查看: 4520|回復: 1
單片機萬年歷仿真及源程序和protel畫的原理圖
萬年歷的所有資料下載:
萬年歷.zip (118.48 KB, 下載次數: 48)
源程序:
  1. #include<reg52.h>
  2. #define uint unsigned int
  4. uchar code table[]={"0000-00-00"};
  5. uchar code table1[]={"00:00:00"};
  6. uchar code table2[]={"MONTUSWEDTHUFRISATSUN"};
  7. sbit rs=P2^0;
  8. sbit rw=P2^1;
  9. sbit e=P2^2;
  10. sbit key1=P2^3;
  11. sbit key2=P2^4;
  12. sbit key3=P2^5;
  13. char num,shi1=0,fen=0,miao=0,ri=0,yue=0;uchar xingqi=1;
  14. int nianqian=0,nianhou=0;
  15. void delay(unsigned int z)
  16. {
  17.         uchar x,y;
  18.         for(x=z;x>0;x--)
  19.                 for(y=110;y>0;y--);
  20. }
  21. void write_com(uchar com)
  22. {
  23.
  24.         rs=0;
  25.         rw=0;
  26.         P0=com;
  27.         delay(5);
  28.         e=1;
  29.         delay(5);
  30.         e=0;
  31. }
  32. void write_data(uchar date)
  33. {
  34. rs=1;
  35. rw=0;
  36. P0=date;
  37. delay(5);
  38. e=1;
  39. delay(5);
  40. e=0;
  41. }
  42. void init()
  43. {
  44.         rs=0;
  45.         write_com(0x38);
  46.         write_com(0x0c);
  47.         write_com(0x06);
  48.         write_com(0x01);
  49.         delay(5);
  50. }
  51. void write_wang(uchar add,uchar date)
  52. {
  53.         uchar shi,ge;
  54.         shi=date/10;
  55.         ge=date%10;
  56.         write_com(0x80+0X40+add);
  57.         write_data(0x30+shi);
  58.         write_data(0x30+ge);
  59.
  60. }
  61. void write_wang1(uchar add,uchar date)
  62. {
  63.         uchar shi,ge;
  64.         shi=date/10;
  65.         ge=date%10;
  66.         write_com(0x80+add);
  67.         write_data(0x30+shi);
  68.         write_data(0x30+ge);
  69. }
  70. void write_wang2(uchar add,int date)
  71. {
  72.         uchar shi,ge;
  73.         shi=date/10;
  74.         ge=date%10;
  75.         write_com(0x80+add);
  76.         write_data(0x30+shi);
  77.         write_data(0x30+ge);
  78. }
  79. void keycan()
  80. {
  81.         uchar i;uchar num1;
  82.         if(key1==0)
  83.         {
  84.                 delay(1);
  85.                 if(key1==0)
  86.                 {
  87.                         num1++;
  88.                         while(!key1);
  89.                         if(num1==1)
  90.                         {
  91.                                 TR0=0;
  92.                                 write_com(0x80+0x40+7);
  93.                                 write_com(0x0f);
  94.                         }
  95.                 }
  96.                         if(num1==2)
  97.                         {
  98.                         write_com(0x80+0x40+4);
  99.                         }
  100.                         if(num1==3)
  101.                         {
  102.                                 write_com(0x80+0x40+1);
  103.
  104.                         }
  105.                         if(num1==4)
  106.                         {
  107.                                 write_com(0x80+9);
  108.                         }
  109.                         if(num1==5)
  110.                         write_com(0x80+6);
  111.                         if(num1==6)
  112.                         write_com(0x80+3);
  113.                         if(num1==7)
  114.                         write_com(0x80+1);
  115.                         if(num1==8)
  116.                            write_com(0x80+13);
  117.                         if(num1>=9)
  118.                         {
  119.                         num1=0;
  120.                         TR0=1;
  121.                         write_com(0x0c);
  122.                         }
  123.         }
  124.         if(num1!=0)
  125.                 {
  126.                  if(key2==0)
  127.                         {
  128.                                 delay(1);
  129.                                 if(key2==0)
  130.                                 {
  131.                                         while(key2!=1);
  132.                                         if(num1==1)
  133.                                         {
  134.                                         miao++;
  135.                                         if(miao==60)
  136.                                                 {
  137.                                                 miao=0;
  138.                                                 }
  139.                                         write_wang(6,miao);
  140.                                         write_com(0x80+0x40+6);
  141.                                         }
  142.                                         if(num1==2)
  143.                                         {
  144.                                         fen++;
  145.                                                 if(fen==60)
  146.                                                 {
  147.                                                 fen=0;
  148.                                                 }
  149.                                         write_wang(3,fen);
  150.                                         write_com(0x80+0x40+3);
  151.                                         }
  152.                                         if(num1==3)
  153.                                         {
  154.                                         shi1++;
  155.                                                 if(shi1==24)
  156.                                                 {
  157.                                                 shi1=0;
  158.                                                 }
  159.                                                 write_wang(0,shi1);
  160.                                         write_com(0x80+0x40);
  161.                                         }
  162.                                         if(num1==4)
  163.                                         {
  164.                                         ri++;
  165.                                         if(yue==1||yue==3||yue==5||yue==7||yue==8||yue==10||yue==12)
  166.                                         {
  167.                                                 if(ri==32)
  168.                                                 {
  169.                                                 ri=1;
  170.                                                 }
  171.                                         }
  172.                                         else if(yue==2)
  173.                                                 {
  174.                                                  if((nianqian*100+nianhou)%4==0 && (nianqian*100+nianhou)%100!=0 || (nianqian*100+nianhou)%400==0 )
  175.                                                         {
  176.        if(ri==30)
  177.        ri=1;
  178.                                                         }
  179.                                                         else
  180.                                                         {
  181.        if(ri==29)
  182.        ri=1;
  183.                                                         }
  184.                                                 }
  185.                                         else
  186.                                                 {
  187.                                                         if(ri==31)
  188.                                                         ri=1;
  189.                                                 }
  190.                                         write_wang1(8,ri);
  191.                                         write_com(0x80+8);
  192.                                         }
  193.                                         if(num1==5)
  194.                                         {
  195.                                         yue++;
  196.                                                 if(yue==13)
  197.                                                 {
  198.                                                 yue=1;
  199.                                                 }
  200.                                                 write_wang1(5,yue);
  201.                                         write_com(0x80+5);
  202.                                         }
  203.                                         if(num1==6)
  204.                                         {
  205.                                                          nianhou++;
  206.                                                 if(nianhou==100)
  207.                                                 {
  208.                                                 nianhou=0;
  209.                                                 }
  210.                                                 write_wang2(2,nianhou);
  211.                                         write_com(0x80+2);
  212.                                         }
  213.                                         if(num1==7)
  214.                                         {        nianqian++;
  215.                                                 if(nianqian==100)
  216.                                                 {
  217.                                                 nianqian=0;
  218.                                                 }
  219.                                                 write_wang2(0,nianqian);
  220.                                         write_com(0x80);
  221.
  222.                                         }
  223.                                         if(num1==8)
  224.                                         {
  225.                                                 xingqi++;
  226.                                                 if(xingqi==8)
  227.                                                 xingqi=1;
  228.                                                         switch(xingqi)
  229.                                                 {
  230.                                                         case 1:
  231.        write_com(0x80+13);
  232.        for(i=0;i<3;i++)
  233.        {
  234.        write_data(table2[i]);
  235.        }
  236.        break;
  237.                                                         case 2:
  238.        write_com(0x80+13);
  239.        for(i=3;i<6;i++)
  240.        {
  241.        write_data(table2[i]);
  242.        }
  243.        break;
  244.                                                         case 3:
  245.        write_com(0x80+13);
  246.        for(i=6;i<9;i++)
  247.        {
  248.        write_data(table2[i]);
  249.        }
  250.        break;
  251.                                                           case 4:
  252.        write_com(0x80+13);
  253.        for(i=9;i<12;i++)
  254.        {
  255.        write_data(table2[i]);
  256.        }
  257.        break;
  258.                                                     case 5:
  259.        write_com(0x80+13);
  260.        for(i=12;i<15;i++)
  261.        {
  262.        write_data(table2[i]);
  263.        }
  264.        break;
  265.                                                          case 6:
  266.        write_com(0x80+13);
  267.        for(i=15;i<18;i++)
  268.        {
  269.        write_data(table2[i]);
  270.        }
  271.        break;
  272.                                                            case 7:
  273.        write_com(0x80+13);
  274.        for(i=18;i<21;i++)
  275.        {
  276.        write_data(table2[i]);
  277.        }
  278.        break;
  279.                                                 }
  280.                                         }
  281.                                 }
  282.                         }
  283.         if(num1!=0)
  284.                 {
  285.                  if(key3==0)
  286.                         {
  287.                                 delay(5);
  288.                                 if(key3==0)
  289.                                 {
  290.                                         while(key3!=1);
  291.                                         if(num1==1)
  292.                                         {
  293.                                         miao--;
  294.                                         if(miao==-1)
  295.                                                 {
  296.                                                 miao=59;
  297.                                                 }
  298.                                         write_wang(6,miao);
  299.                                         write_com(0x80+0x40+6);
  300.                                         }
  301.                                         if(num1==2)
  302.                                         {
  303.                                         fen--;
  304.                                                 if(fen==-1)
  305.                                                 {
  306.                                                 fen=59;
  307.                                                 }
  308.                                         write_wang(3,fen);
  309.                                         write_com(0x80+0x40+3);
  310.                                         }
  311.                                         if(num1==3)
  312.                                         {
  313.                                         shi1--;
  314.                                                 if(shi1==-1)
  315.                                                 {
  316.                                                 shi1=23;
  317.                                                 }
  318.                                                 write_wang(0,shi1);
  319.                                         write_com(0x80+0x40);
  320.                                         }
  321.                                         if(num1==4)
  322.                                         {
  323.                                         ri--;
  324.                                         if(yue==1||yue==3||yue==5||yue==7||yue==8||yue==10||yue==12)
  325.                                         {
  326.                                                 if(ri==-1)
  327.                                                 {
  328.                                                 ri=31;
  329.                                                 }
  330.                                         }
  331.                                         else if(yue==2)
  332.                                                 {
  333.                                                         if(((nianqian*100+nianhou)%4==0 && (nianqian*100+nianhou)%100!=0 || (nianqian*100+nianhou)%400==0 ))
  334.                                                         {
  335.                                                         if(ri==-1)
  336.                                                         ri=29;
  337.                                                         }
  338.                                                         else
  339.                                                         {
  340.        if(ri==-1)
  341.        ri=28;
  342.                                                         }
  343.                                                 }
  344.                                         else
  345.                                                 {
  346.                                                         if(ri==-1)
  347.                                                         ri=30;
  348.                                                 }
  349.                                         write_wang1(8,ri);
  350.                                         write_com(0x80+8);
  351.                                         }
  352.                                         if(num1==5)
  353.                                         {
  354.                                         yue--;
  355.                                                 if(yue==0)
  356.                                                 {
  357.                                                 yue=12;
  358.                                                 }
  359.                                                 write_wang1(5,yue);
  360.                                         write_com(0x80+5);
  361.                                         }
  362.                                         if(num1==6)
  363.                                         {
  364.                                                         nianhou--;
  365.                                                 if(nianhou==-1)
  366.                                                 {
  367.                                                 nianhou=99;
  368.                                                 }
  369.                                         write_wang2(2,nianhou);
  370.                                         write_com(0x80+2);
  371.                                         }
  372.                                         if(num1==7)
  373.                                         {
  374.                                                  nianqian--;
  375.                                                 if(nianqian==-1)
  376.                                                 {
  377.                                                 nianqian=99;
  378.                                                 }
  379.                                          write_wang2(0,nianqian);
  380.                                         write_com(0x80);
  381.                                         }
  382.                                         if(num1==8)
  383.                                         {
  384.                                                 xingqi--;
  385.                                                 if(xingqi==0)
  386.                                                 xingqi=7;
  387.                                                         switch(xingqi)
  388.                                                 {
  389.                                                         case 1:
  390.        write_com(0x80+13);
  391.        for(i=0;i<3;i++)
  392.        {
  393.        write_data(table2[i]);
  394.        }
  395.        break;
  396.                                                         case 2:
  397.        write_com(0x80+13);
  398.        for(i=3;i<6;i++)
  399.        {
  400.        write_data(table2[i]);
  401.        }
  402.        break;
  403.                                                         case 3:
  404.        write_com(0x80+13);
  405.        for(i=6;i<9;i++)
  406.        {
  407.        write_data(table2[i]);
  408.        }
  409.        break;
  410.                                                           case 4:
  411.        write_com(0x80+13);
  412.        for(i=9;i<12;i++)
  413.        {
  414.        write_data(table2[i]);
  415.        }
  416.        break;
  417.                                                     case 5:
  418.        write_com(0x80+13);
  419.        for(i=12;i<15;i++)
  420.        {
  421.        write_data(table2[i]);
  422.        }
  423.        break;
  424.                                                          case 6:
  425.        write_com(0x80+13);
  426.        for(i=15;i<18;i++)
  427.        {
  428.        write_data(table2[i]);
  429.        }
  430.        break;
  431.                                                            case 7:
  432.        write_com(0x80+13);
  433.        for(i=18;i<21;i++)
  434.        {
  435.        write_data(table2[i]);
  436.        }
  437.        break;
  438.                                                 }
  439.                                         }
  440.                                 }
  441.                         }
  442.                 }
  443. }
  444. }
  445. void duxianshi()
  446. {
  447.                 write_com(0x80);
  448.                 for(num=0;num<10;num++)
  449.                 {
  450.                 write_data(table[num]);
  451.                 delay(5);
  452.                 }
  453.                 write_com(0x80+13);
  454.                 for(num=0;num<3;num++)
  455.                 {
  456.                         write_data(table2[num]);
  457.                         delay(5);
  458.                 }
  459.                 write_com(0x80+0x40);
  460.                 for(num=0;num<8;num++)
  461.                 {
  462.                         write_data(table1[num]);
  463.                         delay(5);
  464.                 }
  465. }
  466. void time()
  467. {
  468.         uchar i;
  469.                         if(num==18)
  470.                                 {
  471.                                         num=0;
  472.                                         miao++;
  473.                                         if(miao==60)
  474.                                     {
  475.        miao=0;
  476.        fen++;
  477.        if(fen==60)
  478.        {
  479.        fen=0;
  480.        shi1++;
  481.        if(shi1==24)
  482.        {
  483.        shi1=0;
  484.        ri++;
  485.        xingqi++;
  486.        if(xingqi==8)
  487.        xingqi=1;
  488.        switch(xingqi)
  489.        {
  490.        case 1:
  491.        write_com(0x80+13);
  492.        for(i=0;i<3;i++)
  493.        {
  494.        write_data(table2[i]);
  495.        }
  496.        break;
  497.        case 2:
  498.        write_com(0x80+13);
  499.        for(i=3;i<6;i++)
  500.        {
  501.        write_data(table2[i]);
  502.        }
  503.        break;
  504.        case 3:
  505.        write_com(0x80+13);
  506.        for(i=6;i<9;i++)
  507.        {
  508.        write_data(table2[i]);
  509.        }
  510.        break;
  511.        case 4:
  512.        write_com(0x80+13);
  513.        for(i=9;i<12;i++)
  514.        {
  515.        write_data(table2[i]);
  516.        }
  517.        break;
  518.        case 5:
  519.        write_com(0x80+13);
  520.        for(i=12;i<15;i++)
  521.        {
  522.        write_data(table2[i]);
  523.        }
  524.        break;
  525.        case 6:
  526.        write_com(0x80+13);
  527.        for(i=15;i<18;i++)
  528.        {
  529.        write_data(table2[i]);
  530.        }
  531.        break;
  532.        case 7:
  533.        write_com(0x80+13);
  534.        for(i=18;i<21;i++)
  535.        {
  536.        write_data(table2[i]);
  537.        }
  538.        break;
  539.        }
  540.        if(yue==1||yue==3||yue==5||yue==7||yue==8||yue==10||yue==12)
  541.        {
  542.        if(ri==32)
  543.        {
  544.        ri=1;
  545.        yue++;
  546.        if(yue==13)
  547.        {
  548.        yue=1;
  549.        nianhou++;
  550.        if(nianhou==100)
  551.        {
  552.        nianhou=0;
  553.        nianqian++;
  554.        if(nianqian==100)
  555.        {
  556.        nianqian=0;
  557.        nianhou=0;
  558.        yue=0;
  559.        ri=0;
  560.        shi1=0;
  561.        fen=0;
  562.        miao=0;
  563.        write_com(0x80+13);
  564.        for(i=0;i<3;i++)
  565.        {
  566.        write_data(table2[i]);
  567.        }
  568.        }
  569.        write_wang2(0,nianqian);
  570.        }
  571.        write_wang2(2,nianhou);
  572.        }
  573.        write_wang1(5,yue);
  574.        }
  575.        write_wang1(8,ri);
  576.        }
  577.        else if(yue==2)
  578.        {
  579.        if(ri==29)
  580.        {
  581.        ri=1;
  582.        yue++;
  583.        if(yue==13)
  584.        {
  585.        yue=1;
  586.        nianhou++;
  587.        if(nianhou==100)
  588.        {
  589.        nianhou=0;
  590.        nianqian++;
  591.        if(nianqian==100)
  592.        {
  593.        nianqian=0;
  594.        nianhou=0;
  595.        yue=0;
  596.        ri=0;
  597.        shi1=0;
  598.        fen=0;
  599.        miao=0;
  600.        write_com(0x80+13);
  601.        for(i=0;i<3;i++)
  602.        {
  603.        write_data(table2[i]);
  604.        }
  605.        }
  606.        write_wang2(0,nianqian);
  607.        }
  608.        write_wang2(2,nianhou);
  609.        }
  610.        write_wang1(5,yue);
  611.        }
  612.        write_wang1(8,ri);
  613.        }
  614.        else
  615.        {
  616.        if(ri==31)
  617.        {
  618.        ri=1;
  619.        yue++;
  620.        if(yue==13)
  621.        {
  622.        yue=1;
  623.        nianhou++;
  624.        if(nianhou==100)
  625.        {
  626.        nianhou=0;
  627.        nianqian++;
  628.        if(nianqian==100)
  629.        {
  630.        nianqian=0;
  631.        nianhou=0;
  632.        yue=0;
  633.        ri=0;
  634.        shi1=0;
  635.        fen=0;
  636.        miao=0;
  637.        write_com(0x80+13);
  638.        for(i=0;i<3;i++)
  639.        {
  640.        write_data(table2[i]);
  641.        }
  642.        }
  643.        write_wang2(0,nianqian);
  644.        }
  645.        write_wang2(2,nianhou);
  646.        }
  647.        write_wang1(5,yue);
  648.        }
  649.        write_wang1(8,ri);
  650.        }
  651.        }
  652.        write_wang(0,shi1);
  653.                                 }
  654.                                 write_wang(3,fen);
  655.         }
  656.         write_wang(6,miao);
  657. }
  658. }
  659. void main()
  660. {
  661.     EA=1;
  662.         ET0=1;
  663.         TMOD=0X01;
  664.         TH0=(65536-50000)/256;
  665.         TL0=(65536-50000)%256;
  666.         init();
  667.         duxianshi();
  668.         num=0;
  669.         TR0=1;
  670.                 while(1)
  671.                 {
  672.                            time();
  673.                         keycan();
  674. }
  675. }
  676. void T0_time()interrupt 1
  677. {
  678.         TH0=(65536-50000)/256;
  679.         TL0=(65536-50000)%256;
  680.         num++;
  681. }
ID:211038 發表于 2017-6-14 09:50 | 只看該作者
大神在嘛
