只需一步,快速開(kāi)始
查看: 2716|回復(fù): 0
新手匯編寫(xiě)的LCD1602數(shù)字時(shí)鐘調(diào)不出來(lái)求指正
ID:118098 發(fā)表于 2016-7-29 16:08 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
匯編寫(xiě)的LCD1602數(shù)字時(shí)鐘調(diào)不出來(lái),一直顯示白屏,用C語(yǔ)言寫(xiě) 的就沒(méi)有問(wèn)題很好用,兩種代碼都貼出來(lái),求指正匯編寫(xiě)的問(wèn)題出在那里好多天了
匯編的代碼
;中斷控制定時(shí)  1602屏顯數(shù)字電子時(shí)鐘
RS bit P2.6
RW bit P2.5
E  bit P2.7
LCD EQU P0
SECOND EQU 60H                         ;秒數(shù)存儲(chǔ)
MINUTE EQU 61H                         ;份鐘存儲(chǔ)
HOUR EQU 62H                         ;小時(shí)存儲(chǔ)
ORG 0000H
AJMP INIT_LCD                         ;初始化
ORG 000BH
AJMP TIME0                                 ;中斷入口
ORG 0030H
MIAN:
AJMP MIAN
INIT_LCD:
MOV B,#10
MOV SECOND,#0
MOV MINUTE,#0
MOV HOUR,#12                          ;12小時(shí)
MOV TMOD,00000001B
MOV TH0,#3CH
MOV TL0,#0B0H
SETB ET0
SETB EA
SETB TR0
;MOV TCON,#00010000B         ;開(kāi)啟計(jì)時(shí)
MOV LCD,#00111000B
ACALL WR_COMM
MOV LCD,#00001110B
ACALL WR_COMM
MOV LCD,#00000100B                 ;當(dāng)讀或?qū)懸粋(gè)字符后地址指紋減1
ACALL WR_COMM
MOV LCD,#00000001B
ACALL WR_COMM
MOV LCD,#87H                         ;液晶屏第一行第8個(gè)字位
ACALL WR_COMM
MOV A,HOUR
DIV AB
MOV LCD,A
ACALL WR_DATA
MOV LCD,B
ACALL WR_DATA
MOV A,MINUTE
DIV AB
MOV LCD,A
ACALL WR_DATA
MOV LCD,B
ACALL WR_DATA
MOV A,SECOND
DIV AB
MOV LCD,A
ACALL WR_DATA
MOV LCD,B
ACALL WR_DATA
MOV LCD,#47H                ; 液晶屏第二行第8個(gè)字位
ACALL WR_COMM
;MOV LCD,#'0'
;ACALL WR_COMM
RET
TIME0:
PUSH ACC
MOV R1,#20                     ;定時(shí)1秒
DJNZ R1,JIXU
INC SECOND                ;秒數(shù)
MOV A,SECOND
MOV R2,SECOND
DIV AB
MOV LCD,B
ACALL WR_DATA
MOV LCD,A
ACALL WR_DATA
MOV LCD,#':'
ACALL WR_DATA
CJNE R2,#60,JIXU
MOV SECOND,#0
INC MINUTE                ;分鐘
MOV A,MINUTE
MOV R2,MINUTE
DIV AB
MOV LCD,B
ACALL WR_DATA
MOV LCD,A
ACALL WR_DATA
MOV LCD,#':'
ACALL WR_DATA
CJNE R2,#60,JIXU
MOV MINUTE,#0
INC HOUR           ;小時(shí)
MOV A,HOUR
MOV R2,HOUR
DIV AB
MOV LCD,B
ACALL WR_DATA
MOV LCD,A
ACALL WR_DATA
CJNE R2,#24,JIXU
MOV HOUR,#0
JIXU:                                          ;中斷延時(shí)
POP ACC
MOV TH0,#3CH
MOV TL0,#0B0H
RETI
WR_COMM:                                  ;寫(xiě)指令
CLR RS
CLR RW
CLR E
ACALL CHECK_BF
;ACALL DLY1
SETB E
;ACALL DLY1
CLR E
RET
WR_DATA:                                   ;寫(xiě)數(shù)據(jù)
SETB RS
CLR RW
CLR E
ACALL CHECK_BF
;ACALL DLY1
SETB E
;ACALL DLY1
;CLR E
RET
CHECK_BF:                           ;判斷忙子程序
MOV LCD,#0FFH
CLR RS
SETB RW
CLR E
NOP
SETB E
JB LCD.7,CHECK_BF
RET
DLY1S:MOV R5,#1           ;cpu延時(shí)
DLY1:MOV R6,#100
DLY2:MOV R7,#100
     DJNZ R7,$
         DJNZ R6,DLY2
        ; DJNZ R5,DLY1
RET
END
C語(yǔ)言寫(xiě)的沒(méi)問(wèn)題很好用
#include<reg52.h>
sbit rs=P2^6;
sbit rw=P2^5;
sbit lcden=P2^7;
//LCD EQU P0
uchar code table[]="  2016-7-26 MON";
uchar code table1[]="    23:59:00";
uint count,shi,fen,miao;
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--) ;
void write_com(uchar com)
        rs=0;
        rw=0;
        lcden=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_date(uchar date)
        rs=1;
        rw=0;
        lcden=0;
        P0=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void init()
        uchar num;
        lcden=0;          //自己加的
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        write_com(0x80);
        for(num=0;num<15;num++)
                 write_date(table[num]);
                 delay(5);
        write_com(0x80+0x40);
        for(num=0;num<12;num++)
                 write_date(table1[num]);
                 delay(5);
        TMOD=0X01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
void write_sfm(uchar add,uchar date)
    uchar shi,ge;
        shi=date/10;
        ge=date%10;
        write_com(0X80+0x40+add);
        write_date(0x30+shi);                                //這里解釋了為什么在上面加上23:59:00
        write_date(0x30+ge);
        init();
        if(count==20)        //定時(shí)1秒種
                count=0;
                miao++;
                if(miao==60)
                        miao=0;
                        fen++;
                        if(fen==60)
                                fen=0;
                                shi++;
                                if(shi==24)
                                        shi=0;
                                write_sfm(4,shi);
                        write_sfm(7,fen);
                write_sfm(10,miao);
        //while(1);
void timer0()  interrupt 1
        count++;
