多路超聲波的程序,讓超聲波模塊避免相互干擾,實(shí)現(xiàn)避障小車、跟隨小車燈。。
2017-5-12 17:21 上傳
單片機(jī)源程序如下:
- //使用時(shí)將US100跳帽拔下,使其設(shè)置為電平觸發(fā)模式
- #include <reg52.h>
- #include <intrins.h>
- //引腳定義
- sbit Trig1 = P1 ^ 0; //
- sbit Ecno1 = P1 ^ 1; //
- sbit Trig2 = P3 ^ 2; //
- sbit Ecno2 = P3 ^ 3; //
- sbit Trig3 = P1 ^ 2; //
- sbit Ecno3 = P1 ^ 3; //
- sbit Trig4 = P1 ^ 4; //
- sbit Ecno4 = P1 ^ 5; //
- sbit CS = P0 ^ 5; //片選 高電平有效 單片LCD使用時(shí)可固定高電平
- sbit SID = P0 ^ 6; //數(shù)據(jù)
- sbit SCLK = P0 ^ 7; //時(shí)鐘
- // 函數(shù)聲明
- void Write_char(bit start, unsigned char ddata);
- void Send_byte(unsigned char bbyte);
- void Delaynms(unsigned int di);
- void Lcd_init(void);
- void LCD_Write_string(unsigned char X,unsigned char Y,unsigned char *s);
- void LCD_set_xy( unsigned char x, unsigned char y );
- void StartModule() ;
- void Clr_Scr();
- unsigned char code num[]={"0123456789 :."};
- unsigned char code table1[]={" 前方距離:"};
- unsigned char code table2[] ={"后方距離:"};
- unsigned char code table3[] ={"左方距離:"};
- unsigned char code table4[] ={"右方距離:"};
- unsigned char code M[] = {"CM"};
- unsigned int time1=0;
- unsigned int time2=0;
- unsigned int time3=0;
- unsigned int time4=0;
- long S1=0;
- long S2=0;
- long S3=0;
- long S4=0;
- bit flag =0;
- unsigned char disbuff[4] ={ 0,0,0,0,};
- void Lcd_init(void) //初始化LCD
- Delaynms(10); //啟動(dòng)等待,等LCM講入工作狀態(tài)
- CS=1;
- Write_char(0,0x30); //8 位介面,基本指令集
- Write_char(0,0x0c); //顯示打開,光標(biāo)關(guān),反白關(guān)
- Write_char(0,0x01); //清屏,將DDRAM的地址計(jì)數(shù)器歸零
- void Write_char(bit start, unsigned char ddata) //寫指令或數(shù)據(jù)
- unsigned char start_data,Hdata,Ldata;
- if(start==0)
- start_data=0xf8; //寫指令
- else
- start_data=0xfa; //寫數(shù)據(jù)
- Hdata=ddata&0xf0; //取高四位
- Ldata=(ddata<<4)&0xf0; //取低四位
- Send_byte(start_data); //發(fā)送起始信號(hào)
- Delaynms(5); //延時(shí)
- Send_byte(Hdata); //發(fā)送高四位
- Delaynms(1); //延時(shí)
- Send_byte(Ldata); //發(fā)送低四位
- void Send_byte(unsigned char bbyte) //發(fā)送一個(gè)字節(jié)
- unsigned char i;
- for(i=0;i<8;i++)
- SID=bbyte&0x80; //取出最高位
- SCLK=1;
- SCLK=0;
- bbyte<<=1; //左移
- void Delaynms(unsigned int di) //延時(shí)
- unsigned int da,db;
- for(da=0;da<di;da++)
- for(db=0;db<10;db++);
- void Clr_Scr(void)//清屏函數(shù)
- void LCD_set_xy( unsigned char x, unsigned char y )//設(shè)置LCD顯示的起始位置,X為行,Y為列
- unsigned char address;
- switch(x)
- case 0: address = 0x80 + y; break;
- case 1: address = 0x80 + y; break;
- case 2: address = 0x90 + y; break;
- case 3: address = 0x88 + y; break;
- case 4: address = 0x98 + y; break;
- default:address = 0x80 + y; break;
- Write_char(0, address);
- LCD_set_xy( X, Y );
- while (*s)
- Write_char( 1, *s );
- s ++;
- Delaynms(1);
- void LCD_Write_number(unsigned char s)// 數(shù)字顯示函數(shù)
- Write_char(1,num[s]);
- Delaynms(1);
- void Lcd_Mark2(void)
- Clr_Scr();//清屏
- LCD_Write_string(1,0,table1);//
- LCD_Write_string(1,7,M);
- LCD_Write_string(2,0,table2);
- LCD_Write_string(2,7,M);//
- LCD_Write_string(3,0,table3);//
- LCD_Write_string(3,7,M);
- LCD_Write_string(4,0,table4);//
- LCD_Write_string(4,7,M);
- void Conut1(void)
- time1=TH0*256+TL0;
- TH0=0x00;
- TL0=0x00;
- S1=time1*1.87/100; // 11.0592M晶振
- if(flag==1) //超出測(cè)量
- flag=0;
- LCD_set_xy( 1, 5 );
- LCD_Write_number(13);
- LCD_Write_number(12);
- LCD_set_xy( 1, 6 );
- else
- disbuff[1]=S1%1000/100;
- disbuff[2]=S1%1000%100/10;
- disbuff[3]=S1%1000%100%10;
- LCD_Write_number(disbuff[1]);
- LCD_Write_number(disbuff[2]);
- LCD_Write_number(disbuff[3]);
- void Conut2(void)
- time2=TH0*256+TL0;
- TH0=0x00;
- TL0=0x00;
- S2=time2*1.87/100; // 11.0592M晶振
- flag=0;
- LCD_set_xy( 2, 5 );
- LCD_set_xy( 2, 6 );
- else
- disbuff[1]=S2%1000/100;
- disbuff[2]=S2%1000%100/10;
- disbuff[3]=S2%1000%100%10;
- void Conut4(void)
- time4=TH0*256+TL0;
- TH0=0x00;
- TL0=0x00;
- S4=time4*1.87/100; // 11.0592M晶振
- flag=0;
- else
- disbuff[1]=S4%1000/100;
- disbuff[2]=S4%1000%100/10;
- disbuff[3]=S4%1000%100%10;
- LCD_set_xy( 4, 5 );
- LCD_set_xy( 4, 6 );
- void Conut3(void)
- time3=TH0*256+TL0;
- TH0=0x00;
- TL0=0x00;
- S3=time3*1.87/100; // 11.0592M晶振
- flag=0;
- LCD_set_xy( 3, 5 );
- LCD_set_xy( 3, 6 );
- else
- disbuff[1]=S3%1000/100;
- disbuff[2]=S3%1000%100/10;
- disbuff[3]=S3%1000%100%10;
- void delay20us(void) //誤差 -0.016637731481us
- unsigned char a,b;
- for(b=1;b>0;b--)
- for(a=52;a>0;a--);
- //if Keil,require use intrins.h
- void Delay5ms() //@11.0592MHz
- unsigned char i, j;
- i = 54;
- j = 199;
- do
- while (--j);
- } while (--i);
- void Delay50ms() //@11.0592MHz
- unsigned char i, j, k;
- i = 3;
- j = 26;
- k = 223;
- do
- do
- while (--k);
- } while (--j);
- } while (--i);
- void Delay300ms() //@11.0592MHz
- i = 13;
- j = 156;
- k = 83;
- do
- do
- while (--k);
- } while (--j);
- } while (--i);
- void zd0() interrupt 1 //T0中斷用來(lái)計(jì)數(shù)器溢出,超過(guò)測(cè)距范圍
- flag=1; //中斷溢出標(biāo)志
- void StartModule1() //超聲波觸發(fā)函數(shù)
- { Trig1=0;
- delay20us();
- Trig1=1;
- delay20us(); //發(fā)射一個(gè)大于10us的脈沖,觸發(fā)超聲波發(fā)射
- Trig1=0;
- void StartModule2() //超聲波觸發(fā)函數(shù)
- { Trig2=0;
- delay20us();
- Trig2=1;
- Trig2=0;
- void StartModule3() //超聲波觸發(fā)函數(shù)
- { Trig3=0;
- delay20us();
- Trig3=1;
- Trig3=0;
- void StartModule4() //超聲波觸發(fā)函數(shù)
- { Trig4=0;
- delay20us();
- Trig4=1;
- Trig4=0;
- void main(void)
- TMOD=0x01; //設(shè)T0為方式1
- TH0=0x00;
- TL0=0x00;
- TR0=1;
- ET0=1; //允許T0中斷
- EA=1; //開啟總中斷
- Lcd_init(); //設(shè)置液晶顯示器
- Clr_Scr(); //清屏
- …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
多路超聲波測(cè)試.zip
(257.93 KB, 下載次數(shù): 88)
2017-5-12 17:18 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
評(píng)分
查看全部評(píng)分
