最近做了一個pwm直流電機調速
下面是程序
#include<reg52.h>
uchar num;
uint speed,count,gao_num=50,gao_count;
sbit lcdrs=P3^5;
sbit lcden=P3^4;
sbit jia_key=P3^0;
sbit jian_key=P3^1;
sbit kaiguan=P3^2;
sbit dianji=P1^0;
uchar code table[]={"0123456789"};
uchar code digit2[]={"speed: r/min"};
uchar code digit3[]={"Gao_count: "};
void delay(uint z)
uint x;
for(x=z;x>0;x--) ;
// for(y=110;y>0;y--);
void write_com(uchar com)
lcdrs=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_date(uchar date)
lcdrs=1;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void display()
write_com(0x80+7);
write_date(table[speed/100]);
write_com(0x80+8);
write_date(table[speed%100/10]);
write_com(0x80+9);
write_date(table[speed%10]);
write_com(0x80+0x40+12);
write_date(table[gao_num/10]);
write_com(0x80+0x40+13);
write_date(table[gao_num%10]);
void init()
lcden=0;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x00);
write_com(0x80);
for(num=0;num<15;num++)
write_date(digit2[num]);
delay(5);
write_com(0x80+0x40);
write_date(digit3[num]);
delay(5);
TMOD=0x51;
TH0=(65536-10000)/256;
TL0=(65536-10000)%256; //12HZ 10ms 中斷一次
EA=1;
ET0=1;
TR0=1;
TR1=1;
TH1=0;
TL1=0;
void timer0() interrupt 1
count++;
gao_count++;//統計高電平的時間
void key()
{ /*啟動和關閉電機*/
if(kaiguan==0)
dianji=1;
dianji=0;
/**按鍵加**/
if(jia_key==0)//加速
delay(5);
if(jia_key==0)
gao_num+=5; //按鍵每按下一次,加5已達到讓風扇轉的更快
if(gao_num>99) //當gao_num加到100時,時間正好達到1s
gao_num=99;
while(!jia_key);
/**按鍵減**/
if(jian_key==0)//減速
delay(5);
if(jian_key==0)
if(gao_num!=0)
gao_num-=5;
gao_num=50;
while(!jian_key);
void qudong()
{ if(gao_count>99)
gao_count=0;
if(gao_count<gao_num)
dianji=1;//加速
dianji=0;//減速
init();
dianji=0;
key();
qudong();
if(count>99) //1s
{ count=0;
speed=(TH1*256+TL1)*60/7;
TH1=0;
TL1=0;
display();
