最近在搞DIY小玩意 用到了lcd1602液晶顯示 最后調試成功,希望對有需要的人有所幫助!
1602液晶驅動程序的主要部分:
- #include "lcd1602.h"
- #include "delay.h"
- #include "stdio.h"
- void GPIO_Configuration(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB | RCC_AHB1Periph_GPIOD,ENABLE);//使能PB,PD端口時鐘
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; //普通輸出模式
- GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽輸出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度為50MHz
- GPIO_Init(GPIOD, &GPIO_InitStructure); //初始化GPIOD0~7
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2;
- GPIO_Init(GPIOB, &GPIO_InitStructure); //初始化GPIB15,14,13
- /* 等待液晶準備好 */
- void LCD1602_Wait_Ready(void)
- u8 sta;
- DATAOUT(0xff);
- LCD_RS_Clr();
- LCD_RW_Set();
- do
- LCD_EN_Set();
- delay_ms(5); //延時5ms,非常重要
- sta = GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_7);//讀取狀態字
- LCD_EN_Clr();
- }while(sta & 0x80);//bit7等于1表示液晶正忙,重復檢測直到其等于0為止
- /* 向LCD1602液晶寫入一字節命令,cmd-待寫入命令值 */
- void LCD1602_Write_Cmd(u8 cmd)
- LCD1602_Wait_Ready();
- LCD_RS_Clr();
- LCD_RW_Clr();
- DATAOUT(cmd);
- LCD_EN_Set();
- LCD_EN_Clr();
- //printf("%d",cmd);
- /* 向LCD1602液晶寫入一字節數據,dat-待寫入數據值 */
- void LCD1602_Write_Dat(u8 dat)
- LCD_RS_Set();
- LCD_RW_Clr();
- DATAOUT(dat);
- LCD_EN_Set();
- LCD_EN_Clr();
- /* 清屏 */
- void LCD1602_ClearScreen(void)
- LCD1602_Write_Cmd(0x01);
- /* 設置顯示RAM起始地址,亦即光標位置,(x,y)-對應屏幕上的字符坐標 */
- void LCD1602_Set_Cursor(u8 x, u8 y)
- u8 addr;
- if (y == 0)
- addr = 0x00 + x;
- else
- addr = 0x40 + x;
- LCD1602_Write_Cmd(addr | 0x80);
- /* 在液晶上顯示字符串,(x,y)-對應屏幕上的起始坐標,str-字符串指針 */
- void LCD1602_Show_Str(u8 x, u8 y, u8 *str)
- LCD1602_Set_Cursor(x, y);
- while(*str != '\0')
- LCD1602_Write_Dat(*str++);
- /* 初始化1602液晶 */
- void LCD1602_Init(void)
- GPIO_Configuration();
- LCD1602_Write_Cmd(0x38); //16*2顯示,5*7點陣,8位數據口
- LCD1602_Write_Cmd(0x0c); //開顯示,光標關閉
- LCD1602_Write_Cmd(0x06); //文字不動,地址自動+1
- LCD1602_Write_Cmd(0x01); //清屏
- // LCD1602_Write_Cmd(0X02);
- // LCD1602_Write_Cmd(0X06);
- // LCD1602_Write_Cmd(0X00);
- // LCD1602_Write_Cmd(0X0C);
- // LCD1602_Write_Cmd(0X38);
- // LCD1602_Write_Cmd(0x01);
下載:
lcd1602顯示.7z
(294.08 KB, 下載次數: 1492)
2022-3-31 15:53 上傳
