查看: 7517|回復(fù): 5
ADC0832的proteus仿真與單片機(jī)程序 LCD1602顯示
ID:200018 發(fā)表于 2017-5-12 17:23 | 顯示全部樓層 |閱讀模式
仿真圖:
單片機(jī)源程序如下:
  1. #include <reg52.h>
  2. #include<intrins.h>
  3. #include<math.h>
  4. /**********************************8/
  5. /**********LCD1602接口程序**********/
  6. #define DD P2
  7. sbit Rs=P3^0;
  8. sbit Rw=P3^1;
  9. sbit E=P3^2;
  10. sbit busy_p=ACC^7;
  11. /********************************/
  12. void delay_1ms(unsigned char i)   //最小延時1ms
  13. { unsigned char j;
  14. while(i--)
  15. for(j=0;j<125; j++);
  16. }
  17. void delay_10ns(unsigned char i) //最小延時10ns
  18. { unsigned char j;
  19. while(i--)
  20. for(j=0;j<10; j++);
  21. }
  22. void write_com(unsigned char com,bit p)   //寫指令
  23. {if(p)
  24. delay_10ns(5);
  25. E=0;
  26. Rs=0;
  27. Rw=0;
  28. DD=com;
  29. delay_10ns(50); //>40ns
  30. E=1;
  31. delay_1ms(2); //>150ns
  32. E=0;
  33. delay_10ns(4); //>25+10ns
  34. }
  35. void write_date(unsigned char DATA)   //寫數(shù)據(jù)
  36. {
  37. delay_10ns(50);
  38. E=0;
  39. Rs=1;
  40. Rw=0;
  41. DD=DATA;
  42. delay_10ns(50);
  43. E=1;
  44. delay_10ns(50);
  45. E=0;
  46. delay_10ns(4);
  47. }
  48. void addr_x_y(unsigned char x,bit y)   //寫坐標(biāo),定位置
  49. { unsigned char temp=0x80;
  50. if(y)
  51.    {temp|=0x40;}
  52.    temp|=x;
  53. write_com(temp,0);
  54. }
  55. void desplay_char(unsigned char x,bit y,unsigned char p)
  56. //在指定位置顯示一個字符。
  57. { addr_x_y(x,y);
  58. write_date(p);
  59. }
  60. void init(void)
  61. {delay_1ms(15);
  62. write_com(0x38,0);
  63. delay_1ms(5);
  64. write_com(0x38,0);
  65. delay_1ms(5);
  66. write_com(0x38,0);
  67. delay_1ms(5);
  68. write_com(0x38,1);
  69. write_com(0x08,1);
  70. write_com(0x01,1);
  71. write_com(0x06,1);
  72. write_com(0x0c,1);
  73. }
  74. void xs_int(unsigned int shuju,bit t)   //顯示一個數(shù)字
  75. {unsigned char huancun[6]={0};
  76. unsigned char biaozhi=0,i;
  77. if   (shuju < 10) biaozhi = 1;
  78. else if(shuju < 100) biaozhi = 2;
  79. else if(shuju < 1000) biaozhi = 3;
  80. else if(shuju < 10000) biaozhi = 4;
  81. else if(shuju < 65535) biaozhi = 5;
  82. switch(biaozhi)
  83.    {case 5:huancun[5] = shuju/10000;
  84.     case 4:huancun[3] = shuju%10000/1000;
  85.     case 3:huancun[2] = shuju%1000/100;
  86.     case 2:huancun[1] = shuju%100/10;
  87.     case 1:huancun[0] = shuju%10;
  88. break;
  89.     default:break;
  90. }
  91. for(i=6;i>1;i--)
  92.    {if(i==5)desplay_char(10,1,'.');
  93.         else desplay_char(15-i,t,0x30+huancun[i-1]); }
  94. desplay_char(15,t,'V');
  95. }
  96. /************************************************************/
  97. /**********ADC0832接口程序************************************/
  98. sbit ADC_CS =P3^4;
  99. sbit ADC_CLK=P3^5;
  100. sbit ADC_DO =P3^6;
  101. sbit ADC_DI =P3^7;
  102. /*******************************************************************/
  103. void Delay(unsigned char j)
  104. {
  105. unsigned char i;
  106. for(i=0;i<j;i++); //延時,脈沖一位持續(xù)的時間
  107. }
  108. unsigned char ADC0832(void) //把模擬電壓值轉(zhuǎn)換成8位二進(jìn)制數(shù)并返回
  109. {
  110. unsigned char i,data_c;
  111. data_c=0;
  112. ADC_CS=0;
  113. ADC_DO=0;//片選,DO為高阻態(tài)
  114. for(i=0;i<10;i++)
  115.     {;}
  116. ADC_CLK=0;
  117. Delay(2);
  118. ADC_DI=1;
  119. ADC_CLK=1;
  120. Delay(2); //第一個脈沖,起始位
  121. ADC_CLK=0;
  122. Delay(2);
  123. ADC_DI=1;
  124. ADC_CLK=1;
  125. Delay(2); //第二個脈沖,DI=1表示雙通道單極性輸入
  126. ADC_CLK=0;
  127. Delay(2);
  128. ADC_DI=1;
  129. ADC_CLK=1;
  130. Delay(2); //第三個脈沖,DI=1表示選擇通道1(CH2)
  131. ADC_DI=0;
  132. ADC_DO=1;//DI轉(zhuǎn)為高阻態(tài),DO脫離高阻態(tài)為輸出數(shù)據(jù)作準(zhǔn)備
  133. ADC_CLK=1;
  134. Delay(2);
  135. ADC_CLK=0;
  136. Delay(2);//經(jīng)實驗,這里加一個脈沖AD便能正確讀出數(shù)據(jù),
  137.            //不加的話讀出的數(shù)據(jù)少一位(最低位d0讀不出)
  138. for (i=0; i<8; i++)
  139.     {
  140.      ADC_CLK=1;
  141.         Delay(2);
  142. ……………………
  143. …………限于本文篇幅 余下代碼請從51黑下載附件…………
ADC0832.zip (157.77 KB, 下載次數(shù): 183)
參與人數(shù) 1黑幣 +1 收起 理由
tcsncg + 1 很給力!
ID:337640 發(fā)表于 2018-5-25 10:55 | 顯示全部樓層
直接跑,好像跑不起來
ID:588348 發(fā)表于 2020-3-29 08:51 | 顯示全部樓層
老哥,跑起來程序顯示的一直是0呀
ID:694118 發(fā)表于 2020-4-10 09:41 | 顯示全部樓層
張小超 發(fā)表于 2020-3-29 08:51
老哥,跑起來程序顯示的一直是0呀
是頻率問題嗎,可能是單片機(jī)晶振頻率和0832的工作頻率不匹配,我也剛開始學(xué),不懂
ID:713781 發(fā)表于 2020-4-13 20:49 | 顯示全部樓層
顯示和ad沒有動啊
ID:713781 發(fā)表于 2020-4-13 20:56 | 顯示全部樓層
#include <reg52.h>  #include <intrins.h>  #include <math.h>  /**********************************8/  /**********LCD1602接口程序**********/  #define DD P2  sbit Rs=P3^0;  sbit Rw=P3^1;  sbit E=P3^2;  sbit busy_p=ACC^7;  /********************************/  void delay_1ms(unsigned char i) //最小延時1ms  { unsigned char j;  while(i--)  for(j=0;j<125; j++);  }  void delay_10ns(unsigned char i) //最小延時10ns  { unsigned char j;  while(i--)  for(j=0;j<10; j++);  }  void write_com(unsigned char com,bit p) //寫指令  {if(p)  delay_10ns(5);  E=0;  Rs=0;  Rw=0;  DD=com;  delay_10ns(50); //>40ns  E=1;  delay_1ms(2); //>150ns  E=0;  delay_10ns(4); //>25+10ns  }  void write_date(unsigned char DATA) //寫數(shù)據(jù)  {  delay_10ns(50);  E=0;  Rs=1;  Rw=0;  DD=DATA;  delay_10ns(50);  E=1;  delay_10ns(50);  E=0;  delay_10ns(4);  }  void addr_x_y(unsigned char x,bit y) //寫坐標(biāo),定位置  { unsigned char temp=0x80;  if(y)  {temp|=0x40;}  temp|=x;  write_com(temp,0);  }  void desplay_char(unsigned char x,bit y,unsigned char p)  //在指定位置顯示一個字符。  { addr_x_y(x,y);  write_date(p);  }  void init(void)  {delay_1ms(15);  write_com(0x38,0);  delay_1ms(5);  write_com(0x38,0);  delay_1ms(5);  write_com(0x38,0);  delay_1ms(5);  write_com(0x38,1);  write_com(0x08,1);  write_com(0x01,1);  write_com(0x06,1);  write_com(0x0c,1);  }  void xs_int(unsigned int shuju,bit t) //顯示一個數(shù)字  {unsigned char huancun[6]={0};  unsigned char biaozhi=0,i;  if (shuju < 10) biaozhi = 1;  else if(shuju < 100) biaozhi = 2;  else if(shuju < 1000) biaozhi = 3;  else if(shuju < 10000) biaozhi = 4;  else if(shuju < 65535) biaozhi = 5;  switch(biaozhi)  {case 5:huancun[5] = shuju/10000;  case 4:huancun[3] = shuju%10000/1000;  case 3:huancun[2] = shuju%1000/100;  case 2:huancun[1] = shuju%100/10;  case 1:huancun[0] = shuju%10;  break;  default:break;  }  for(i=6;i>1;i--)  {if(i==5)desplay_char(10,1,'.');  else desplay_char(15-i,t,0x30+huancun[i-1]); }  desplay_char(15,t,'V');  }  /************************************************************/  /**********ADC0832接口程序************************************/  sbit ADC_CS =P3^4;  sbit ADC_CLK=P3^5;  sbit ADC_DO =P3^6;  sbit ADC_DI =P3^7;  /*******************************************************************/  void Delay(unsigned char j)  {  unsigned char i;  for(i=0;i<j;i++); //延時,脈沖一位持續(xù)的時間  }  unsigned char ADC0832(void) //把模擬電壓值轉(zhuǎn)換成8位二進(jìn)制數(shù)并返回  {  unsigned char i,data_c;  data_c=0;  ADC_CS=0;  ADC_DO=0;//片選,DO為高阻態(tài)  for(i=0;i<10;i++)  {;}  ADC_CLK=0;  Delay(2);  ADC_DI=1;  ADC_CLK=1;  Delay(2); //第一個脈沖,起始位  ADC_CLK=0;  Delay(2);  ADC_DI=1;  ADC_CLK=1;  Delay(2); //第二個脈沖,DI=1表示雙通道單極性輸入  ADC_CLK=0;  Delay(2);  ADC_DI=1;  ADC_CLK=1;  Delay(2); //第三個脈沖,DI=1表示選擇通道1(CH2)  ADC_DI=0;  ADC_DO=1;//DI轉(zhuǎn)為高阻態(tài),DO脫離高阻態(tài)為輸出數(shù)據(jù)作準(zhǔn)備  ADC_CLK=1;  Delay(2);  ADC_CLK=0;  Delay(2);//經(jīng)實驗,這里加一個脈沖AD便能正確讀出數(shù)據(jù),  //不加的話讀出的數(shù)據(jù)少一位(最低位d0讀不出)  for (i=0; i<8; i++)  {  ADC_CLK=1;  Delay(2);  ADC_CLK=0;  Delay(2);  data_c=(data_c<<1)|ADC_DO;//在每個脈沖的下降沿DO輸出一位數(shù)據(jù),最終ch為8位二進(jìn)制數(shù)  }  ADC_CS=1;//取消片選,一個轉(zhuǎn)換周期結(jié)束  return(data_c);//把轉(zhuǎn)換結(jié)果返回  }  void main(void)  {  unsigned int data_temp=0;  while(1)  { data_temp=ADC0832();  init();  xs_int(196*data_temp,1);  }  }
