查看: 2020|回復: 0
輸入數字控制蜂鳴器以不同頻率響
ID:139210 發表于 2016-9-12 16:53 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
sbit beep=P1^5;
void xiang(unsigned char);
void init(void);
void chushi(void);
unsigned char a,num;
unsigned int n;
        init();
                if(RI==1)                          //½óêÕ¼ì2a
                        RI=0;
                        P0=SBUF;                 //ledÏÔê¾½óêÕμ½μÄêy¾Y
                        num=SBUF;
                        xiang(num);                 //¸ù¾Y½óêÕμ½μÄêy¾YéèÖÃÆμÂê
           if(n>10*a)        ////////ìØ±eÇ¿μ÷£oμ±D′Îan==10*aê±£¬3ìDò3ö′í////////                        //////////
                           TR0=0;
                           n=0;                                  //′ÎêyÇåáã
                        beep=~beep;
                        TR0=1;
void xiang(unsigned char num)
       TR0=0;                                                 //μ±½óêÕμ½μÄêy×Ö2»êÇÔ¤éèêy×Öê±£¬1رն¨ê±Æ÷T0
           //EA=0;
           chushi();
       if(num==0x01) {a=4; TR0=1;  }        //ÎaóDD§DÅoÅÔò′ò¿aT0
           if(num==0X02) {a=2;TR0=1;}
           if(num==0X03){a=1;TR0=1;}
           //EA=1;
void time0() interrupt 1
          TR0=0;
          TH0=(65536-10000)/256;
          TL0=(65536-10000)%256;
          n++;
          TR0=1;
void init()
        a=0;
        n=0;
        num=0;
    SCON=0X50;                        //′®¿úí¨DÅ1¤×÷·½ê½éèÖÃÎa·½ê½1
        TMOD=0X21;                        //éèÖüÆêyÆ÷1¤×÷·½ê½£¬T1Îa×Ô¶ˉ֨װ·½ê½£¬T0Îa16λ¼Æêy
        PCON=0X80;                         //2¨ìØÂê¼ó±¶
        TH1=0XF3;                        //×°3õÖ죬éèÖÃ2¨ìØÂê
        TL1=0XF3;
        TH0=(65536-10000)/256;                  //T03õê¼ÖμéèÖÃ(10ms)        0xd8
        TL0=(65536-10000)%256;        //f0
        TR1=1;                                 //¿a¼Æê±Æ÷1
        //TR0=1;
        EA=1;
        ET0=1;
void chushi()
