DS18B20溫度傳感器的protues模擬
#include<reg52.h>
#include<intrins.h>
sbit wela = P2^0;
sbit dula = P2^1;
sbit IO_18B20 = P2^2; //DS18B20通信引腳
uint temp;
uchar code table[]={0x3f,0x06,0x05b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delay(uint ms) // ms延時(shí)函數(shù) (AT89C51 @ 11.0592MHz)
unsigned int i;
unsigned char j;
for(i=0;i<ms;i++)
for(j=0;j<200;j++);
for(j=0;j<102;j++);
/* 軟件延時(shí)函數(shù),延時(shí)時(shí)間(t*10)us */
void DelayX10us(unsigned char t)
do {
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
} while (--t);
bit Get18B20Ack()
bit ack;
EA = 0;
IO_18B20 = 0;
DelayX10us(50);
IO_18B20 = 1;
DelayX10us(6);
ack = IO_18B20;
while(!IO_18B20);
DelayX10us(6);
EA = 1;
return ack;
void Write18B20(unsigned char dat)
unsigned char mask;
EA = 0;
for(mask=0x01; mask!= 0; mask<<=1)
IO_18B20 = 0;
_nop_();
_nop_();
//_nop_();
if((mask&dat) == 0)
IO_18B20 = 0;
IO_18B20 = 1;
DelayX10us(6);
IO_18B20 = 1;
_nop_();
_nop_();
_nop_();
EA = 1;
unsigned char Read18B20()
unsigned char dat;
unsigned char mask;
EA = 0;
for(mask=0x01; mask!=0; mask<<=1)
IO_18B20 = 0;
_nop_();
_nop_();
//_nop_();
IO_18B20 = 1;
_nop_();
_nop_();
_nop_();
if(!IO_18B20)
dat &= ~mask;
dat |= mask;
DelayX10us(6);
EA = 1;
return dat;
bit Start18B20()
bit ack;
ack = Get18B20Ack();
if(ack == 0)
Write18B20(0xCC);
Write18B20(0x44);
return ~ack;
bit Get18B20Temp(uint *temp)
bit ack;
unsigned char LSB, MSB;
if(ack == 0)
Write18B20(0xCC);
Write18B20(0xBE);
LSB = Read18B20();
MSB = Read18B20();
*temp = ((int)MSB<<8) + LSB;
return ~ack;
void display(uint num)
uchar i;
for(i=0;i<6;i++)
//位選
P0 = ~(0x1<<i);
wela = 1;
wela = 0;
//段選
P0 = table[num%10];
dula = 1;
dula = 0;
num=num/10;
//去除前面為0的位
if(num==0)
i=6;
delay(3);
uint tmp;
if(Start18B20())
if(Get18B20Temp(&temp))
tmp=temp;
tmp=tmp>>4;
tmp=tmp&0xFF;
display(tmp);
