分享一個消洗臺的單片機程序源碼:
完整源碼下載:
modbus通訊.zip
(74.71 KB, 下載次數: 64)
2017-3-15 16:07 上傳
部分源碼預覽:
- * 文件名:main.c
- * 描 述:RS485的Modbus
- * 備 注:
- * 支持Modbus協議的寄存器讀取和單寄存器寫入操作
- #include <reg52.h>
- #include "i2c.h"
- #define KEY P1
- typedef unsigned int uint;
- typedef unsigned char u8;
- unsigned char addr;
- unsigned char dat;
- int s=0,m=1,sa=0,ma=2,num;
- sbit LSA=P2^2;
- sbit LSB=P2^3;
- sbit LSC=P2^4;
- sbit OUTa=P2^5;
- sbit OUT=P2^6;
- sbit LE=P2^7;
- uint a[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//0到9
- uint sg,ss,mg,ms,sga,ssa,mga,msa,K=0;
- sbit BUZZ = P1^5;
- bit flagBuzzOn = 0;
- unsigned char KH,KL;
- unsigned char T0RH = 0;
- unsigned char T0RL = 0;
- unsigned char regGroup[5];
- unsigned char MODADD=0X01;
- void ConfigTimer0(unsigned int ms);
- extern void UartDriver();
- extern void ConfigUART(unsigned int baud);
- extern void UartRxMonitor(unsigned char ms);
- extern void UartWrite(unsigned char *buf, unsigned char len);
- extern unsigned int GetCRC16(unsigned char *ptr, unsigned char len);
- extern void zhu();
- extern void DigDisplay();
- extern void Timer1Init();
- extern void delay(uint i);
- extern int Keypros();
- extern void At24c02Write(unsigned char addr,unsigned char dat) ;
- extern unsigned char At24c02Read(unsigned char addr);
- void main()
- unsigned char x=~OUT,y=~OUTa;
- m=At24c02Read(1);
- delay(1000);
- ma=At24c02Read(2);
- while (1)
- while((OUT&OUTa)==1)
- EA = 1;
- ConfigTimer0(1);
- ConfigUART(9600);
- while ((KEY&0x0f)!=0x01)
- DigDisplay();
- UartDriver();
- Keypros();
- if((KEY&0x0f)==0x01)
- delay(3000);
- OUT=0;
- return;
- if((m||ma)!=0)
- zhu();
- KL=At24c02Read(4);
- delay(1000);
- KH=At24c02Read(3);
- delay(1000);
- K=(KH<<8)+KL;
- DigDisplay();
- K++;
- KH=K>>8;
- KL=K&0X00FF;
- At24c02Write(4,KL);
- delay(1000);
- while(K==100){DigDisplay();}
- At24c02Write(3,KH);
- delay(1000);
- void UartAction(unsigned char *buf, unsigned char len)
- unsigned char i;
- unsigned char cnt;
- unsigned int crc;
- unsigned char crch, crcl;
- MODADD=At24c02Read(0);
- if (buf[0] !=MODADD ) //本機地址設定為0x01,
- return;
- crc = GetCRC16(buf, len-2);
- crch = crc >> 8;
- crcl = crc & 0xFF;
- if ((buf[len-2]!=crch) || (buf[len-1]!=crcl))
- return;
- switch (buf[1])
- case 0x03:
- if ((buf[2]==0x00) && (buf[3]<=0x05))
- if (buf[3] <= 0x04)
- regGroup[0]=At24c02Read(0);
- regGroup[1]=At24c02Read(1);
- regGroup[2]=At24c02Read(2);
- regGroup[3]=At24c02Read(3);
- regGroup[4]=At24c02Read(4);
- i = buf[3];
- cnt = buf[5];
- buf[2] = cnt*2;
- len = 3;
- while (cnt--)
- buf[len++] = 0x00;
- buf[len++] = regGroup[i++];
- else
- buf[2] = 2;
- buf[3] = 0x00;
- buf[4] = flagBuzzOn;
- len = 5;
- break;
- else
- buf[1] = 0x83;
- buf[2] = 0x02;
- len = 3;
- break;
- case 0x06:
- switch(buf[3])
- case 0:
- i = buf[3];
- regGroup[i] = buf[5];
- MODADD = regGroup[i];
- At24c02Write(0,MODADD);
- case 1:
- i = buf[3];
- m = regGroup[i];
- At24c02Write(1,m);
- case 2:
- i = buf[3];
- ma = regGroup[i];
- At24c02Write(2,ma);
- else
- flagBuzzOn = (bit)buf[5];
- len -= 2;
- break;
- else
- buf[1] = 0x86;
- buf[2] = 0x02;
- len = 3;
- break;
- default:
- buf[1] |= 0x80;
- buf[2] = 0x01;
- len = 3;
- break;
- crc = GetCRC16(buf, len);
- buf[len++] = crc >> 8;
- buf[len++] = crc & 0xFF;
- UartWrite(buf, len);
- /* 配置并啟動T0 */
- unsigned long tmp;
- tmp = 11059200 / 12;
- tmp = (tmp * ms) / 1000;
- tmp = 65536 - tmp;
- tmp = tmp + 33;
- T0RH = (unsigned char)(tmp>>8);
- T0RL = (unsigned char)tmp;
- TMOD &= 0xF0;
- TMOD |= 0x01;
- TH0 = T0RH;
- TL0 = T0RL;
- ET0 = 1;
- TR0 = 1;
- /* T0中斷服務函數,執行串口接收監控和蜂鳴器驅動 */
- void InterruptTimer0() interrupt 1
- TH0 = T0RH;
- TL0 = T0RL;
- if (flagBuzzOn)
- BUZZ = ~BUZZ;
- else
- BUZZ = 1;
- UartRxMonitor(1);
- * 函 數 名 : delay
- * 函數功能 : 延時函數,i=1時,大約延時10us
- void delay(uint i)
- while(i--);
- * 函數名 :Keypros()
- * 函數功能 :按鍵處理函數
- * 輸入 : 無
- * 輸出 : 鍵值
- int Keypros()
- if ((OUT&OUTa)!=0)
- if((KEY&0x0f)==0x05)
- m--;
- delay(30000);
- if(m<=1)
- m=1;
- if((KEY&0x0f)==0x06)
- m++;
- delay(40000);
- if(m>30)
- m=30;
- if((KEY&0x0f)==0x08)
- ma--;
- delay(40000);
- if(ma<=1)
- ma=1; //現在第1次ma減到0會死機---------------------------------------
- if((KEY&0x0f)==0x09)
- ma++ ;
- delay(30000);
- if(ma>30)
- ma=30;
- if((KEY&0x0f)==0x0a)
- delay(1000);
- delay(1000); // 等待寫完。
- if((KEY&0x0f)==0x0c)
- delay(1000);
- num=At24c02Read(1); //讀取EEPROM地址1內的數據保存在num中
- m=num;
- delay(1000);
- num=At24c02Read(2);
- ma=num;
- return(m,ma);
- 動態置LEDCOM口低電平
- void DigDisplay()
- u8 i;
- sg=s%10;
- ss=s/10;
- mg=m%10;
- ms=m/10;
- sga=sa%10;
- ssa=sa/10;
- mga=ma%10;
- msa=ma/10;
- for(i=0;i<8;i++)
- switch(i)
- case(0):
- LSA=0;LSB=0;LSC=0; P0=a[sg]; break;//顯示第0位
- case(1):
- LSA=1;LSB=0;LSC=0; P0=a[ss]; break;//顯示第1位
- case(2):
- LSA=0;LSB=1;LSC=0; P0=a[mg]; break;//顯示第2位
- case(3):
- LSA=1;LSB=1;LSC=0; P0=a[ms];break;//顯示第3位
- case(4):
- LSA=0;LSB=0;LSC=1; P0=a[sga]; break;//顯示第4位
- case(5):
- LSA=1;LSB=0;LSC=1; P0=a[ssa];break;//顯示第5位
- case(6):
- LSA=0;LSB=1;LSC=1; P0=a[mga];; break;//顯示第6位
- case(7):
- LSA=1;LSB=1;LSC=1; P0=a[msa]; break;//顯示第7位
- delay(10); // 增減亮度。
- P0=0x00;//消隱
- * 函 數 名 : Timer1Init
- * 函數功能 : 定時器1初始化
- * 輸 入 : 無
- * 輸 出 : 無
- void Timer1Init()
- TMOD=0X11;
- ET1=1;
- EA=1;
- TR1=1;
- * 函 數 名 : void Timer1() interrupt 3
- * 函數功能 : 定時器1中斷函數
- * 輸 入 : 無
- * 輸 出 : 無
- void Timer1() interrupt 3
- static uint i;
- TH1=0X3c; //給定時器賦初值,定時50ms
- TL1=0Xb0;
- i++;
- if((s||m)!=0)
- if(i==20) //中斷次數
- i=0;
- s--;
- if(s<=-1&&(m!=0))
- s=59;
- m--;
- else
- if((sa||ma)!=0)
- if(i==20)
- i=0;
- sa--;
- if(sa<=-1&&(ma!=0))
- sa=59;
- ma--;
- else{ ma-=0; if(ma<=-1) { ma=0; }}
- else{ sa-=0; if(sa<=-1) { sa=0; }}
- if((sa||ma)!=0)
- OUTa=0; OUT=1;
- if((sa||ma)==0)
- {OUTa=1; OUT=1;TR1=0;}
- * 函 數 名 : zhu
- * 函數功能
- * 輸 入 : 無
- * 輸 出 : 無
- void zhu()
- { while(ma||sa)
- if((KEY&0x0f)!=0x01)
- Keypros();
- DigDisplay();
- else
- delay(1000);
- m=num;
- delay(1000);
- ma=num;
- while (sa||ma!=0)
- { DigDisplay();
- Timer1Init();
復制代碼 |
