藍牙智能手環要求收到消息或者建立連接后震動提示,分享代碼,共同學習~歡迎互相討論,改進技術.
2017-4-11 19:14 上傳
全部資料源代碼下載:
nrf51_ble_motor.rar
(5.66 MB, 下載次數: 50)
2017-4-11 09:50 上傳
連接震動 下載積分: 黑幣 -5
部分源碼預覽:
- /* Copyright (c) 2015 Nordic Semiconductor. All Rights Reserved.
- * The information contained herein is property of Nordic Semiconductor ASA.
- * Terms and conditions of usage are described in detail in NORDIC
- * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
- * Licensees are granted free, non-transferable use of the information. NO
- * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
- * the file.
- * @brief Blinky Sample Application main file.
- * This file contains the source code for a sample server application using the LED Button service.
- #include <stdint.h>
- #include <string.h>
- #include "nordic_common.h"
- #include "nrf.h"
- #include "app_error.h"
- #include "ble.h"
- #include "ble_hci.h"
- #include "ble_srv_common.h"
- #include "ble_advdata.h"
- #include "ble_conn_params.h"
- #include "softdevice_handler.h"
- #include "app_timer.h"
- #include "app_button.h"
- #include "ble_lbs.h"
- #include "bsp.h"
- #include "ble_gap.h"
- #define CENTRAL_LINK_COUNT 0 /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
- #define PERIPHERAL_LINK_COUNT 1 /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
- #define ADVERTISING_LED_PIN BSP_LED_0_MASK /**< Is on when device is advertising. */
- #define CONNECTED_LED_PIN BSP_LED_1_MASK /**< Is on when device has connected. */
- #define LEDBUTTON_LED_PIN BSP_LED_2_MASK /**< LED to be toggled with the help of the LED Button Service. */
- #define LEDBUTTON_BUTTON_PIN BSP_BUTTON_0 /**< Button that will trigger the notification event with the LED Button Service */
- #define DEVICE_NAME "Nordic_Blinky" /**< Name of device. Will be included in the advertising data. */
- #define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */
- #define APP_ADV_TIMEOUT_IN_SECONDS BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */
- #define APP_TIMER_PRESCALER 0 /**< Value of the RTC1 PRESCALER register. */
- #define APP_TIMER_MAX_TIMERS 6 /**< Maximum number of simultaneously created timers. */
- #define APP_TIMER_OP_QUEUE_SIZE 4 /**< Size of timer operation queues. */
- #define MIN_CONN_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.5 seconds). */
- #define MAX_CONN_INTERVAL MSEC_TO_UNITS(200, UNIT_1_25_MS) /**< Maximum acceptable connection interval (1 second). */
- #define SLAVE_LATENCY 0 /**< Slave latency. */
- #define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory time-out (4 seconds). */
- #define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(20000, APP_TIMER_PRESCALER) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
- #define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */
- #define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
- #define APP_GPIOTE_MAX_USERS 1 /**< Maximum number of users of the GPIOTE handler. */
- #define BUTTON_DETECTION_DELAY APP_TIMER_TICKS(50, APP_TIMER_PRESCALER) /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
- #define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
- static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
- static ble_lbs_t m_lbs; /**< LED Button Service instance. */
- /**@brief Function for assert macro callback.
- * @details This function will be called in case of an assert in the SoftDevice.
- * @warning This handler is an example only and does not fit a final product. You need to analyze
- * how your product is supposed to react in case of Assert.
- * @warning On assert from the SoftDevice, the system can only recover on reset.
- * @param[in] line_num Line number of the failing ASSERT call.
- * @param[in] p_file_name File name of the failing ASSERT call.
- void assert_nrf_callback(uint16_t line_num, const uint8_t * p_file_name)
- app_error_handler(DEAD_BEEF, line_num, p_file_name);
- /**@brief Function for the LEDs initialization.
- * @details Initializes all LEDs used by the application.
- static void leds_init(void)
- LEDS_CONFIGURE(ADVERTISING_LED_PIN | CONNECTED_LED_PIN | LEDBUTTON_LED_PIN);
- LEDS_ON(LEDBUTTON_LED_PIN);
- LEDS_OFF(ADVERTISING_LED_PIN | CONNECTED_LED_PIN );
- /**@brief Function for the Timer initialization.
- * @details Initializes the timer module.
- static void timers_init(void)
- // Initialize timer module, making it use the scheduler
- APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
- /**@brief Function for the GAP initialization.
- * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
- * device including the device name, appearance, and the preferred connection parameters.
- static void gap_params_init(void)
- uint32_t err_code;
- ble_gap_conn_params_t gap_conn_params;
- ble_gap_conn_sec_mode_t sec_mode;
- BLE_GAP_CONN_SEC_MODE_SET_OPEN(&sec_mode);
- err_code = sd_ble_gap_device_name_set(&sec_mode,
- (const uint8_t *)DEVICE_NAME,
- strlen(DEVICE_NAME));
- APP_ERROR_CHECK(err_code);
- memset(&gap_conn_params, 0, sizeof(gap_conn_params));
- gap_conn_params.min_conn_interval = MIN_CONN_INTERVAL;
- gap_conn_params.max_conn_interval = MAX_CONN_INTERVAL;
- gap_conn_params.slave_latency = SLAVE_LATENCY;
- gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
- err_code = sd_ble_gap_ppcp_set(&gap_conn_params);
- /**@brief Function for initializing the Advertising functionality.
- * @details Encodes the required advertising data and passes it to the stack.
- * Also builds a structure to be passed to the stack when starting advertising.
- static void advertising_init(void)
- ble_advdata_t advdata;
- ble_advdata_t scanrsp;
- ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
- // Build and set advertising data
- memset(&advdata, 0, sizeof(advdata));
- advdata.name_type = BLE_ADVDATA_FULL_NAME;
- advdata.include_appearance = true;
- advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
- memset(&scanrsp, 0, sizeof(scanrsp));
- scanrsp.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
- scanrsp.uuids_complete.p_uuids = adv_uuids;
- err_code = ble_advdata_set(&advdata, &scanrsp);
- /**@brief Function for handling write events to the LED characteristic.
- * @param[in] p_lbs Instance of LED Button Service to which the write applies.
- * @param[in] led_state Written/desired state of the LED.
- static void led_write_handler(ble_lbs_t * p_lbs, uint8_t led_state)
- if (led_state)
- LEDS_OFF(LEDBUTTON_LED_PIN);
- else
- /**@brief Function for initializing services that will be used by the application.
- static void services_init(void)
- ble_lbs_init_t init;
- init.led_write_handler = led_write_handler;
- err_code = ble_lbs_init(&m_lbs, &init);
- /**@brief Function for handling the Connection Parameters Module.
- * @details This function will be called for all events in the Connection Parameters Module that
- * are passed to the application.
- * @note All this function does is to disconnect. This could have been done by simply
- * setting the disconnect_on_fail config parameter, but instead we use the event
- * handler mechanism to demonstrate its use.
- * @param[in] p_evt Event received from the Connection Parameters Module.
- static void on_conn_params_evt(ble_conn_params_evt_t * p_evt)
- if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED)
- err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE);
- /**@brief Function for handling a Connection Parameters error.
- * @param[in] nrf_error Error code containing information about what went wrong.
- static void conn_params_error_handler(uint32_t nrf_error)
- APP_ERROR_HANDLER(nrf_error);
- /**@brief Function for initializing the Connection Parameters module.
- static void conn_params_init(void)
- ble_conn_params_init_t cp_init;
- memset(&cp_init, 0, sizeof(cp_init));
- cp_init.p_conn_params = NULL;
- cp_init.first_conn_params_update_delay = FIRST_CONN_PARAMS_UPDATE_DELAY;
- cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
- cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
- cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
- cp_init.disconnect_on_fail = false;
- cp_init.evt_handler = on_conn_params_evt;
- cp_init.error_handler = conn_params_error_handler;
- err_code = ble_conn_params_init(&cp_init);
- /**@brief Function for starting advertising.
- static void advertising_start(void)
- ble_gap_adv_params_t adv_params;
- // Start advertising
- memset(&adv_params, 0, sizeof(adv_params));
- adv_params.type = BLE_GAP_ADV_TYPE_ADV_IND;
- adv_params.p_peer_addr = NULL;
- adv_params.fp = BLE_GAP_ADV_FP_ANY;
- adv_params.interval = APP_ADV_INTERVAL;
- adv_params.timeout = APP_ADV_TIMEOUT_IN_SECONDS;
- err_code = sd_ble_gap_adv_start(&adv_params);
- LEDS_ON(ADVERTISING_LED_PIN);
- /**@brief Function for handling the Application's BLE stack events.
- * @param[in] p_ble_evt Bluetooth stack event.
- static void on_ble_evt(ble_evt_t * p_ble_evt)
- switch (p_ble_evt->header.evt_id)
- case BLE_GAP_EVT_CONNECTED:
- LEDS_ON(CONNECTED_LED_PIN);
- LEDS_OFF(ADVERTISING_LED_PIN);
- m_conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
- err_code = app_button_enable();
- break;
- case BLE_GAP_EVT_DISCONNECTED:
- LEDS_OFF(CONNECTED_LED_PIN);
- m_conn_handle = BLE_CONN_HANDLE_INVALID;
- err_code = app_button_disable();
- advertising_start();
- break;
- case BLE_GAP_EVT_SEC_PARAMS_REQUEST:
- // Pairing not supported
- err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
- BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
- NULL,
- NULL);
- break;
- case BLE_GATTS_EVT_SYS_ATTR_MISSING:
- // No system attributes have been stored.
- err_code = sd_ble_gatts_sys_attr_set(m_conn_handle, NULL, 0, 0);
- break;
- default:
- // No implementation needed.
- break;
- /**@brief Function for dispatching a BLE stack event to all modules with a BLE stack event handler.
- * @details This function is called from the scheduler in the main loop after a BLE stack
- * event has been received.
- static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
- on_ble_evt(p_ble_evt);
- ble_conn_params_on_ble_evt(p_ble_evt);
- ble_lbs_on_ble_evt(&m_lbs, p_ble_evt);
- /**@brief Function for initializing the BLE stack.
- * @details Initializes the SoftDevice and the BLE event interrupt.
- static void ble_stack_init(void)
- nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
- // Initialize the SoftDevice handler module.
- SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
- ble_enable_params_t ble_enable_params;
- err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
- PERIPHERAL_LINK_COUNT,
- &ble_enable_params);
- //Check the ram settings against the used number of links
- CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
- // Enable BLE stack.
- err_code = softdevice_enable(&ble_enable_params);
- ble_gap_addr_t addr;
- err_code = sd_ble_gap_address_get(&addr);
- err_code = sd_ble_gap_address_set(BLE_GAP_ADDR_CYCLE_MODE_NONE, &addr);
- // Subscribe for BLE events.
- err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
- /**@brief Function for handling events from the button handler module.
- * @param[in] pin_no The pin that the event applies to.
- * @param[in] button_action The button action (press/release).
- static void button_event_handler(uint8_t pin_no, uint8_t button_action)
- switch (pin_no)
- case LEDBUTTON_BUTTON_PIN:
- err_code = ble_lbs_on_button_change(&m_lbs, button_action);
- if (err_code != NRF_SUCCESS &&
- err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
- err_code != NRF_ERROR_INVALID_STATE)
- break;
- default:
- APP_ERROR_HANDLER(pin_no);
- break;
- /**@brief Function for initializing the button handler module.
- static void buttons_init(void)
- //The array must be static because a pointer to it will be saved in the button handler module.
- static app_button_cfg_t buttons[] =
- {LEDBUTTON_BUTTON_PIN, false, BUTTON_PULL, button_event_handler}
- err_code = app_button_init(buttons, sizeof(buttons) / sizeof(buttons[0]),
- BUTTON_DETECTION_DELAY);
- /**@brief Function for the Power Manager.
- static void power_manage(void)
- uint32_t err_code = sd_app_evt_wait();
- /**@brief Function for application main entry.
- int main(void)
- // Initialize.
- leds_init();
- timers_init();
- buttons_init();
- ble_stack_init();
- gap_params_init();
- services_init();
- advertising_init();
- conn_params_init();
- // Start execution.
- // Enter main loop.
- for (;;)
- power_manage();
