查看: 2476|回復: 2
16*16滾動點陣 仿真及源程序
  1. /*****************************************************
  2. 制作:長江大學電信學院創新實驗室梅旭紅2018.4.
  3. QQ:707378760
  4. Email:mxh20999@163.com
  5. *****************************************************/
  6. #include<reg52.h>
  7. unsigned char i;
  8. unsigned int j;
  9. unsigned int a;
  10. unsigned int b;
  11. unsigned long int code table[]={
  12.                                                      0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  13.                                                         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  14.                                                         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  15.                                                         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  16.
  17.                                                         0x20,0x02,0x1C,0x02,0x10,0x01,0xFF,0xFF,
  18.                                                         0x90,0x00,0xB0,0x00,0x24,0x01,0x24,0x05,
  19.                                                         0x24,0x19,0x3F,0x41,0x24,0x81,0xE4,0x7F,
  20.                                                         0x24,0x01,0x24,0x01,0x20,0x01,0x00,0x00,/*"特",0*/
  21.                                                       0x00,0x80,0xF8,0x47,0x00,0x20,0x00,0x18,
  22.                                                         0xFF,0x07,0x00,0x00,0xF8,0x1F,0x08,0x00,
  23.                                                         0x08,0x00,0x08,0x00,0xFF,0xFF,0x08,0x00,
  24.                                                         0x08,0x08,0x08,0x18,0xF8,0x0F,0x00,0x00,/*"帥",1*/
  25.
  26.                                                         0x00,0x00,0x50,0x00,0x4F,0x3F,0x4A,0x01,
  27.                                                         0x48,0x01,0xFF,0xFF,0x48,0x21,0x48,0x61,
  28.                                                         0x48,0x3F,0x00,0x00,0xFC,0x0F,0x00,0x40,
  29.                                                         0x00,0x80,0xFF,0x7F,0x00,0x00,0x00,0x00,/*"制",0*/
  30.                                                         0x80,0x00,0x40,0x00,0x20,0x00,0xF8,0xFF,
  31.                                                         0x07,0x00,0x22,0x00,0x18,0x00,0x0C,0x00,
  32.                                                         0xFB,0xFF,0x48,0x04,0x48,0x04,0x48,0x04,
  33.                                                         0x68,0x04,0x48,0x06,0x08,0x04,0x00,0x00,/*"作",1*/
  34.                                                         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  35.                                                         0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x27,
  36.                                                         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"!",0*/
  37.                                                         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  38.                                                         0x80,0x80,0x80,0xFF,0x00,0xA1,0x80,0x20,
  39.                                                         0x80,0x20,0x00,0x11,0x00,0x0E,0x00,0x00,/*"p",0*/
  40.                                                         0x80,0x20,0x80,0x20,0x80,0x3F,0x00,0x21,
  41.                                                         0x80,0x20,0x80,0x00,0x80,0x01,0x00,0x00,/*"r",1*/
  42.                                                         0x00,0x00,0x00,0x1F,0x80,0x20,0x80,0x20,
  43.                                                         0x80,0x20,0x80,0x20,0x00,0x1F,0x00,0x00,/*"o",2*/
  44.                                                         0x00,0x00,0x80,0x00,0x80,0x00,0xE0,0x1F,
  45.                                                         0x80,0x20,0x80,0x20,0x00,0x00,0x00,0x00,/*"t",3*/
  46.                                                         0x00,0x00,0x00,0x1F,0x80,0x22,0x80,0x22,
  47.                                                         0x80,0x22,0x80,0x22,0x00,0x13,0x00,0x00,/*"e",4*/
  48.                                                         0x80,0x00,0x80,0x1F,0x00,0x20,0x00,0x20,
  49.                                                         0x00,0x20,0x80,0x10,0x80,0x3F,0x00,0x20,/*"u",5*/
  50.                                                         0x00,0x00,0x00,0x33,0x80,0x24,0x80,0x24,
  51.                                                         0x80,0x24,0x80,0x24,0x80,0x19,0x00,0x00,/*"s",6*/
  52.                                                         0x00,0x00,0x00,0x30,0x00,0x30,0x00,0x00,
  53.                                                         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*".",0*/
  54.                                                         0x00,0x00,0xF8,0x19,0x08,0x21,0x88,0x20,
  55.                                                         0x88,0x20,0x08,0x11,0x08,0x0E,0x00,0x00,/*"5",1*/
  56.                                                         0x00,0x00,0x00,0x0E,0x00,0x11,0x80,0x20,
  57.                                                         0x80,0x20,0x88,0x10,0xF8,0x3F,0x00,0x20,/*"d",2*/
  58.                                                         0x00,0x00,0xE0,0x0F,0x10,0x11,0x88,0x20,
  59.                                                         0x88,0x20,0x18,0x11,0x00,0x0E,0x00,0x00,/*"6",3*/
  60.                                                         0x00,0x00,0x00,0x0E,0x00,0x11,0x80,0x20,
  61.                                                         0x80,0x20,0x88,0x10,0xF8,0x3F,0x00,0x20,/*"d",4*/
  62.                                                         0x00,0x00,0x00,0x30,0x00,0x30,0x00,0x00,
  63.                                                         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*".",5*/
  64.                                                         0x00,0x00,0x00,0x0E,0x00,0x11,0x80,0x20,
  65.                                                         0x80,0x20,0x80,0x20,0x00,0x11,0x00,0x00,/*"c",6*/
  66.                                                         0x00,0x00,0x00,0x1F,0x80,0x20,0x80,0x20,
  67.                                                         0x80,0x20,0x80,0x20,0x00,0x1F,0x00,0x00,/*"o",7*/
  68.                                                         0x80,0x20,0x80,0x3F,0x80,0x20,0x80,0x00,
  69.                                                         0x80,0x3F,0x80,0x20,0x80,0x00,0x00,0x3F,/*"m",8*/
  70.                                                         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  71.                                                         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  72.                                                         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  73.                                                         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  74.                                                         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  75.                                                         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  76.
  77.                                           };
  78. void delay(unsigned int i)
  79. {
  80.                 while(i--);
  81. }
  82. void main()
  83. {
  84.         P2=0;
  85.         P1=0;
  86.         P0=0;
  87.         while(1)
  88.         {
  89.                 j=0;
  90.                 if(a>20)
  91.                         {
  92.                                 a=0;
  93.                                 b+=2;
  94.                                 if(b>=450) b=0;
  95.                         }
  96.                 P3=0x01;
  97.                 for(i=0;i<8;i++)
  98.                         {
  99.                                 P1=i;
  100.                                 P0=table[j+b];
  101.                                 P2=table[j+b+1];
  102.                                 delay(10);
  103.                                 P0=0;
  104.                                 P2=0;
  105.                                 j+=2;
  106.                         }
  107.                  P3=0x02;
  108.                  for(i=0;i<8;i++)
  109.                          {
  110.                                 P1=i;
  111.                                 P0=table[j+b];
  112.                                 P2=table[j+b+1];
  113.                                 delay(10);
  114.                                 P0=0;
  115.                                 P2=0;
  116.                                 j+=2;
  117.                         }
  118.                  a++;
  119.         }
  120. }
16_16滾動點陣.zip
374.64 KB, 下載次數: 26, 下載積分: 黑幣 -5
ID:136460 發表于 2016-9-11 08:15 | 只看該作者
51有你更精彩
ID:137075 發表于 2016-9-11 08:25 | 只看該作者
更精彩
