#include<reg52.h>
sbit key1=P3^4;
sbit key2=P3^5;
sbit key3=P3^6;
sbit key4=P3^7;
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
void delayms(uint xms)
uint i,j;
for(i=xms;i>0;i--)
for(j=110;j>0;j--);
void display(uint num)
P0=table[num];
dula=1;
dula=0;
void matrikeyscan()
uint temp,key;
P3=0xfe;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delayms(10);
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
temp=P3;
switch(temp)
case 0xee:key=0;break;
case 0xde:key=1;break;
case 0xbe:key=2;break;
case 0x7e:key=3;break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
display(key);
P3=0xfd;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delayms(10);
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
temp=P3;
switch(temp)
case 0xed:key=4;break;
case 0xdd:key=5;break;
case 0xbd:key=6;break;
case 0x7d:key=7;break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
display(key);
P3=0xfb;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delayms(10);
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
temp=P3;
switch(temp)
case 0xeb:key=8;break;
case 0xdb:key=9;break;
case 0xbb:key=10;break;
case 0x7b:key=11;break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
display(key);
void keyscan()
uchar key;
if(key1==0)
delayms(10);
if(key1==0)
key=12;
while(!key1);
display(key);
if(key2==0)
delayms(10);
if(key2==0)
key=13;
while(!key2);
display(key);
matrikeyscan();
P0=0;
dula=1;
dula=0;
P0=0xc0;
wela=1;
wela=0;
keyscan();
