查看: 7392|回復: 4
PIC32自帶ADC的問題
ID:135490 發表于 2016-7-29 20:41 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
1黑幣
我是想掃描四個通道,AN15,AN14,AN9,AN8,但是每次只能讀取到一個數據,那就是AN8的。程序在下面,請大神指導,調了兩天了。芯片是PIC32MX564
void __ADC10SCAN()
        uint a = 0, b = 0, c = 0, d = 0, e = 0, f = 0, g = 0, h = 0;
        uint i = 0;
        AD1PCFG &= 0x3CFF; // All PORTB = Digital; RB15、14、9、8 = analog
        AD1CON1 = 0x00E4; // SSRC bit = 111 implies internal(自動轉換)
        AD1CHS &= (~BIT(23)); // 選擇VR- 作為MUX A 反相輸入
        // In this example RB12/AN12 is the input
        AD1CSSL |= BIT(15) | BIT(14) | BIT(9) | BIT(8);        //掃描AN15、14、9、8
        AD1CON3 = 0x0F00; // Sample time = 15 TAD
        AD1CON2 &= 0x03E;                //四次產生中斷,總是使用MUX A多路開關,一個16字緩沖區
        AD1CON2 |= BIT(10);        //掃描輸入
        AD1CON1SET = 0x8000; // Turn ON the ADC
        while (1) // Repeat continuously
//                AD1CON1 |= 0x0002; // 啟動采樣
//                while ( ! mAD1GetIntFlag() ) { }
                while (!(AD1CON1 & 0x0001)); // Conversion done?轉換是否完成
                a = ADC1BUF0; // Yes, get ADC value
                b = ADC1BUF1; // Yes, get ADC value
                c = ADC1BUF2; // Yes, get ADC value
                d = ADC1BUF3; // Yes, get ADC value
                e = ADC1BUF4; // Yes, get ADC value
                f = ADC1BUF5; // Yes, get ADC value
                g = ADC1BUF6; // Yes, get ADC value
                h = ADC1BUF7; // Yes, get ADC value
                a = ADC1BUF8; // Yes, get ADC value
                b = ADC1BUF9; // Yes, get ADC value
                c = ADC1BUFA; // Yes, get ADC value
                d = ADC1BUFB; // Yes, get ADC value
                e = ADC1BUFC; // Yes, get ADC value
                f = ADC1BUFD; // Yes, get ADC value
                g = ADC1BUFE; // Yes, get ADC value
                h = ADC1BUFF; // Yes, get ADC value
                i++;
                AD1CON1 & (~0x0001);
ID:195453 發表于 2017-7-25 15:38 | 只看該作者
樓主你是怎么解決的
ID:275095 發表于 2018-5-14 07:27 來自觸屏版 | 只看該作者
每次采樣之后,試著把ADON清零,在換模擬通道
ID:330691 發表于 2018-5-16 13:32 | 只看該作者
我做過一個ad模塊下的多路通道ad:在中斷里面配置1ms定時中斷,在定時中斷里面計數,計數1配置好通道1并打開AD中斷退出,計數2配置好通道2并打開AD中斷退出,計數3配置好通道3并打開AD中斷退出. 然后在AD中斷里面判別是哪個通道就把加過賦值給相應的寄存器
if(ADIE&&ADIF)
                        ADIF=0;
                        ADGO=0;
                        ADIE=0;
if(AD1flag==1)//AN1
                    if(volt_ad_num==0)
                        AD1flag=0;
                        volt_ad_8L=ADRESL;
                        volt_ad_8H=ADRESH;
                        volt_ad_value=volt_ad_8H;
                        volt_ad_value=volt_ad_value<<8;
                        volt_ad_value=volt_ad_value+volt_ad_8L;
                        volt_status=1;
ID:330691 發表于 2018-5-16 13:34 | 只看該作者
配置通道的 程序如下
if(ad_change_time<10)ad_change_time++;   //AD切換間隔時間
                  if(ad_change_time==1)
                ADCON0bits.CHS = 0x00;                        //AD采樣通道設置到電流采樣通道
                                  AD0flag=1;
                                  AD1flag=0;
                                  AD2flag=0;
                                  ADIF=0;
                                  ADIE=1;
                ADGO=1;
                PEIE=1;
                                  GIE=1;
