簡單的51練手,下面是proteus仿真原理圖:
單片機源程序:
- #include<reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit key1=P3^4;
- sbit key2=P3^5;
- sbit wei4=P2^0;
- sbit wei3=P2^1;
- uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77};
- void delayms(uint);
- uchar numt0,num,flat;
- void delayms(uint xms)
- uint i,j;
- for(i=xms;i>0;i--)
- for(j=110;j>0;j--);
- void display(uchar numdis)
- uchar shi,ge;
- shi=numdis/10;
- ge=numdis%10;
- wei4=1;
- wei3=1;
- P1=table[shi];
- wei4=1;
- wei3=0;
- delayms(5);
- wei4=1;
- wei3=1;
- P1=table[ge];
- wei4=0;
- wei3=1;
- delayms(5);
- void init()
- TMOD=0x01;
- TH0=(65536-45872)/256;
- TL0=(65536-45872)%256;
- EA=1;
- ET0=1;
- void keyscan()
- if(key1==0)
- delayms(10);
- if(key1==0)
- num++;
- flat++;
- if(num==99)
- num=0;
- while(!key1);
- if(key2==0);
- delayms(10);
- if(key2==0)
- if(num==0)
- num=99;
- flat=99;
- flat--;
- num--;
- while(!key2);
- void main()
- {init();
- while(1)
- keyscan();
- display(num);
- void T0_time() interrupt 1
- {TH0=(65536-45872)/256;
- numt0++;
- if(numt0==20)
- {numt0=0;
- num++;
- if(num==60)
- num=0;
下載:
按鍵控制數碼管顯示.rar
(55.45 KB, 下載次數: 25)
2017-5-8 20:47 上傳
