STM32F4開發源碼之I2S音頻播放,利用原子STM32F407開發板進行編寫。
完整源碼下載:
(10)I2S音頻播放.zip
(150.58 KB, 下載次數: 61)
2017-4-10 13:50 上傳
STM32F4開發源碼——I2S音頻播放
部分源程序預覽:
- #include "wavplayer.h"
- #include "cs4334.h"
- #include "lcd.h"
- #include "led.h"
- #include "ff.h"
- u16 buffer1[1024]={0x00};
- u16 buffer2[1024]={0x00};
- __IO u32 WaveLen=0;
- __IO u32 XferCplt=0;
- __IO u32 DataOffset=0;
- __IO u32 WaveCounter;
- u8 buffer_switch=1;
- WAVE_TypeDef WAVE_Format;
- void Wavplay(void)
- FATFS fatfs;
- FIL fileR;
- UINT BytesRead;
- u8 i=0;
- f_mount(0, &fatfs);
- f_open(&fileR, "0:/WAV/melody.wav" , FA_READ);
- f_read(&fileR, buffer1, 1024, &BytesRead);
- while(WaveParsing())LCD_String(20,50,"File read error!",RED);
- LCD_String(20,50,"0:/WAV/melody.wav",WHITE);
- WaveLen = WAVE_Format.DataSize;
- AUDIO_Init(WAVE_Format.SampleRate);
- f_lseek(&fileR, WaveCounter);//跳過文件頭
- f_read(&fileR, buffer2, 1024, &BytesRead);
- Audio_MAL_Play((u32)buffer1, 1024);
- buffer_switch=1;
- XferCplt=0;
- while(WaveLen!=0)
- while(XferCplt==0);//等待DMA傳送完成
- XferCplt=0;
- if(buffer_switch==0)
- Audio_MAL_Play((u32)buffer1,1024);//從buffer1播放
- f_read(&fileR,buffer2,1024,&BytesRead);//填充buffer2
- buffer_switch=1;
- else
- Audio_MAL_Play((u32)buffer2,1024);//從buffer2播放
- f_read(&fileR,buffer1,1024,&BytesRead);//填充buffer1
- buffer_switch=0;
- i++;
- if(i==100)
- LEDTog(LED1);
- i=0;
- u8 WaveParsing(void)
- u32 temp=0x00;
- u32 extraformatbytes=0;
- temp=ReadUnit((u8*)buffer1,0,4,BigEndian);//讀'RIFF'
- if(temp!=CHUNK_ID)return 1;
- WAVE_Format.RIFFchunksize=ReadUnit((u8*)buffer1,4,4,LittleEndian);//讀文件長度
- temp=ReadUnit((u8*)buffer1,8,4,BigEndian);//讀'WAVE'
- if(temp!=FILE_FORMAT)return 2;
- temp=ReadUnit((u8*)buffer1,12,4,BigEndian);//讀'fmt '
- if(temp!=FORMAT_ID)return 3;
- temp=ReadUnit((u8*)buffer1,16,4,LittleEndian);//讀'fmt'數據長度
- if(temp!=0x10)extraformatbytes=1;
- WAVE_Format.FormatTag=ReadUnit((u8*)buffer1,20,2,LittleEndian);//讀音頻格式
- if(WAVE_Format.FormatTag!=WAVE_FORMAT_PCM)return 4;
- WAVE_Format.NumChannels=ReadUnit((u8*)buffer1,22,2,LittleEndian);//讀聲道數
- WAVE_Format.SampleRate=ReadUnit((u8*)buffer1,24,4,LittleEndian);//讀采樣率
- WAVE_Format.ByteRate=ReadUnit((u8*)buffer1,28,4,LittleEndian);//讀波特率
- WAVE_Format.BlockAlign=ReadUnit((u8*)buffer1,32,2,LittleEndian);//讀塊對齊
- WAVE_Format.BitsPerSample=ReadUnit((u8*)buffer1,34,2,LittleEndian);//讀采樣點位數
- if(WAVE_Format.BitsPerSample!=BITS_PER_SAMPLE_16)return 5;
- DataOffset=36;
- if(extraformatbytes==1)
- temp=ReadUnit((u8*)buffer1,36,2,LittleEndian);//讀額外格式字節
- if(temp!=0x00)return 6;
- temp=ReadUnit((u8*)buffer1,38,4,BigEndian);//讀'fact'
- if(temp!=FACT_ID)return 7;
- temp=ReadUnit((u8*)buffer1,42,4,LittleEndian);//讀Fact數據大小
- DataOffset+=10+temp;
- temp=ReadUnit((u8*)buffer1,DataOffset,4,BigEndian);//讀'data'
- DataOffset+=4;
- if(temp!=DATA_ID)return 8;
- WAVE_Format.DataSize=ReadUnit((u8*)buffer1,DataOffset,4,LittleEndian);//讀采樣數據大小
- DataOffset+=4;
- WaveCounter=DataOffset;
- return 0;
- u32 ReadUnit(u8 *buffer,u8 idx,u8 NbrOfBytes,Endianness BytesFormat)
- u32 index=0;
- u32 temp=0;
- for(index=0;index<NbrOfBytes;index++)temp|=buffer[idx+index]<<(index*8);
- if (BytesFormat == BigEndian)temp= __REV(temp);
- return temp;
- void AUDIO_TransferComplete(u32 pBuffer, u32 Size)
- XferCplt=1;
- if(WaveLen)WaveLen-=1024;
- if(WaveLen<1024) WaveLen=0;
