PIC的OLED屏資料不好找才下的,里面是51內(nèi)核的,文件夾寫的是PIC,打開里面是51的!//******************************************************************************/ #include "reg52.h" #include<intrins.h> #define high 1 #define low 0 /*************Pin Define***************/ sbit RES=P1^2; sbit DC=P1^3; sbit SCL=P1^0; sbit SDA=P1^1; /****************************************************/ void Initial_LY096BG30(); void Delay_50ms(unsigned int Del_50ms); void Delay_1ms(unsigned int Del_1ms); void fill_picture(unsigned char fill_Data); void Picture_1(); void Write_SPI_Command(unsigned char ucCmd); void Write_SPI_Data(unsigned char ucData); /***********************Initial code*********************/ void Initial_LY096BG30() { |
