查看: 5625|回復(fù): 0
ARM裸機(jī)篇-串口UART實(shí)驗(yàn)
串口應(yīng)該都很熟悉了,具體通信原理我就不提了,這個百度上都很多講的,然后就直接看函數(shù)了。
  1. void Uart_SendByte(int data)//這個函數(shù)是發(fā)送整型數(shù)據(jù),參數(shù)為data
  2. {
  3.     if(whichUart==0)//這個是選中串口0
  4.     {
  5.         if(data=='')//然后判斷數(shù)據(jù)不為空
  6.         {
  7.       /*寄存器的原始宏定義,
  8.       #define rUTRSTAT0   (*(volatile unsigned *)0x50000010) //UART 0 Tx/Rx status*/
  9.             while(!(rUTRSTAT0 & 0x2));/*這個就是查詢串口0的狀態(tài)寄存器,第1位是發(fā)送緩沖器是否為空
  10.             第二位是Transmit buffer empty
  11.             0 = The buffer register is not empty
  12.             1 = Empty     這里檢查為0的話就是還沒發(fā)送完全,當(dāng)置1的時候表示發(fā)完了,程序繼續(xù)執(zhí)行*/
  13.             Delay(10);                 //because the slow response of hyper_terminal
  14.             WrUTXH0('');
  15.         }
  16.         while(!(rUTRSTAT0 & 0x2));   //Wait until THR is empty.
  17.         Delay(10);
  18.         WrUTXH0(data);
  19.     }
  20.     else if(whichUart==1)
  21.     {
  22.         if(data=='')
  23.         {
  24.             while(!(rUTRSTAT1 & 0x2));
  25.             Delay(10);                 //because the slow response of hyper_terminal
  26.             rUTXH1 = '';
  27.         }
  28.         while(!(rUTRSTAT1 & 0x2));   //Wait until THR is empty.
  29.         Delay(10);
  30.         rUTXH1 = data;
  31.     }
  32.     else if(whichUart==2)
  33.     {
  34.         if(data=='')
  35.         {
  36.             while(!(rUTRSTAT2 & 0x2));
  37.             Delay(10);                 //because the slow response of hyper_terminal
  38.             rUTXH2 = '';
  39.         }
  40.         while(!(rUTRSTAT2 & 0x2));   //Wait until THR is empty.
  41.         Delay(10);
  42.         rUTXH2 = data;
  43.     }
  44. }
搞了這么久我還不知道如何確定ARM的大端或是小端格式,這個是在啟動代碼里設(shè)置的,現(xiàn)在還沒看,mini2440的串口代碼和華恒2410的串口發(fā)送代碼一樣的。注釋如上。
主函數(shù)中的關(guān)鍵代碼:
  1. /***************************************************************************************
  2. *   Function Name               :   Main()
  3. *   Create Date                 :   2011/12/10
  4. *   Author/Corporation          :   濤行天下
  5. *
  6. *   Description                 :   Find a proper thread in thread array
  7. *
  8. *   Param                       :   ThreadNo : someParam description
  9.                                     ThreadStaus : someParam description
  10. *
  11. *
  12. *   Global Variable             :   DISP_wuiSegmentAppID
  13. *   File Static Variable                :   naucThreadNo
  14. *   Function Static Variable        :   None
  15. *
  16. *----------------------------------------------------
  17. *   Revision History
  18. *   No.         Date          Revised by                 Item       Description
  19. *   V0.0           2011/12/10     濤行天下          ...         ....
  20. ***************************************************************************************/
  21. void Main(void)
  22. {
  23.     U8 count_num = 0;
  24.     char *mode;
  25.     int i;
  26.     U8 key;
  27.     U32 mpll_val = 0 ;
  28.     //U32 divn_upll = 0 ;
  29.     #if ADS10
  30. //  __rt_lib_init(); //for ADS 1.0
  31.     #endif
  32.     Port_Init();//端口初始化
  33.     Isr_Init();//中斷初始化
  34.     i = 2 ; //don't use 100M!
  35.         //boot_params.cpu_clk.val = 3;
  36.     //確定頻率
  37.     switch ( i )
  38.     {
  39.         case 0: //200
  40.             key = 12;
  41.             mpll_val = (92<<12)|(4<<4)|(1);
  42.             break;
  43.         case 1: //300
  44.             key = 13;
  45.             mpll_val = (67<<12)|(1<<4)|(1);
  46.             break;
  47.         case 2: //400
  48.             key = 14;
  49.             mpll_val = (92<<12)|(1<<4)|(1);
  50.             break;
  51.         case 3: //440!!!
  52.             key = 14;
  53.             mpll_val = (102<<12)|(1<<4)|(1);
  54.             break;
  55.         default:
  56.             key = 14;
  57.             mpll_val = (92<<12)|(1<<4)|(1);
  58.             break;
  59.     }
  60.     //init FCLK=400M, so change MPLL first
  61.     ChangeMPllValue((mpll_val>>12)&0xff, (mpll_val>>4)&0x3f, mpll_val&3);
  62.     ChangeClockDivider(key, 12);
  63.     cal_cpu_bus_clk();
  64.     consoleNum = 0; // Uart 1 select for debug.選擇串口號
  65.     Uart_Init( 0,115200 );//初始化串口參數(shù)以及時鐘源
  66.     Uart_Select( consoleNum );//選擇串口號
  67.     Beep(2000, 100);//蜂鳴器
  68.     Uart_SendByte('');//打印信息
  69.     Uart_SendByte('H');
  70.     while(1)
  71.     {
  72.         Uart_SendByte(count_num);
  73.         Uart_SendByte(' ');
  74.         count_num ++;
  75.         Delay(500);
  76.     }
從而讓ARM一直向PC機(jī)發(fā)送從0-255數(shù)據(jù),在PC機(jī)中顯示結(jié)果如下:
這個看不了十六進(jìn)制的數(shù),我搞了個串口助手來顯示:
上面那個是用mini2440實(shí)現(xiàn)的,那個通過UBOOT可以直接燒寫程序,不過到了華恒的板子我就不知道為啥了,這個苦悶了我好久,今天在進(jìn)入PPCBOOT中利用erase命令把那個linux系統(tǒng)檫除了,然后進(jìn)入ppcboot命令行形式才可以jtag調(diào)試,不知道為啥,這次終于進(jìn)了一次調(diào)試結(jié)果出來了。
下面出一張計數(shù)的圖,感覺下成就感吧,雖然底層函數(shù)還沒完全弄懂!
現(xiàn)在總結(jié)這些步驟吧,最開始在上電的時候不要立馬啟動系統(tǒng),先要進(jìn)入PPCBOOT模式命令行,然后再啟動AXD調(diào)試器。
通過H-JATG軟件可以看到是小端格式的,但是具體怎么設(shè)置暫時還不清楚,
#define WrUTXH0(ch) (*(volatile unsigned char *)0x50000020)=(unsigned char)(ch)
WrUTXH0即是寫UTXH0的意思,UTXH0是第一個串口的發(fā)送緩沖寄存器!
2011/12/13日
還是阿南的程序給力啊,華恒板子帶的程序沒啥用
2011/12/21日
感慨日子過的飛快!可是我卻沒啥長進(jìn),先上程序吧:
  1. ;//呼叫主應(yīng)用程序
  2.     b UART
  3. UART
  4.     ldr r0, =GPHCON ;//設(shè)置RxD0,TxD0引腳
  5.     ldr r1, =0x2afaaa
  6.     str r1, [r0]
  7.
  8.     ldr r0, =GPHUP
  9.     ldr r1, =0x7ff
  10.     str r1, [r0] ;    // The pull up function is disabled GPH[10:0]
  11.     ldr r0, =UFCON0 ;//禁用FIFO
  12.     ldr r1, =0x0
  13.     str r1, [r0]
  14.
  15.     ldr r0, =UMCON0  ;//禁用AFC
  16.     ldr r1, =0x0
  17.     str r1, [r0]
  18.
  19.     ldr r0, =ULCON0 ;//設(shè)置線寄存器
  20.     ldr r1, =0x3   ; //UART LINE CONFIG  正常模式,無奇偶校驗(yàn),一個停止位,8個數(shù)據(jù)位
  21.     str r1, [r0]
  22.
  23.     ldr r0, =UCON0 ;//設(shè)置Uart0控制器
  24.     ldr r1, =0x245;//RX邊沿觸發(fā),TX電平觸發(fā),禁用延時中斷,使用RX 錯誤中斷,正常操作模式,中斷請求或表決模式
  25.     str r1, [r0]
  26.
  27.     ldr r0, =UBRDIV0 ;//設(shè)置波特率為115200
  28.     ldr r1, =0x1a    ;//int(50700000 / 16 / 115200) - 1 = 26
  29.     str r1, [r0]
  30.
  31.     mov r1, #100
  32. Delay
  33.     sub r1, r1, #0x1
  34.     bne Delay
  35.
  36.     ;//開中斷
  37.     ldr r0, =INTMSK
  38.     ldr r1, [r0]
  39.     and r1, r1, #0xefffffff
  40.     str r1, [r0]
  41.
  42.     MOV R5 , #127 ;//設(shè)置要打印的字符的個數(shù)
  43.     MOV R1 , #0x0 ;//設(shè)置要打印的字符
  44. LOOP
  45.    LDR R3 , =UTRSTAT0
  46.    LDR R2 , [R3]
  47.    TST R2 ,#0x04 ;//判斷發(fā)送緩沖區(qū)是否為空
  48.    BEQ LOOP      ;//為空則執(zhí)行下邊的語句,不為空則跳轉(zhuǎn)到LOOP
  49.    LDR R0 , =UTXH0
  50.
  51.    STR R1 ,[R0] ;//向數(shù)據(jù)緩沖區(qū)放置要發(fā)送的數(shù)據(jù)
  52.    ADD R1, R1, #1
  53.    SUB R5 ,R5, #0x01 ;//計數(shù)器減一
  54.    CMP R5 ,#0x0
  55.    BNE LOOP
  56.
  57. LOOP2   B LOOP2
這個緊跟隨這啟動代碼后面的一部分用匯編編的串口發(fā)送程序,設(shè)置相關(guān)寄存器,然后往PC端發(fā)送數(shù)據(jù)。
