基于proteus的16*16LED點陣屏的仿真
含有proteus的原理圖
keil c的源程序
8*8點陣屏是通過分解重新封裝的
可以實現滾動顯示
16×16點陣(滾動顯示)仿真原理圖:
單片機源程序:
- #include <reg52.h>
- #define int8 unsigned char
- #define int16 unsigned int
- #define int32 unsigned long
- int8 flag;
- int8 n;
- int8 code table[][32]={
- {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/* " " */
- {0x04,0x28,0x08,0x24,0x32,0x22,0xC2,0x21,0xC2,0x26,0x34,0x38,0x04,0x04,0x08,0x18,0x30,0xF0,0xC0,0x17,0x60,0x10,0x18,0x10,0x0C,0x14,0x06,0x18,0x04,0x10,0x00,0x00},/*"歡",0*/
- {0x02,0x02,0x04,0x82,0xF8,0x73,0x04,0x20,0x02,0x00,0xE2,0x3F,0x42,0x20,0x82,0x40,0x02,0x40,0xFA,0x3F,0x02,0x20,0x42,0x20,0x22,0x20,0xC2,0x3F,0x02,0x00,0x00,0x00},/*"迎",1*/
- {0x00,0x01,0x04,0x02,0x1C,0x0C,0xC0,0x3F,0x1C,0xC0,0x02,0x09,0x02,0x16,0x92,0x60,0x4A,0x20,0x82,0x2F,0x02,0x20,0x0E,0x24,0x00,0x22,0x90,0x31,0x0C,0x20,0x00,0x00},/*"您",2*/
- {0x44,0x10,0x44,0x14,0x88,0x54,0x88,0x54,0xD0,0x5F,0x30,0x50,0x60,0x50,0xFE,0x7F,0x40,0x50,0x20,0x90,0xB0,0x9F,0x98,0x92,0x8C,0x94,0x88,0x34,0x80,0x11,0x00,0x00},/*"乘",3*/
- {0x82,0x00,0x02,0x01,0x22,0x06,0x22,0x38,0x22,0x04,0x22,0x03,0x22,0x00,0xFE,0xFF,0xA2,0x00,0x22,0x01,0x22,0x02,0x22,0x3C,0x22,0x02,0x02,0x01,0x02,0x00,0x00,0x00},/*"坐",4*/
- {0x02,0x00,0x0C,0x00,0xF0,0x3F,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0xA0,0x00,0x60,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x00},/*"廣",5*/
- {0x80,0x00,0x01,0x07,0x06,0x00,0x18,0x00,0xE0,0xFF,0x00,0x04,0x00,0x03,0x00,0x00,0xFE,0x7F,0x00,0x08,0x00,0x06,0x80,0x01,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00},/*"州",6*/
- {0x00,0x00,0x04,0x20,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x21,0x04,0x20,0x04,0x00,0x00,0x00},/*"三",7*/
- {0x20,0x08,0x20,0x86,0x7F,0x60,0x80,0x0F,0x00,0x04,0x00,0x1A,0x00,0xEA,0x00,0x2A,0x00,0x2A,0x00,0x2A,0x00,0x2A,0xF0,0x2B,0x0C,0x28,0x02,0x20,0x0F,0x00,0x00,0x00},/*"汽",8*/
- {0x00,0x00,0x80,0x00,0x04,0x01,0x0E,0x02,0x14,0x0C,0x24,0x70,0xC4,0x21,0x8C,0x00,0x08,0x00,0x08,0x70,0x28,0x08,0x1E,0x06,0x0C,0x03,0x80,0x01,0x00,0x01,0x00,0x00},/*"公",9*/
- {0x00,0x00,0x00,0x08,0xF8,0x49,0x20,0x49,0x20,0x49,0x20,0x49,0x20,0x49,0x20,0x49,0x20,0x49,0xF0,0x49,0x00,0x48,0x04,0x40,0x02,0x40,0xFC,0x7F,0x00,0x00,0x00,0x00},/*"司",10*/
- {0x00,0x00,0x80,0x00,0x04,0x01,0x0E,0x02,0x14,0x0C,0x24,0x70,0xC4,0x21,0x8C,0x00,0x08,0x00,0x08,0x70,0x28,0x08,0x1E,0x06,0x0C,0x03,0x80,0x01,0x00,0x01,0x00,0x00},/*"公",11*/
- {0x40,0x00,0x40,0x08,0x41,0x08,0x42,0x08,0x4C,0x08,0xF8,0x7F,0x50,0x08,0x40,0x08,0x40,0x08,0x60,0x08,0xD0,0x7F,0x4C,0x08,0x47,0x08,0x42,0x08,0x40,0x00,0x00,0x00},/*"共",12*/
- {0x20,0x08,0x20,0x86,0x7F,0x60,0x80,0x0F,0x00,0x04,0x00,0x1A,0x00,0xEA,0x00,0x2A,0x00,0x2A,0x00,0x2A,0x00,0x2A,0xF0,0x2B,0x0C,0x28,0x02,0x20,0x0F,0x00,0x00,0x00},/*"汽",13*/
- {0x20,0x00,0x20,0x20,0x20,0x21,0x20,0x23,0x20,0x25,0x20,0x39,0x20,0xE1,0x20,0x21,0xFF,0x2F,0x20,0x21,0x20,0x21,0x20,0x21,0x20,0x21,0x20,0x21,0x20,0x00,0x00,0x00},/*"車",14*/
- {0x00,0x00,0x00,0x00,0x1A,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*",",15*/
- {0x00,0x04,0x01,0x04,0x02,0x04,0x04,0x04,0x08,0x04,0x30,0x04,0xC0,0x05,0x00,0xFE,0x80,0x05,0x60,0x04,0x10,0x04,0x0C,0x04,0x06,0x04,0x03,0x04,0x02,0x04,0x00,0x00},/*"大",16*/
- {0x00,0x02,0x40,0x0C,0x40,0x08,0x40,0x48,0x40,0x3A,0x40,0x2A,0x42,0x0A,0x41,0x8A,0xFE,0x7A,0x40,0x2B,0x40,0x0A,0x40,0x18,0x40,0xEA,0x40,0x4C,0x40,0x08,0x00,0x00},/*"學",17*/
- {0x20,0x08,0x30,0x08,0xE0,0xFF,0x42,0x08,0x4C,0x08,0xF0,0x1F,0x10,0x12,0x1A,0x12,0xF2,0x13,0x04,0x10,0xC8,0xFF,0x30,0x10,0xCC,0x50,0x02,0x37,0x1C,0x12,0x00,0x00},/*"城",18*/
- {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0C,0x0E,0x14,0x10,0x24,0x10,0x44,0x10,0x84,0x11,0x0C,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"2",0*/
- {0x04,0x02,0x44,0x06,0xC4,0x1A,0x48,0xE3,0x48,0x46,0x48,0x00,0x04,0x09,0x04,0x09,0x08,0x09,0xC8,0xFF,0x30,0x09,0x28,0x49,0x44,0x39,0x02,0x29,0x1F,0x01,0x00,0x00},/*"線",19*/
- {0x00,0x02,0x02,0x42,0x04,0x42,0x08,0x42,0x30,0x42,0xC0,0x7F,0x00,0x42,0x00,0x42,0x00,0x42,0x00,0x42,0xFE,0x7F,0x00,0x42,0x00,0x42,0x00,0x42,0x00,0x42,0x00,0x00},/*"開",20*/
- {0x40,0x04,0x80,0x08,0x00,0x11,0xFF,0xEF,0x00,0x44,0x02,0x10,0x82,0x10,0x82,0x10,0x82,0x90,0xFE,0x7F,0x82,0x50,0x82,0x10,0x82,0x10,0x82,0x10,0x02,0x10,0x00,0x00},/*"往",21*/
- {0x00,0x04,0x01,0x04,0x02,0x04,0x04,0x04,0x08,0x04,0x30,0x04,0xC0,0x05,0x00,0xFE,0x80,0x05,0x60,0x04,0x10,0x04,0x0C,0x04,0x06,0x04,0x03,0x04,0x02,0x04,0x00,0x00},/*"大",22*/
- {0x00,0x02,0x40,0x0C,0x40,0x08,0x40,0x48,0x40,0x3A,0x40,0x2A,0x42,0x0A,0x41,0x8A,0xFE,0x7A,0x40,0x2B,0x40,0x0A,0x40,0x18,0x40,0xEA,0x40,0x4C,0x40,0x08,0x00,0x00},/*"學",23*/
- {0x20,0x08,0x30,0x08,0xE0,0xFF,0x42,0x08,0x4C,0x08,0xF0,0x1F,0x10,0x12,0x1A,0x12,0xF2,0x13,0x04,0x10,0xC8,0xFF,0x30,0x10,0xCC,0x50,0x02,0x37,0x1C,0x12,0x00,0x00},/*"城",24*/
- {0x00,0x00,0x00,0x00,0x1A,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*",",25*/
- {0x00,0x02,0x00,0x42,0x00,0x32,0xFE,0x23,0x04,0x00,0x08,0x44,0xFF,0x55,0x50,0x55,0x50,0x55,0x50,0xFD,0x52,0x55,0x51,0x55,0xFE,0x55,0x00,0x44,0x00,0x04,0x00,0x00},/*"請",26*/
- {0x00,0x01,0x04,0x02,0x1C,0x0C,0xC0,0x3F,0x1C,0xC0,0x02,0x09,0x02,0x16,0x92,0x60,0x4A,0x20,0x82,0x2F,0x02,0x20,0x0E,0x24,0x00,0x22,0x90,0x31,0x0C,0x20,0x00,0x00},/*"您",27*/
- {0x82,0x00,0x02,0x01,0x22,0x06,0x22,0x38,0x22,0x04,0x22,0x03,0x22,0x00,0xFE,0xFF,0xA2,0x00,0x22,0x01,0x22,0x02,0x22,0x3C,0x22,0x02,0x02,0x01,0x02,0x00,0x00,0x00},/*"坐",28*/
- {0x01,0x08,0xC2,0x08,0x44,0x0F,0x28,0xF8,0x30,0x08,0xCE,0x0F,0x04,0x01,0x00,0x41,0x02,0x41,0x01,0x41,0xFE,0x4F,0x00,0x51,0x00,0x61,0x00,0x41,0x00,0x01,0x00,0x00},/*"好",29*/
- {0x42,0x08,0x81,0x08,0xFE,0xFF,0x00,0x09,0x01,0x0A,0x01,0x01,0x02,0x11,0x0C,0x11,0x30,0x11,0xC0,0xFF,0x30,0x11,0x08,0x11,0x06,0x11,0x03,0x11,0x02,0x01,0x00,0x00},/*"扶",30*/
- {0x20,0x08,0xC0,0x48,0x00,0x4B,0xFF,0x7F,0x00,0x89,0x9C,0x88,0x00,0x10,0xBC,0x2A,0x82,0xCA,0xC2,0x4A,0xB2,0x5A,0x82,0x6A,0xAE,0x0A,0x90,0x0F,0x0C,0x00,0x00,0x00},/*"穩",31*/
- {0x00,0x00,0x00,0x00,0x00,0x00,0xFA,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"!",32*/
- {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}/* " " */
- void delay(void);
- int16 offset;
- void main(void)
- int8 i;
- int8 *p;
- flag=0x10;
- n=0;
- TMOD=0x01;
- TH0=0xb1;
- TL0=0xe0;
- ET0=1;
- EA=1;
- TR0=1;
- p=&table[0][0];
- while (1)
- for (i=0;i<8;i++) //顯示左半邊屏幕
- P0=*(p+offset+2*i);
- P2=i|0x08; //P2.4=0,P2.3=1 選中U2, 輸出掃描碼給U6
- delay();
- P0=*(p+offset+2*i+1);
- P2=i|0x10; //P2.4=1,P2.3=0 選中U3, 輸出掃描碼給U7
- delay();
- for (i=8;i<16;i++) //顯示右半邊屏幕
- P2=(i-8)|0x20; //P2.5=1 P2.4=0, P2.3=0 選中U4,輸出掃描碼U8
- delay();
- P2=(i-8)|0x40; //P2.6=1 P2.5=0, P2.4=0 選中U5,輸出掃描碼U9
- delay();
下載:
16×16點陣(滾動顯示).zip
(88.42 KB, 下載次數: 81)
2017-4-11 15:38 上傳
壓縮文件
