查看: 3153|回復(fù): 4
麻煩各位大神幫忙看看 矩陣鍵盤在1602上不顯示
ID:198338 發(fā)表于 2017-5-10 20:12 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#include<intrins.h>
#include<math.h>
sbit rs=P3^5;
sbit rw=P3^6;
sbit lcden=P3^7;
void Delay100ms()                //@11.0592MHz
        unsigned char i, j;
        i = 180;
        j = 73;
        do
                while (--j);
        } while (--i);
void Delay10ms()                //@11.0592MHz
        unsigned char i, j;
        i = 18;
        j = 235;
        do
                while (--j);
        } while (--i);
void write_com(uchar com)        //寫命令
rs=0;
rw=0;
lcden=0;
P0=com;
Delay100ms();
lcden=1;
Delay100ms();
lcden=0;
void write_date(uchar date)        //寫數(shù)據(jù)
rs=1;
rw=0;
lcden=0;
P0=date;
Delay100ms();
lcden=1;
Delay100ms();
lcden=0;
void init()        //初始化函數(shù)
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);
void keyscan()
  uchar temp,key;
  P3=0xfe;
  temp=P3;
  temp=temp&0xf0;
  if(temp!=0xf0)
   Delay10ms();
   temp=P3;
   temp=temp&0xf0;
   if(temp!=0xf0)
    temp=P3;
        switch(temp)
         case 0xee:key=0;break;
         case 0xde:key=1;break;
         case 0xbe:key=2;break;
         case 0x7e:key=3;break;
        while(temp!=0xf0)
         temp=P3;
         temp=temp&0xf0;
        write_com(0x80+0x40+4);
  P3=0xfd;
  temp=P3;
  temp=temp&0xf0;
  if(temp!=0xf0)
   Delay10ms();
   temp=P3;
   temp=temp&0xf0;
   if(temp!=0xf0)
    temp=P3;
        switch(temp)
         case 0xed:key=4;break;
         case 0xdd:key=5;break;
         case 0xbd:key=6;break;
         case 0x7d:key=7;break;
        while(temp!=0xf0)
         temp=P3;
         temp=temp&0xf0;
P3=0xfb;
  temp=P3;
  temp=temp&0xf0;
  if(temp!=0xf0)
   Delay10ms();
   temp=P3;
   temp=temp&0xf0;
   if(temp!=0xf0)
    temp=P3;
        switch(temp)
         case 0xeb:key=8;break;
         case 0xdb:key=9;break;
         case 0xbb:key=10;break;
         case 0x7b:key=11;break;
        while(temp!=0xf0)
         temp=P3;
         temp=temp&0xf0;
P3=0xf7;
  temp=P3;
  temp=temp&0xf0;
  if(temp!=0xf0)
   Delay10ms();
   temp=P3;
   temp=temp&0xf0;
   if(temp!=0xf0)
    temp=P3;
        switch(temp)
         case 0xe7:key=12;break;
         case 0xd7:key=13;break;
         case 0xb7:key=14;break;
         case 0x77:key=15;break;
        while(temp!=0xf0)
         temp=P3;
         temp=temp&0xf0;
void main()        //主函數(shù)
  init();
   keyscan();
ID:149451 發(fā)表于 2017-5-11 08:43 | 顯示全部樓層
初步看,鍵盤掃描里最終執(zhí)行的僅有向LCD寫命令的函數(shù),沒有寫數(shù)據(jù)的函數(shù);另P3口與LCD控制端共用也存疑問,需考慮合適否。
評(píng)分
參與人數(shù) 1黑幣 +20 收起 理由
admin + 20 回帖助人的獎(jiǎng)勵(lì)!
查看全部評(píng)分
ID:198338 發(fā)表于 2017-5-11 15:47 | 顯示全部樓層
w1179benp 發(fā)表于 2017-5-11 08:43
初步看,鍵盤掃描里最終執(zhí)行的僅有向LCD寫命令的函數(shù),沒有寫數(shù)據(jù)的函數(shù);另P3口與LCD控制端共用也存疑問, ...
能幫忙改下嗎
ID:111634 發(fā)表于 2017-5-11 18:35 | 顯示全部樓層
本帖最后由 zl2168 于 2017-5-11 19:13 編輯
需先解決2個(gè)問題:鍵掃描和1602顯示
實(shí)例62 4×4矩陣式鍵盤
實(shí)例67  LCD1602顯示屏顯示
先Proteus仿真一下,確認(rèn)有效。
實(shí)例61 LCD1602顯示屏顯示.rar (49.26 KB, 下載次數(shù): 9)
實(shí)例62 4×4矩陣式鍵盤.rar (44.79 KB, 下載次數(shù): 5)
以上摘自張志良編著《80C51單片機(jī)仿真設(shè)計(jì)實(shí)例教程——基于Keil C和Proteus》清華大學(xué)出版社ISBN 978-7-302-41682-1,內(nèi)有常用的單片機(jī)應(yīng)用100案例,用于仿真實(shí)驗(yàn)操作,電路與程序真實(shí)可靠可信可行。書中電路和程序設(shè)計(jì)有詳細(xì)說明,程序語句條條有注解。
ID:381421 發(fā)表于 2018-11-1 21:23 | 顯示全部樓層
解決了嗎? 我也是矩陣鍵盤與1602拼在一起 不能顯示
