0, 3,1,1,
0,0,0, 6,1,2, 7,1,2, 0,0,0, 7,1,2, 6,1,2, 5,1,2, 3,2,2, 0,0,100
{6, 2, 3,  5, 2, 1,  3, 2, 2,  5, 2, 2,  1, 3, 2,  6, 2, 1,  5, 2, 1,
//一個(gè)音符有三個(gè)數(shù)字。前為第幾個(gè)音、中為第幾個(gè)八度、后為時(shí)長(zhǎng)(以半拍為單位)。
//6, 2, 3 分別代表:6, 中音, 3個(gè)半拍;
//5, 2, 1 分別代表:5, 中音, 1個(gè)半拍;
//3, 2, 2 分別代表:3, 中音, 2個(gè)半拍;
//5, 2, 2 分別代表:5, 中音, 2個(gè)半拍;
//1, 3, 2 分別代表:1, 高音, 2個(gè)半拍;
6, 2, 4, 3, 2, 2, 5, 2, 1, 6, 2, 1, 5, 2, 2, 3, 2, 2, 1, 2, 1,
6, 1, 1, 5, 2, 1, 3, 2, 1, 2, 2, 4, 2, 2, 3, 3, 2, 1, 5, 2, 2,
5, 2, 1, 6, 2, 1, 3, 2, 2, 2, 2, 2, 1, 2, 4, 5, 2, 3, 3, 2, 1,
2, 2, 1, 1, 2, 1, 6, 1, 1, 1, 2, 1, 5, 1, 6, 0, 0, 100},
{6, 3, 1, 6, 3, 1, 6, 3, 1, 6, 3, 1, 6, 3, 1, 6, 3, 1, 0,0,100},
{0,0,1, 0,0,100},
void delay(unsigned char t)     //節(jié)拍
        unsigned char t1;
        unsigned long t2;
        for(t1 = 0; t1 < t; t1++)
                for(t2 = 0; t2 < 8000; t2++);
        TR0 = 0;
void delaya(unsigned char t)     //節(jié)拍
        unsigned char t1;
        unsigned long t2;
                for(t2 = 0; t2 < 2000; t2++);
        TR0 = 0;
void delay1(int z)                        //延遲z ms
        int i,j;
        for(i=0;i<110;i++)
                for(j=0;j<z;j++);
void an()                //按鍵檢測(cè)
        P2=0xff;
        if(key1==0||key2==0||key3==0)
                delay1(10);
                if(key1==0)
                        num++;
                        if(num==4)
                                        num=0;
                        i=0;
                        time=0;
                if(key2==0)
                        num--;
                        if(num==-1)
                                        num=3;
                        i=0;
                        time=0;
                if(key3==0)
                        tempstop=!tempstop;
                while(!key1||!key2||!key3);
                delay1(5);
        P2=0xff;
        tempan=P2;
        tempan=tempan&0x0f;
        while(tempan!=0x0f)
                delay1(5);
                tempan=P2;
                tempan=tempan&0x0f;
                while(tempan==0x0f);
                switch(tempan)
                        case 0x0e:
                                num++;
                                if(num==4)
                                                num=0;
                                i=0;
                                time=0;
                                break;
                        case 0x0d:
                                num--;
                                if(num==-1)
                                                num=3;
                                i=0;
                                time=0;
                                break;
                        case 0x0b:
                                tempstop=!tempstop;
                                break;
                        case 0x07:
                                temptime=!temptime;
                                break;
                while(tempan!=0x0f)
                        tempan=P2;
                        tempan=tempan&0x0f;
                        delay1(5);
void main(void)
        tempi=1;
        TMOD = 1;
        ET0 = 1;
        EA = 1;
                if(song[num][i+2]==100)
                        i=0;
                k = song[num][i]+7*(song[num][i + 1]-1);
                timer0h = FREQH[k];
                timer0l = FREQL[k];
                time = song[num][i + 2];
                if(tempi==1)
                i += 3;
                TH0 = timer0h;
                TL0 = timer0l;
                TR0 = 1;
                if(!temptime)
                        delay(time);
                        delaya(time);
                P1=table[num+1];
                while(tempstop)
                        an();
void t0int() interrupt 1
    TR0 = 0;
    speaker = !speaker;
    TH0 = timer0h;
    TL0 = timer0l;
    TR0 = 1;
                an();
