2017-3-23 09:54 上傳
為什么這個程序,無法把ledbuff[]的值賦給P0?
#include<reg52.h>
#define ulong unsigned long
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
uchar ledbuff[8]={
0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00};
sbit SA=P1^0;
sbit SB=P1^1;
sbit SC=P1^2;
uint time=0;
ulong sec=0;
uchar i=0;
{ TMOD=0x01;
TH0=(65536-1000)/256;
TL0=(65536-1000)%256;
TR0=1;
if(TF0==1)
TF0=0;
TH0=(65536-2000)/256;
TL0=(65536-2000)%256;
time++;
if(time>=1000)
time=0;
sec++;
ledbuff[0]=table[sec%10];
ledbuff[1]=table[sec/10%10];
ledbuff[2]=table[sec/100%10];
ledbuff[3]=table[sec/1000%10];
ledbuff[4]=table[sec/10000%10];
ledbuff[5]=table[sec/100000%10];
ledbuff[6]=table[sec/1000000%10];
ledbuff[7]=table[sec/10000000%10];
switch(i)
{case 0:SC=1;SB=1;SA=1;P0=ledbuff[0];break;
case 1:SC=1;SB=1;SA=0;P0=ledbuff[1];break;
case 2:SC=1;SB=0;SA=1;P0=ledbuff[2];break;
case 3:SC=1;SB=0;SA=0;P0=ledbuff[3];break;
case 4:SC=0;SB=1;SA=1;P0=ledbuff[4];break;
case 5:SC=0;SB=1;SA=0;P0=ledbuff[5];break;
case 6:SC=0;SB=0;SA=1;P0=ledbuff[6];break;
case 7:SC=0;SB=0;SA=0;P0=ledbuff[7];break;
default :break;
