GY-65是BOSCH博世生產(chǎn)的,給論壇的朋友們帶來bmp085模塊資料分享,他是一款數(shù)字式氣溫氣壓計(jì) 高度計(jì)模塊,可以和單片機(jī)直接接口。
BMP085模塊引腳圖:
2017-3-15 23:14 上傳
BMP085原理圖:
2017-3-15 23:14 上傳
BMP085模塊的pdf資料:
2017-3-15 23:13 上傳
2017-3-15 23:13 上傳
Arduino 51單片機(jī)和avr的源碼在壓縮包里面都有
BMP085和單片機(jī)接口的原理圖:
2017-3-15 23:11 上傳
下面是51單片機(jī)代碼的預(yù)覽:
- // BMP085 IIC測(cè)試程序
- // 使用單片機(jī)STC89C51
- // 晶振:11.0592M
- // 顯示:電腦串口助手
- // 編譯環(huán)境 Keil uVision2
- // 參考宏晶網(wǎng)站24c04通信程序
- // 時(shí)間:2012年5月1日
- // QQ:531389319
- #include <REG51.H>
- #include <math.h> //Keil library
- #include <stdlib.h> //Keil library
- #include <stdio.h> //Keil library
- #include <INTRINS.H> //Keil library
- #define uchar unsigned char
- #define uint unsigned int
- #define DataPort P0 //LCD1602數(shù)據(jù)端口
- sbit SCL=P1^0; //IIC時(shí)鐘引腳定義
- sbit SDA=P1^1; //IIC數(shù)據(jù)引腳定義
- #define BMP085_SlaveAddress 0xee //定義器件在IIC總線中的從地址
- #define OSS 0 // Oversampling Setting (note: code is not set up to use other OSS values)
- typedef unsigned char BYTE;
- typedef unsigned short WORD;
- uchar ge,shi,bai,qian,wan,shiwan; //顯示變量
- int dis_data; //變量
- short ac1;
- short ac2;
- short ac3;
- unsigned short ac4;
- unsigned short ac5;
- unsigned short ac6;
- short b1;
- short b2;
- short mb;
- short mc;
- short md;
- int temperature;
- long pressure;
- void delay(unsigned int k);
- //void InitLcd(); //初始化lcd1602
- //void WriteDataLCM(uchar dataW);
- //void WriteCommandLCM(uchar CMD,uchar Attribc);
- //void DisplayOneChar(uchar X,uchar Y,uchar DData);
- void conversion(long temp_data);
- void Single_Write(uchar SlaveAddress,uchar REG_Address,uchar REG_data); //單個(gè)寫入數(shù)據(jù)
- uchar Single_Read(uchar REG_Address); //單個(gè)讀取內(nèi)部寄存器數(shù)據(jù)
- void Multiple_Read(uchar,uchar); //連續(xù)的讀取內(nèi)部寄存器數(shù)據(jù)
- void Delay5us();
- void Delay5ms();
- void BMP085_Start();
- void BMP085_Stop();
- void BMP085_SendACK(bit ack);
- bit BMP085_RecvACK();
- void BMP085_SendByte(BYTE dat);
- BYTE BMP085_RecvByte();
- void BMP085_ReadPage();
- void BMP085_WritePage();
- //串口初始化
- //9600 bps @ 11.059 MHz
- void init_uart()
- TMOD=0x21;
- TH1=0xfd;
- TL1=0xfd;
- SCON=0x50;
- PS=1; //串口中斷設(shè)為高優(yōu)先級(jí)別
- TR0=1; //啟動(dòng)定時(shí)器
- TR1=1;
- ET0=1; //打開定時(shí)器0中斷
- ES=1;
- EA=1;
- //*********串口數(shù)據(jù)發(fā)送******************
- void SeriPushSend(uchar send_data)
- SBUF=send_data;
- while(!TI);TI=0;
- shiwan=temp_data/100000+0x30 ;
- temp_data=temp_data%100000; //取余運(yùn)算
- wan=temp_data/10000+0x30 ;
- temp_data=temp_data%10000; //取余運(yùn)算
- qian=temp_data/1000+0x30 ;
- temp_data=temp_data%1000; //取余運(yùn)算
- bai=temp_data/100+0x30 ;
- temp_data=temp_data%100; //取余運(yùn)算
- shi=temp_data/10+0x30 ;
- temp_data=temp_data%10; //取余運(yùn)算
- ge=temp_data+0x30;
- unsigned int i,j;
- for(i=0;i<k;i++)
- for(j=0;j<121;j++)
- 延時(shí)5微秒(STC90C52RC@12M)
- 不同的工作環(huán)境,需要調(diào)整此函數(shù),注意時(shí)鐘過快時(shí)需要修改
- 當(dāng)改用1T的MCU時(shí),請(qǐng)調(diào)整此延時(shí)函數(shù)
- void Delay5us()
- _nop_();_nop_();_nop_();_nop_();
- 延時(shí)5毫秒(STC90C52RC@12M)
- void Delay5ms()
- WORD n = 560;
- while (n--);
- 起始信號(hào)
- SDA = 1; //拉高數(shù)據(jù)線
- SCL = 1; //拉高時(shí)鐘線
- Delay5us(); //延時(shí)
- SDA = 0; //產(chǎn)生下降沿
- SCL = 0; //拉低時(shí)鐘線
- 停止信號(hào)
- SDA = 0; //拉低數(shù)據(jù)線
- SDA = 1; //產(chǎn)生上升沿
- 發(fā)送應(yīng)答信號(hào)
- 入口參數(shù):ack (0:ACK 1:NAK)
- SDA = ack; //寫應(yīng)答信號(hào)
- 接收應(yīng)答信號(hào)
- CY = SDA; //讀應(yīng)答信號(hào)
- return CY;
- 向IIC總線發(fā)送一個(gè)字節(jié)數(shù)據(jù)
- BYTE i;
- for (i=0; i<8; i++) //8位計(jì)數(shù)器
- dat <<= 1; //移出數(shù)據(jù)的最高位
- SDA = CY; //送數(shù)據(jù)口
- BMP085_RecvACK();
- 從IIC總線接收一個(gè)字節(jié)數(shù)據(jù)
- BYTE i;
- BYTE dat = 0;
- SDA = 1; //使能內(nèi)部上拉,準(zhǔn)備讀取數(shù)據(jù),
- dat <<= 1;
- dat |= SDA; //讀數(shù)據(jù)
- return dat;
- //單字節(jié)寫入BMP085內(nèi)部數(shù)據(jù)*******************************
- BMP085_Start(); //起始信號(hào)
- BMP085_SendByte(SlaveAddress); //發(fā)送設(shè)備地址+寫信號(hào)
- BMP085_SendByte(REG_Address); //內(nèi)部寄存器地址
- BMP085_SendByte(REG_data); //內(nèi)部寄存器數(shù)據(jù)
- BMP085_Stop(); //發(fā)送停止信號(hào)
- //單字節(jié)讀取BMP085內(nèi)部數(shù)據(jù)********************************
- { uchar REG_data;
- BMP085_SendByte(BMP085_SlaveAddress); //發(fā)送設(shè)備地址+寫信號(hào)
- BMP085_SendByte(REG_Address); //發(fā)送存儲(chǔ)單元地址
- BMP085_SendByte(BMP085_SlaveAddress+1); //發(fā)送設(shè)備地址+讀信號(hào)
- REG_data=BMP085_RecvByte(); //讀出寄存器數(shù)據(jù)
- BMP085_SendACK(1);
- BMP085_Stop(); //停止信號(hào)
- return REG_data;
- //讀出BMP085內(nèi)部數(shù)據(jù),連續(xù)兩個(gè)
- short Multiple_read(uchar ST_Address)
- uchar msb, lsb;
- short _data;
- BMP085_SendByte(ST_Address); //發(fā)送存儲(chǔ)單元地址
- msb = BMP085_RecvByte(); //BUF[0]存儲(chǔ)
- BMP085_SendACK(0); //回應(yīng)ACK
- lsb = BMP085_RecvByte();
- BMP085_SendACK(1); //最后一個(gè)數(shù)據(jù)需要回NOACK
- Delay5ms();
- _data = msb << 8;
- _data |= lsb;
- return _data;
- long bmp085ReadTemp(void)
- BMP085_SendByte(0xF4); // write register address
- BMP085_SendByte(0x2E); // write register data for temp
- delay(10); // max time is 4.5ms
- return (long) Multiple_read(0xF6);
- long bmp085ReadPressure(void)
- long pressure = 0;
- BMP085_SendByte(0x34); // write register data for pressure
- delay(20); // max time is 4.5ms
- pressure = Multiple_read(0xF6);
- pressure &= 0x0000FFFF;
- return pressure;
- //return (long) bmp085ReadShort(0xF6);
- //初始化BMP085,根據(jù)需要請(qǐng)參考pdf進(jìn)行修改**************
- void Init_BMP085()
- ac1 = Multiple_read(0xAA);
- ac2 = Multiple_read(0xAC);
- ac3 = Multiple_read(0xAE);
- ac4 = Multiple_read(0xB0);
- ac5 = Multiple_read(0xB2);
- ac6 = Multiple_read(0xB4);
- b1 = Multiple_read(0xB6);
- b2 = Multiple_read(0xB8);
- mb = Multiple_read(0xBA);
- mc = Multiple_read(0xBC);
- md = Multiple_read(0xBE);
- void bmp085Convert()
- unsigned int ut;
- unsigned long up;
- long x1, x2, b5, b6, x3, b3, p;
- unsigned long b4, b7;
- ut = bmp085ReadTemp(); // 讀取溫度
- // ut = bmp085ReadTemp(); // 讀取溫度
- up = bmp085ReadPressure(); // 讀取壓強(qiáng)
- // up = bmp085ReadPressure(); // 讀取壓強(qiáng)
- x1 = (((long)ut - (long)ac6)*(long)ac5) >> 15;
- x2 = ((long) mc << 11) / (x1 + md);
- b5 = x1 + x2;
- temperature = ((b5 + 8) >> 4);
- b6 = b5 - 4000;
- // Calculate B3
- x1 = (b2 * (b6 * b6)>>12)>>11;
- x2 = (ac2 * b6)>>11;
- x3 = x1 + x2;
- b3 = (((((long)ac1)*4 + x3)<<OSS) + 2)>>2;
- // Calculate B4
- x1 = (ac3 * b6)>>13;
- x2 = (b1 * ((b6 * b6)>>12))>>16;
- x3 = ((x1 + x2) + 2)>>2;
- b4 = (ac4 * (unsigned long)(x3 + 32768))>>15;
- b7 = ((unsigned long)(up - b3) * (50000>>OSS));
- if (b7 < 0x80000000)
- p = (b7<<1)/b4;
- else
- p = (b7/b4)<<1;
- x1 = (p>>8) * (p>>8);
- x1 = (x1 * 3038)>>16;
- x2 = (-7357 * p)>>16;
- pressure = p+((x1 + x2 + 3791)>>4);
- //******主程序********
- void main()
- delay(100); //上電延時(shí)
- init_uart();
- Init_BMP085(); //初始化BMP085
- while(1) //循環(huán)
- Init_BMP085();
- bmp085Convert();
- conversion(temperature);
- SeriPushSend('T'); //溫度顯示
- SeriPushSend(':');
- SeriPushSend(bai);
- SeriPushSend(shi);
- SeriPushSend('.');
- SeriPushSend(ge);
- SeriPushSend(' ');
- conversion(pressure);
- SeriPushSend('P'); //顯示壓強(qiáng)
- SeriPushSend(shiwan);
- SeriPushSend(wan);
- SeriPushSend(qian);
- SeriPushSend('K'); //氣壓?jiǎn)挝?br />
- SeriPushSend('p');
- SeriPushSend('a');
- SeriPushSend(0x0d);
- SeriPushSend(0x0a);
- delay(100);
2017-3-15 23:07 上傳
2017-3-15 23:16 上傳
全部資料下載含有Arduino 51單片機(jī)和avr源碼:
【Realplay】BOSCH BMP085 數(shù)字式氣溫氣壓模塊 高度計(jì)模塊GY-65.rar
(1.67 MB, 下載次數(shù): 42)
2017-3-15 16:32 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
