查看: 3232|回復: 0
用51做一個0.00-99.9S的秒表
ID:183929 發表于 2017-3-28 19:03 | 顯示全部樓層 |閱讀模式
#include "reg52.h"                         //此文件中定義了單片機的一些特殊功能寄存器
typedef unsigned int uint;          //對數據類型進行聲明定義
typedef unsigned char uchar;
uchar datas[3]={0,0,0};
uchar code smgduan[18]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x40};//顯示0~F的值
uint sec = 0;
uchar i = 0;
uint count = 0;
bit flag = 0;
void Timer0Init()
        TMOD=0x01;//選擇為定時器0 模式1,工作方式1,僅用TR0打開啟動。
        TH0=(-2500)>>8;        //給定時器賦初值,定時1ms
        TL0=(-2500)&0x00ff;
        ET0=1;//打開定時器0中斷允許
        EA=1;//打開總中斷
        TR0=1;//打開定時器
void jisuan()
   datas[0] = sec%10;
   datas[1] = sec/10%10;
   datas[2] = sec/100%10;
        Timer0Init(); //定時器0初始化
                if(flag)
                    sec ++;
            jisuan();
                    flag = 0;
                    if(sec == 999)
                         sec = 0;
void Timer0() interrupt 1
    TH0=(-2500)>>8;        //給定時器賦初值,定時2.5ms
        TL0=(-2500)&0x00ff;
        P0 = 0x00;
        P2 = i <<2;
    if(i == 1)
           P0 = smgduan[datas[i]]|0x80;
       P0 = smgduan[datas[i]];
        i ++;
        if(i == 3)
          i = 0;
        count ++;
        if(count == 40)//0.1S
            count = 0;
            flag = 1;
