- /*預處理命令*/
- #include<reg52.h> //包含單片機寄存器的頭文件
- #include<intrins.h> //包含_nop_()函數(shù)定義的頭文件
- #define uchar unsigned char
- #define uint unsigned int
- #define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
- sbit IRIN=P3^2; //紅外接收器數(shù)據(jù)線
- sbit P2_0 = P2^0;
- sbit P2_1 = P2^1;
- sbit P2_2 = P2^2;
- sbit P2_3 = P2^3;
- uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,
- 0xf8,0x80,0x90};
- uchar IRCOM[7];
- uchar m;
- void delay1ms();
- void delay(unsigned char x) ;
- void display();
- void delay1(int ms);
- void main()
- unsigned int a;
- IRIN=1; //I/O口初始化
- IE=0x81; //允許總中斷中斷,使能 INT0 外部中斷
- TCON=TCON|0x01; //觸發(fā)方式為脈沖負邊沿觸發(fā)
- while(1)
- for(a=100;a>0;a--)
- display();
- void IR_IN() interrupt 0 using 0
- unsigned char j,k,N=0;
- unsigned char q=0;
- EX0 = 0;
- delay(15);
- if (IRIN==1)
- EX0 =1;
- return;
- //確認IR信號出現(xiàn)
- while (!IRIN) //等IR變?yōu)楦唠娖,跳過9ms的前導低電平信號。
- delay(1);
- for (j=0;j<4;j++) //收集四組數(shù)據(jù)
- for (k=0;k<8;k++) //每組數(shù)據(jù)有8位
- while (IRIN) //等 IR 變?yōu)榈碗娖剑^4.5ms的前導高電平信號。
- {delay(1);}
- while (!IRIN) //等 IR 變?yōu)楦唠娖?br />
- delay(1);
- while (IRIN) //計算IR高電平時長
- delay(1);
- N++;
- if (N>=30)
- EX0=1;
- return;
- } //0.14ms計數(shù)過長自動離開。
- } //高電平計數(shù)完畢
- IRCOM[j]=IRCOM[j] >> 1; //數(shù)據(jù)最高位補“0”
- if(N>=8)
- IRCOM[j] = IRCOM[j] | 0x80; //數(shù)據(jù)最高位補“1”
- N=0;
- if(IRCOM[2]!=~IRCOM[3])
- EX0=1;
- return;
- IRCOM[5]=IRCOM[2] & 0x0F; //取鍵碼的低四位
- IRCOM[6]=IRCOM[2] >> 4; //右移4次,高四位變?yōu)榈退奈?br />
- if(IRCOM[5]>9)
- IRCOM[5]=IRCOM[5]+0x37;
- else
- IRCOM[5]=IRCOM[5]+0x30;
- if(IRCOM[6]>9)
- IRCOM[6]=IRCOM[6]+0x37;
- else
- IRCOM[6]=IRCOM[6]+0x30;
- q= (((IRCOM[6]&0x0f)<<4) + (IRCOM[5]&0x0f));
- switch(q) //判斷按鍵鍵碼值
- case 0x16:m=0;break; //串口發(fā)送0
- case 0x03:m=1;break; //串口發(fā)送01
- case 0x18:m=2;break; //串口發(fā)送02
- case 0x55:m=3;break; //串口發(fā)送03
- case 0x08:m=4;break; //串口發(fā)送04
- case 0x13:m=5;break; //串口發(fā)送05
- case 0x51:m=6;break; //串口發(fā)送06
- case 0x42:m=7;break; //串口發(fā)送07
- case 0x52:m=8;break; //串口發(fā)送08
- case 0x41:m=9;break; //串口發(fā)送09
- default :break;
- EX0 = 1;
- /***************延時函數(shù)*****************************/
- void delay(unsigned char x) //x*0.14MS
- unsigned char i;
- while(x--)
- for (i = 0; i<13; i++) {}
- void display()
- P0=table[m];
- P2_3 = 0;
- delay(5);
- P2_3 = 1;
- unsigned char y;
- while(ms--)
- for(y = 0; y<250; y++)
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- void delay1ms()
- unsigned int i;
- for(i=8024;i>0;i--); //延時124*8+10=1002us
