查看: 2546|回復: 0
1602顯示時間
ID:117161 發(fā)表于 2016-7-23 10:37 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
uchar n,num1,num2,num3,s,g,fs,fg,ss,sg;
uint num;
sbit lcden=P3^4;
sbit lcdrs=P3^5;
uchar code table1[]="I LOVE YOU";
uchar code table[]="0123456789:";
void delay(ms)
{  uint i,j;
for(i=ms;i>0;i--)
   for(j=110;j>0;j--);
void write_com(uchar com)
lcdrs=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_data(uchar date)
lcdrs=1;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void init()
lcden=0;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
void T0_time()interrupt 1
   num++;
   if(num==5000)
   num=0;
   num1++;
   if(num1==60)
num1=0;
   num2++;//?
   if(num2==60)
   num2=0;
   num3++;//?
   if(num3==24)
  num3=0;
   s=num1/10;
   g=num1%10;
   fs=num2/10;
   fg=num2%10;
   ss=num3/10;
   sg=num3%10;
     init();
TMOD=0x02;
TH0=(256-200);
TL0=(256-200);
EA=1;
ET0=1;
TR0=1;
write_com(0x80);
write_data(table[ss]);
     write_data(table[sg]);
     write_data(table[10]);
     write_data(table[fs]);
     write_data(table[fg]);
  write_data(table[s]);
     write_data(table[g]);
write_com(0x80+0x40);
for(n=0;n<10;n++)
  write_data(table1[n]);
