查看: 13136|回復: 5
單片機4*4矩陣鍵盤按鍵控制led燈的程序及仿真
通過1-8按鍵顯示逐個燈亮一個。9全滅。。10左移一位依次類推。。。這是一個簡單的單片機例子,下面是仿真原理圖:
所有資料打包下載: 4乘4按鍵控制燈.zip (52.31 KB, 下載次數: 79)
原理圖:
  1. #include <reg52.h>
  2. #include<intrins.h>
  3. typedef  unsigned char   int8;
  4. typedef  unsigned int    int16;
  5. sbit KeyIn1  = P1^0;
  6. sbit KeyIn2  = P1^1;
  7. sbit KeyIn3  = P1^2;
  8. sbit KeyIn4  = P1^3;
  9. sbit KeyOut1 = P1^4;
  10. sbit KeyOut2 = P1^5;
  11. sbit KeyOut3 = P1^6;
  12. sbit KeyOut4 = P1^7;
  13. void delay(void);
  14. void delay1s(void)
  15. {
  16.     unsigned char a,b,c;
  17.     for(c=167;c>0;c--)
  18.         for(b=171;b>0;b--)
  19.             for(a=16;a>0;a--);
  20.                         }
  21. main()
  22. {        int8 i;
  23.         P0 = 0xFF;
  24.         while (1)
  25.         {
  26.                 KeyOut1 = 0;
  27.                 KeyOut2 = 1;
  28.                 KeyOut3 = 1;
  29.                 KeyOut4 = 1;
  30.                 if(KeyIn1 == 0)
  31.                 {
  32.                         delay();
  33.                         if(KeyIn1 == 0)
  34.                          { i=0 ;P0 = 0xfe;  }
  35.                 }
  36.                 if(KeyIn2 == 0)
  37.                 {
  38.                         delay();
  39.                         if(KeyIn2 == 0)
  40.                           { i=0 ; P0 = 0xe0;}
  41.                 }
  42.                 if(KeyIn3 == 0)
  43.                 {
  44.                         delay();
  45.                         if(KeyIn3 == 0)
  46.                         { i=0 ; P0=0Xff; }
  47.
  48.                 }
  49.                 if(KeyIn4 == 0)
  50.                 {
  51.                         delay();
  52.                         if(KeyIn4 == 0)
  53.                           {i=1;P0=0XF0;}
  54.                 }
  55.                 while((KeyIn1 == 0)||(KeyIn2 == 0)||
  56.                       (KeyIn3 == 0)||(KeyIn4 == 0));
  57.
  58.                 KeyOut1 = 1;
  59.                 KeyOut2 = 0;
  60.                 KeyOut3 = 1;
  61.                 KeyOut4 = 1;
  62.                 if(KeyIn1 == 0)
  63.                 {
  64.                         delay();
  65.                         if(KeyIn1 == 0)
  66.                          { i=0 ;  P0 = 0xfc;   }
  67.                 }
  68.                 if(KeyIn2 == 0)
  69.                 {
  70.                         delay();
  71.                         if(KeyIn2 == 0)
  72.                          { i=0 ;  P0 = 0xc0; }
  73.                 }
  74.                 if(KeyIn3 == 0)
  75.                 {
  76.                         delay();
  77.                         if(KeyIn3 == 0)
  78.                          {  i=1;  P0=0XFE;}
  79.                 }
  80.                 if(KeyIn4 == 0)
  81.                 {
  82.                         delay();
  83.                         if(KeyIn4 == 0)
  84.                            {i=1;P0=0XE0;}
  85.                 }
  86.                 while((KeyIn1 == 0)||(KeyIn2 == 0)||
  87.                       (KeyIn3 == 0)||(KeyIn4 == 0));
  88.                 KeyOut1 = 1;
  89.                 KeyOut2 = 1;
  90.                 KeyOut3 = 0;
  91.                 KeyOut4 = 1;
  92.                 if(KeyIn1 == 0)
  93.                 {
  94.                         delay();
  95.                         if(KeyIn1 == 0)
  96.                         { i=0 ;   P0 = 0xf8;  }
  97.                 }
  98.                 if(KeyIn2 == 0)
  99.                 {
  100.                         delay();
  101.                         if(KeyIn2 == 0)
  102.                         { i=0 ;   P0 = 0x80; }
  103.                 }
  104.                 if(KeyIn3 == 0)
  105.                 {
  106.                         delay();
  107.                         if(KeyIn3 == 0)
  108.                           {i=1;P0=0XFC;}
  109.                 }
  110.                 if(KeyIn4 == 0)
  111.                 {
  112.                         delay();
  113.                         if(KeyIn4 == 0)
  114.                             {i=1;P0=0XC0;}
  115.                 }
  116.                 while((KeyIn1 == 0)||(KeyIn2 == 0)||
  117.                       (KeyIn3 == 0)||(KeyIn4 == 0));
  118.                 KeyOut1 = 1;
  119.                 KeyOut2 = 1;
  120.                 KeyOut3 = 1;
  121.                 KeyOut4 = 0;
  122.                 if(KeyIn1 == 0)
  123.                 {
  124.                         delay();
  125.                         if(KeyIn1 == 0)
  126.                          { i=0 ;   P0 = 0xf0; }
  127.                 }
  128.                 if(KeyIn2 == 0)
  129.                 {
  130.                         delay();
  131.                         if(KeyIn2 == 0)
  132.                           { i=0 ;  P0 = 0x00;}
  133.                 }
  134.                 if(KeyIn3 == 0)
  135.                 {
  136.                         delay();
  137.                         if(KeyIn3 == 0)
  138.                         {i=1;P0=0XF8;}
  139.                 }
  140.                 if(KeyIn4 == 0)
  141.                 {
  142.                         delay();
  143.                         if(KeyIn4 == 0)
  144.                           {i=1;P0=0X80;}
  145.                 }
  146.
  147.            while((KeyIn1 == 0)||(KeyIn2 == 0)||
  148.                       (KeyIn3 == 0)||(KeyIn4 == 0));
  149.                 switch(i)
  150.                 {        case 0: P0=P0;break;
  151.                         case 1: P0=_crol_(P0,1);delay1s(); break;
  152.
  153.                         default:
  154.                           P0=0XFF;
  155.
  156.                 }
  157.
  158.         }
  159. }
  160. void delay(void)
  161. {
  162.         int16 i=500;
  163.         while (i--);
  164. }
收藏收藏2 分享淘帖 頂 踩
ID:110866 發表于 2016-12-1 23:19 | 只看該作者
感謝分享,學習到了
ID:159790 發表于 2017-5-14 12:42 | 只看該作者
謝謝分享
ID:867353 發表于 2020-12-24 20:28 來自觸屏版 | 只看該作者
有沒有詳細解釋??
ID:867353 發表于 2020-12-24 20:31 來自觸屏版 | 只看該作者
求大神解釋代碼
ID:896773 發表于 2021-4-19 14:45 | 只看該作者
代碼有注釋嗎?
