#include <reg52.h>
sbit BUZZ = P1^6;
bit flagBuzzOn = 0; //蜂鳴器啟動標志
unsigned char T0RH = 0; //T0重載值的高字節(jié)
unsigned char T0RL = 0; //T0重載值的低字節(jié)
unsigned char regGroup[5]; //Modbus寄存器組,地址為0x00~0x04
void ConfigTimer0(unsigned int ms);
extern void UartDriver();
extern void ConfigUART(unsigned int baud);
extern void UartRxMonitor(unsigned char ms);
extern void UartWrite(unsigned char *buf, unsigned char len);
extern unsigned int GetCRC16(unsigned char *ptr, unsigned char len);
extern void InitLcd1602();
extern void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
EA = 1; //開總中斷
ConfigTimer0(1); //配置T0定時1ms
ConfigUART(9600); //配置波特率為9600
InitLcd1602(); //初始化液晶
while (1)
UartDriver(); //調用串口驅動
/* 串口動作函數(shù),根據(jù)接收到的命令幀執(zhí)行響應的動作
buf-接收到的命令幀指針,len-命令幀長度 */
void UartAction(unsigned char *buf, unsigned char len)
unsigned char i;
unsigned char cnt;
unsigned char str[4];
unsigned int crc;
unsigned char crch, crcl;
if (buf[0] != 0x01) //本例中的本機地址設定為0x01,
{ //如數(shù)據(jù)幀中的地址字節(jié)與本機地址不符,
return; //則直接退出,即丟棄本幀數(shù)據(jù)不做任何處理
//地址相符時,再對本幀數(shù)據(jù)進行校驗
crc = GetCRC16(buf, len-2); //計算CRC校驗值
crch = crc >> 8;
crcl = crc & 0xFF;
if ((buf[len-2]!=crch) || (buf[len-1]!=crcl))
return; //如CRC校驗不符時直接退出
//地址和校驗字均相符后,解析功能碼,執(zhí)行相關操作
switch (buf[1])
case 0x03: //讀取一個或連續(xù)的寄存器
if ((buf[2]==0x00) && (buf[3]<=0x05)) //只支持0x0000~0x0005
if (buf[3] <= 0x04)
i = buf[3]; //提取寄存器地址
cnt = buf[5]; //提取待讀取的寄存器數(shù)量
buf[2] = cnt*2; //讀取數(shù)據(jù)的字節(jié)數(shù),為寄存器數(shù)*2
len = 3; //幀前部已有地址、功能碼、字節(jié)數(shù)共3個字節(jié)
while (cnt--)
buf[len++] = 0x00; //寄存器高字節(jié)補0
buf[len++] = regGroup[i++]; //寄存器低字節(jié)
else //地址0x05為蜂鳴器狀態(tài)
buf[2] = 2; //讀取數(shù)據(jù)的字節(jié)數(shù)
buf[3] = 0x00;
buf[4] = flagBuzzOn;
len = 5;
break;
else //寄存器地址不被支持時,返回錯誤碼
buf[1] = 0x83; //功能碼最高位置1
buf[2] = 0x02; //設置異常碼為02-無效地址
len = 3;
break;
case 0x06: //寫入單個寄存器
if (buf[3] <= 0x04)
regGroup[i] = buf[5]; //保存寄存器數(shù)據(jù)
cnt = regGroup[i] >> 4; //顯示到液晶上
if (cnt >= 0xA)
str[0] = cnt - 0xA + 'A';
str[0] = cnt + '0';
cnt = regGroup[i] & 0x0F;
if (cnt >= 0xA)
str[1] = cnt - 0xA + 'A';
str[1] = cnt + '0';
str[2] = '\0';
LcdShowStr(i*3, 0, str);
flagBuzzOn = (bit)buf[5]; //寄存器值轉為蜂鳴器的開關
len -= 2; //長度-2以重新計算CRC并返回原幀
break;
buf[1] = 0x86; //功能碼最高位置1
len = 3;
break;
default: //其它不支持的功能碼
buf[1] |= 0x80; //功能碼最高位置1
buf[2] = 0x01; //設置異常碼為01-無效功能
len = 3;
break;
crc = GetCRC16(buf, len); //計算返回幀的CRC校驗值
buf[len++] = crc >> 8; //CRC高字節(jié)
buf[len++] = crc & 0xFF; //CRC低字節(jié)
UartWrite(buf, len); //發(fā)送返回幀
/* 配置并啟動T0,ms-T0定時時間 */
unsigned long tmp; //臨時變量
tmp = 11059200 / 12; //定時器計數(shù)頻率
tmp = (tmp * ms) / 1000; //計算所需的計數(shù)值
tmp = 65536 - tmp; //計算定時器重載值
tmp = tmp + 33; //補償中斷響應延時造成的誤差
T0RH = (unsigned char)(tmp>>8); //定時器重載值拆分為高低字節(jié)
T0RL = (unsigned char)tmp;
TMOD &= 0xF0; //清零T0的控制位
TMOD |= 0x01; //配置T0為模式1
TH0 = T0RH; //加載T0重載值
TL0 = T0RL;
ET0 = 1; //使能T0中斷
TR0 = 1; //啟動T0
/* T0中斷服務函數(shù),執(zhí)行串口接收監(jiān)控和蜂鳴器驅動 */
void InterruptTimer0() interrupt 1
TH0 = T0RH; //重新加載重載值
TL0 = T0RL;
if (flagBuzzOn) //執(zhí)行蜂鳴器鳴叫或關閉
BUZZ = ~BUZZ;
BUZZ = 1;
UartRxMonitor(1); //串口接收監(jiān)控
