查看: 2995|回復(fù): 0
DHT022-arduino
ID:171446 發(fā)表于 2017-3-17 10:13 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
byte bGlobalErr;
byte dht_dat[5];
float Data_humidity;
float Data_temperature;
void setup(){
  pinMode(A1,OUTPUT);
  digitalWrite(A1,HIGH);
  Serial.begin(9600);
void loop(){
  ReadDHT();
  if(bGlobalErr==0){
        Data_humidity = (dht_dat[0]*256+dht_dat[1])/10;  //Calculate humidity %
        if ((dht_dat[2] & 0x7f) != dht_dat[2]) {     //Calculate temperature C
           dht_dat[2]= dht_dat[2] & 0x7f;
           Data_temperature = -1*(dht_dat[2]*256+dht_dat[3])/10;
        else {
           Data_temperature = (dht_dat[2]*256+dht_dat[3])/10;
        Serial.println(Data_humidity);
        Serial.println(Data_temperature);
  delay(1000);
void ReadDHT(){
  bGlobalErr=0;
  byte dht_in;
  byte i;
  digitalWrite(A1,LOW);
  delay(18);
  delayMicroseconds(30);
  pinMode(A1,INPUT);
  delayMicroseconds(40);
  dht_in=digitalRead(A1);
  delayMicroseconds(80);
  for (i=0; i<5; i++)
    dht_dat[i] = read_dht_dat();
  pinMode(A1,OUTPUT);
byte read_dht_dat(){
  byte i = 0;
  byte result=0;
  for(i=0; i< 8; i++){
    while(digitalRead(A1)==LOW);
    if (digitalRead(A1)==HIGH)
      result |=(1<<(7-i));
    while (digitalRead(A1)==HIGH);
  return result;
