查看: 10980|回復: 21
段式液晶HT1621驅(qū)動 15F104E做的溫控器
ID:19198 發(fā)表于 2016-11-11 13:07 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最后由 trm999 于 2017-11-5 12:35 編輯
歷時一周,由HT1621B驅(qū)動寫起,LCD正常顯示后,加入18B20溫度檢測程序,
可以正常顯示溫度后,又加入按鍵識別,因為是6腳IO,所以只有一個IO可用,
加入短按,2秒長按,5秒長按程序來實現(xiàn)減、加、保存,涉及到保存,
又學習STC單片機的EEPROM,實現(xiàn)保存后由于代碼比較多,又進行模塊化編程學習,
在這里卡了2天,定時器卡了一下午,終于完成
注意:1.EEPROM操作放到中斷里面可以正常操作保存,估計和關閉中斷有關系  2.因為繼電器會干擾動作,要加電容
// - - * * * * * * * HT1621 段碼屏驅(qū)動   * * * * * * *
// - - * MCU STC15F104W通過 15F104E未知 內(nèi)設12M 晶振 *
// - - * C 語言程序          trm999  版本1.0         *
//                 溫度容差0.5攝氏度,當空調(diào)控制器使用,必須要有容差
數(shù)碼管結(jié)構       a    f     b        g      e     c     d         dp
                 seg0  seg1  seg2  seg3  seg4  seg5  seg6   seg7
com0          1a    1f    1b    1g    1e    1c    1d     1dp
  com1          2a    2f    2b    2g    2e    2c    2d     2dp
    com2      3a    3f    3b    3g    3e    3c    3d     3dp
      com3      4a    4f    4b    4g    4e    4c    4d     3dp      數(shù)據(jù)位4位,結(jié)構4321
sbit DQ=P3^5;   //18B20
sbit SS=P3^0;   //繼電器
sbit HT1621_CS=P3^3; // - - HT1621使能引腳
sbit HT1621_WR=P3^2; // - - HT1621時鐘引腳
sbit HT1621_DAT=P3^4; // - - HT1621數(shù)據(jù)引腳
sbit key_sr=P3^1;//對應按鍵
//shuzi0是左1大8字的代碼表格
uchar code Ht1621_shuzi0[][8]={                //0~9數(shù)字數(shù)組
    {0x01,0x01,0x01,0x00,0x01,0x01,0x01,0x00},//0
    {0x00,0x00,0x01,0x00,0x00,0x01,0x00,0x00},//1
    {0x01,0x00,0x01,0x01,0x01,0x00,0x01,0x00},//2
    {0x01,0x00,0x01,0x01,0x00,0x01,0x01,0x00},//3
    {0x00,0x01,0x01,0x01,0x00,0x01,0x00,0x00},//4
    {0x01,0x01,0x00,0x01,0x00,0x01,0x01,0x00},//5
    {0x01,0x01,0x00,0x01,0x01,0x01,0x01,0x00},//6
    {0x01,0x00,0x01,0x00,0x00,0x01,0x00,0x00},//7
    {0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x00},//8
    {0x01,0x01,0x01,0x01,0x00,0x01,0x01,0x00},//9
    {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01},//AUTO    10
    {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//        11
//shuzi1是左2大8字的代碼表格
uchar code Ht1621_shuzi1[][8]={                //0~9數(shù)字數(shù)組
    {0x02,0x02,0x02,0x00,0x02,0x02,0x02,0x00},//0
    {0x00,0x00,0x02,0x00,0x00,0x02,0x00,0x00},//1
    {0x02,0x00,0x02,0x02,0x02,0x00,0x02,0x00},//2
    {0x02,0x00,0x02,0x02,0x00,0x02,0x02,0x00},//3
    {0x00,0x02,0x02,0x02,0x00,0x02,0x00,0x00},//4
    {0x02,0x02,0x00,0x02,0x00,0x02,0x02,0x00},//5
    {0x02,0x02,0x00,0x02,0x02,0x02,0x02,0x00},//6
    {0x02,0x00,0x02,0x00,0x00,0x02,0x00,0x00},//7
    {0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x00},//8
    {0x02,0x02,0x02,0x02,0x00,0x02,0x02,0x00},//9
    {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02},//hight    10
//shuzi2是右小8字的代碼表格
uchar code Ht1621_shuzi2[][8]={                //0~9數(shù)字數(shù)組
    {0x04,0x04,0x04,0x00,0x04,0x04,0x04,0x00},//0
    {0x00,0x00,0x04,0x00,0x00,0x04,0x00,0x00},//1
    {0x04,0x00,0x04,0x04,0x04,0x00,0x04,0x00},//2
    {0x04,0x00,0x04,0x04,0x00,0x04,0x04,0x00},//3
    {0x00,0x04,0x04,0x04,0x00,0x04,0x00,0x00},//4
    {0x04,0x04,0x00,0x04,0x00,0x04,0x04,0x00},//5
    {0x04,0x04,0x00,0x04,0x04,0x04,0x04,0x00},//6
    {0x04,0x00,0x04,0x00,0x00,0x04,0x00,0x00},//7
    {0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x00},//8
    {0x04,0x04,0x04,0x04,0x00,0x04,0x04,0x00},//9
    {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04},//low    10
//shuzi3是特殊符號代碼表格
uchar code Ht1621_shuzi3[][8]={                //0~9數(shù)字數(shù)組
    {0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//上半圓
    {0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x00},//圓雙線
    {0x00,0x00,0x08,0x00,0x00,0x00,0x00,0x00},//TEMP
    {0x00,0x00,0x00,0x08,0x00,0x00,0x00,0x00},//ROOM
    {0x00,0x00,0x00,0x00,0x08,0x00,0x00,0x00},//SET
    {0x00,0x00,0x00,0x00,0x00,0x08,0x00,0x00},//下半圓hr
    {0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x00},//線條
    {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08},//FAN    7
    {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//    8
淘寶買的2毛液晶玻璃,接口有變化,com0-com4是反的
要用HT1621B驅(qū)動,自己做的板子老是有重影,干脆打板子,做工不錯
焊好后,松香不少請無視
15F104E單片機,加的背光,晚上方便
外殼是個問題,基本都是膠粘的,因為汽車使用,所以電源是12V變5V,用的3312模塊的一半
左邊圓的是按鍵
正常顯示溫度,小數(shù)字是小數(shù)部分,AUTO代表正溫度,負溫度會顯示LOW
設定界面會顯示線條,繼電器閉合會顯示一個小圓圈和兩個細線
源文件因為是模塊化,所以打包吧
溫控器   15F104E通過1.0版 20161102溫控器 15F104E通過1.0版.7z (117.73 KB, 下載次數(shù): 254) (118 K) 下載次數(shù):0
參與人數(shù) 1黑幣 +100 收起 理由
admin + 100 共享資料的黑幣獎勵!
收藏收藏16 分享淘帖 頂1 踩
ID:14010 發(fā)表于 2016-11-11 18:46 | 只看該作者
不錯,支持一下!
ID:149091 發(fā)表于 2016-11-22 21:50 | 只看該作者
51黑有你更精彩!!!
ID:190026 發(fā)表于 2017-5-6 17:38 | 只看該作者
購買了 怎么不能下載呢
ID:140489 發(fā)表于 2017-6-16 10:21 | 只看該作者
下載了,但是好貴,一共要10黑幣
ID:303586 發(fā)表于 2018-4-8 14:53 | 只看該作者
看看歷程,學習下
ID:254251 發(fā)表于 2018-5-15 18:09 | 只看該作者
編不過
ID:254251 發(fā)表于 2018-5-15 18:49 | 只看該作者
回差0.5太小繼電器頻繁開閉,回差2到3比較好
ID:399111 發(fā)表于 2020-4-29 12:14 | 只看該作者
學習下
ID:282850 發(fā)表于 2020-4-30 15:18 | 只看該作者
液晶的焊接方法不錯,有個優(yōu)點是方便拆下來,今年焊過一次直插,拆時把腳剪了一段,后改成此法焊接。
HT1621的字編碼可以優(yōu)化一下,一維數(shù)組就可以了。顯示時發(fā)送的是一個char就行。
ID:718536 發(fā)表于 2020-11-27 21:24 | 只看該作者
溫控部分有加入PID算法嗎?
ID:19198 發(fā)表于 2021-1-3 22:53 | 只看該作者
簡化一下,留存?zhèn)渫?br />
  1. uchar code bianma[][8]={                //0~9數(shù)字數(shù)組
  2.     {0x01,0x01,0x01,0x00,0x01,0x01,0x01,0x00},//0                                  0
  3.     {0x00,0x00,0x01,0x00,0x00,0x01,0x00,0x00},//1                                  1
  4.     {0x01,0x00,0x01,0x01,0x01,0x00,0x01,0x00},//2                                  2
  5.     {0x01,0x00,0x01,0x01,0x00,0x01,0x01,0x00},//3                                  3
  6.     {0x00,0x01,0x01,0x01,0x00,0x01,0x00,0x00},//4                                  4
  7.     {0x01,0x01,0x00,0x01,0x00,0x01,0x01,0x00},//5                                  5
  8.     {0x01,0x01,0x00,0x01,0x01,0x01,0x01,0x00},//6                                  6
  9.     {0x01,0x00,0x01,0x00,0x00,0x01,0x00,0x00},//7                                  7
  10.     {0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x00},//8                                  8
  11.     {0x01,0x01,0x01,0x01,0x00,0x01,0x01,0x00},//9                                        9
  12.           {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01},//AUTO 10                10
  13.           {0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//上半圓                11
  14.     {0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00},//圓雙線                12
  15.     {0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00},//TEMP                        13
  16.     {0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00},//ROOM                        14
  17.     {0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00},//SET                                15
  18.     {0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x00},//下半圓hr        16
  19.     {0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00},//線條                        17
  20.           {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01},//FAN                                18
  21.           {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//滅                     19
void SMG_SX(shi,ge,xiaoshu,low,high,xian,yuanxian,tmp)//段碼屏顯示函數(shù),數(shù)據(jù)轉(zhuǎn)換
                uchar j,t;
                uchar a0,a1,a2,a3;
        for(j=0;j<8;j++)
            a0=(bianma[shi][j]);
                                                a1=(bianma[ge][j]|bianma[high][j]);
                                                a2=(bianma[xiaoshu][j]|bianma[low][j]);
                                                a3=(bianma[yuanxian][j]|bianma[tmp][j]);
                                                a1<<=1;
                                                a2<<=2;
                                                a3<<=3;
                                                t=(a0|a1|a2|a3);
            Ht1621WrOneData(j,t);  //寫入1621顯示緩存
ID:201953 發(fā)表于 2021-1-11 08:47 | 只看該作者
感謝分享。學習一下段式液晶的輸出格式輸出。
ID:282074 發(fā)表于 2021-1-16 07:56 來自觸屏版 | 只看該作者
trm999 發(fā)表于 2021-1-3 22:53
里面的板子可以一塊兒打樣
ID:381171 發(fā)表于 2021-6-1 11:26 | 只看該作者
學習的道路因為有51黑論壇更容易了!非常感謝!
ID:137736 發(fā)表于 2022-9-3 18:23 | 只看該作者
1621驅(qū)動很好
ID:507641 發(fā)表于 2022-9-8 08:48 | 只看該作者
f556 發(fā)表于 2020-4-30 15:18
HT16 ...
詳細點,上個實例
ID:507641 發(fā)表于 2022-9-19 08:40 | 只看該作者
請問屏的型號或者連接?謝謝
ID:977861 發(fā)表于 2022-10-3 13:29 | 只看該作者
測溫是多少到多少呀
ID:102702 發(fā)表于 2022-11-10 22:57 | 只看該作者
樓主能上個電路圖嗎?
ID:624729 發(fā)表于 2023-4-18 21:20 | 只看該作者
非常精彩,學到不少,多謝。
ID:437013 發(fā)表于 2025-6-3 09:47 | 只看該作者
學習,正好遇到了ht1621驅(qū)動段碼屏
