求指導(dǎo),我用你的代碼運行一個不一樣的東西,結(jié)果很失望
import java.util.Random;
public class BpDeep{
public double[][] layer;//神經(jīng)網(wǎng)絡(luò)各層節(jié)點
public double[][] layerErr;//神經(jīng)網(wǎng)絡(luò)各節(jié)點誤差
public double[][][] layer_weight;//各層節(jié)點權(quán)重
public double[][][] layer_weight_delta;//各層節(jié)點權(quán)重動量
public double mobp;//動量系數(shù)
public double rate;//學(xué)習(xí)系數(shù)
public BpDeep(int[] layernum, double rate, double mobp){
this.mobp = mobp;
this.rate = rate;
layer = new double[layernum.length][];
layerErr = new double[layernum.length][];
layer_weight = new double[layernum.length][][];
layer_weight_delta = new double[layernum.length][][];
Random random = new Random();
for(int l=0;l<layernum.length;l++){
layer[l]=new double[layernum[l]];
layerErr[l]=new double[layernum[l]];
if(l+1<layernum.length){
layer_weight[l]=new double[layernum[l]+1][layernum[l+1]];
layer_weight_delta[l]=new double[layernum[l]+1][layernum[l+1]];
for(int j=0;j<layernum[l]+1;j++)
for(int i=0;i<layernum[l+1];i++)
layer_weight[l][j][i]=random.nextDouble();//隨機(jī)初始化權(quán)重
//逐層向前計算輸出
public double[] computeOut(double[] in){
for(int l=1;l<layer.length;l++){
for(int j=0;j<layer[l].length;j++){
double z=layer_weight[l-1][layer[l-1].length][j];
for(int i=0;i<layer[l-1].length;i++){
layer[l-1][i]=l==1?in[i]:layer[l-1][i];
z+=layer_weight[l-1][i][j]*layer[l-1][i];
layer[l][j]=1/(1+Math.exp(-z));
return layer[layer.length-1];
//逐層反向計算誤差并修改權(quán)重
public void updateWeight(double[] tar){
int l=layer.length-1;
for(int j=0;j<layerErr[l].length;j++)
layerErr[l][j]=layer[l][j]*(1-layer[l][j])*(tar[j]-layer[l][j]);
while(l-->0){
for(int j=0;j<layerErr[l].length;j++){
double z = 0.0;
for(int i=0;i<layerErr[l+1].length;i++){
z=z+l>0?layerErr[l+1][i]*layer_weight[l][j][i]:0;
layer_weight_delta[l][j][i]= mobp*layer_weight_delta[l][j][i]+rate*layerErr[l+1][i]*layer[l][j];//隱含層動量調(diào)整
layer_weight[l][j][i]+=layer_weight_delta[l][j][i];//隱含層權(quán)重調(diào)整
if(j==layerErr[l].length-1){
layer_weight_delta[l][j+1][i]= mobp*layer_weight_delta[l][j+1][i]+rate*layerErr[l+1][i];//截距動量調(diào)整
layer_weight[l][j+1][i]+=layer_weight_delta[l][j+1][i];//截距權(quán)重調(diào)整
layerErr[l][j]=z*layer[l][j]*(1-layer[l][j]);//記錄誤差
public void train(double[] in, double[] tar){
double[] out = computeOut(in);
updateWeight(tar);
import java.util.Arrays;
public class MyBPtest1{
public static void main(String[] args){
//初始化神經(jīng)網(wǎng)絡(luò)的基本配置
//第一個參數(shù)是一個整型數(shù)組,表示神經(jīng)網(wǎng)絡(luò)的層數(shù)和每層節(jié)點數(shù),比如{3,10,10,10,10,2}表示輸入層是3個節(jié)點,輸出層是2個節(jié)點,中間有4層隱含層,每層10個節(jié)點
/////////第二個參數(shù)是學(xué)習(xí)步長(過小會使收斂速度太慢;過大則會使預(yù)測不準(zhǔn),跳過一些細(xì)節(jié)),
/////////第三個參數(shù)是動量系數(shù)(使波動小的預(yù)測重新振蕩起來)
BpDeep bp = new BpDeep(new int[]{5,5,1}, 0.15, 0.9);
////////對于輸入樣本如果只有一個數(shù)。沒關(guān)系,大不了{(lán),}第二項里的data和target全為0,,,,!!!!這理解是錯誤
////////因為我們設(shè)定了輸入層為2,才會有兩個輸入({,},{,}}這樣的東西;同理輸入層也為如此
////////所以說如果是5個輸入,一個輸出對于data就{{,,,,},{,,,,}。。。。。。};;;;;對于target{,,,,}
double[][] data = new double[][]{{192,195,194,193,193},
{195,194,193,193,195},{194,193,193,195,201},
{193,193,195,201,205},{193,195,201,205,205},
{195,201,205,205,203},{201,205,205,203,203},
{205,205,203,203,202},{205,203,203,202,206},
{203,203,202,206,204},{203,202,206,204,204},
{202,206,204,204,203},{206,204,204,203,199},
{204,204,203,199,195},{204,203,199,195,182},
{203,199,195,182,179},{199,195,182,179,178},
{195,182,179,178,176},{182,179,178,176,175},
{179,178,176,175,173},{178,176,175,173,175},
{176,175,173,175,182},{175,173,175,182,183},
{173,175,182,183,185},{175,182,183,185,179}};
//設(shè)置目標(biāo)數(shù)據(jù),對應(yīng)4個坐標(biāo)數(shù)據(jù)的分類
double[][] target = new double[][]{{195},{201},{205},{205},{203},
{203},{202},{206},{204},{204},{203},{199},{195},{182},{179},
{178},{176},{175},{173},{175},{182},{183},{185},{179},{182}};
//迭代訓(xùn)練5000次
///////這里我們沒有設(shè)置訓(xùn)練到了某一精確度自動停止,而是實打?qū)嵉挠?xùn)練這些次數(shù)
for(int n=0;n<5000;n++)
for(int i=0;i<data.length;i++)
bp.train(data[i], target[i]);
//根據(jù)訓(xùn)練結(jié)果來檢驗樣本數(shù)據(jù)
for(int j=0;j<data.length;j++){
double[] result = bp.computeOut(data[j]);
System.out.println(Arrays.toString(data[j])+":"+Arrays.toString(result));
//根據(jù)訓(xùn)練結(jié)果來預(yù)測一條新數(shù)據(jù)的分類
double[] x = new double[]{192,195,194,193,193};
double[] result = bp.computeOut(x);
System.out.println(Arrays.toString(x)+":"+Arrays.toString(result));
