查看: 2049|回復: 0
單片機點陣時鐘源碼
ID:130000 發表于 2016-7-11 12:21 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#define uint unsigned int        //數據類型宏定義,表示范圍從0~65535
#define uchar unsigned char       //數據類型宏定義,表示值范圍從0~255
uchar aa, bb, cc;
uchar miao, fen, shi;
uchar a_1, a_2, a_3, a_4;
uchar num1, num2;
sbit a = P0 ^ 0;//定義管腳
sbit b = P0 ^ 1;//
sbit c = P0 ^ 2;//
sbit d = P0 ^ 3;//
sbit e = P0 ^ 4;//
sbit f = P0 ^ 5;//
sbit g = P0 ^ 6;//
sbit h = P0 ^ 7;//
sbit zuo_1 = P1 ^ 0;//定義管腳
sbit zuo_2 = P1 ^ 1;//
sbit zuo_3 = P1 ^ 2;//
sbit zuo_4 = P1 ^ 3;//
sbit s1 = P1 ^ 4;//定義按鍵
sbit s2 = P1 ^ 5;//
void chushihua();
void guanjiao(uchar n);
void yanshi(uint z);
void xianshi();
void jianpan();
void write_shi(uchar shu);
void write_fen(uchar shu);
void xiaodou();
        chushihua();
        for (;;)
                        if (miao == 60)
                                miao = 0; fen++;
                        write_fen(fen);
                        if (fen == 60)
                                fen = 0; shi++;
                        write_shi(shi);
                        if (shi == 24)
                                shi = 0;
                jianpan();
                xianshi();
void jianpan()//鍵盤掃描
        if (s2 == 0)           //判斷s2是否被摁下,如果是則進入if循環語句
                xiaodou();
        if (s2 == 0)        //再次判斷s2是否被摁下
                fen++;
        if (s1 == 0)           //判斷s1是否被摁下,如果是則進入if循環語句
                xiaodou();
        if (s1 == 0)        //再次判斷s1是否被摁下
        shi++;
void xianshi()//顯示函數
        zuo_1 = 0;
        guanjiao(a_1);
        yanshi(2);
        zuo_1 = 1;
        guanjiao(11);
        yanshi(1);
        zuo_2 = 0;
        guanjiao(a_2);
        yanshi(2);
        zuo_2 = 1;
        guanjiao(11);
        yanshi(1);
        zuo_3 = 0;
        guanjiao(a_3);
        yanshi(2);
        guanjiao(bb);
        yanshi(2);
        zuo_3 = 1;
        guanjiao(11);
        yanshi(1);
        zuo_4 = 0;
        guanjiao(a_4);
        yanshi(2);
        zuo_4 = 1;
        guanjiao(11);
        yanshi(1);
void chushihua()//初始化函數
        TMOD = 0x01;        //設定時器0為工作方式1
        EA = 1;             //開總中斷
        ET0 = 1;            //開定時器0中斷
        TH0 = (65535 - 50000) / 256;       //對定時器0
        TL0 = (65535 - 50000) % 256;       //賦予初值
        TR0 = 1;                       //啟動定時器0
        aa = 0, bb = 10, cc = 0, miao = 0, fen = 0, shi = 0;
        zuo_1 = 1; zuo_2 = 1; zuo_3 = 1; zuo_4 = 1;
        num1 = 0; num2 = 0;
void yanshi(uint z)//延時函數
        uint x, y;
        for (x = z; x>0; x--)                //若for循環中數值為真,則維持循環,一旦為假,
                for (y = 110; y>0; y--);         //則退出循環語句,以此來達到延時的目的
void guanjiao(uchar n)//管腳顯示函數
        switch (n)
        case 0:a = 0; b = 0; c = 0; d = 0; e = 0; f = 0; break;
        case 1:b = 0; c = 0; break;
        case 2:a = 0; b = 0; g = 0; e = 0; d = 0; break;
        case 3:a = 0; b = 0; g = 0; c = 0; c = 0; d = 0; break;
        case 4:f = 0; g = 0; b = 0; c = 0; break;
        case 5:a = 0; f = 0; g = 0; c = 0; d = 0; break;
        case 6:a = 0; f = 0; e = 0; d = 0; c = 0; g = 0; break;
        case 7:a = 0; b = 0; c = 0; break;
        case 8:a = 0; b = 0; c = 0; d = 0; e = 0; f = 0; g = 0; break;
        case 9:a = 0; b = 0; c = 0; d = 0; f = 0; g = 0; break;
        case 10:h = 0; break;
        case 11:a = 1; b = 1; c = 1; d = 1; e = 1; f = 1; g = 1; g = 1; f = 1; g = 1, h = 1; break;
        case 12:h = 1; break;
void xiaodou()//消抖函數
        uchar x;
        for (x = 15; x > 0; x--) //若for循環中數值為真,則維持循環,一旦為假,則退出循環語句,以此來達到延時的目的
                xianshi();
void write_shi(uchar shu)//寫小時函數
        uchar shiwei, gewei;       //定義十位和個位數據類型
        shiwei = shu / 10;          //將一個數進行十位和
        gewei = shu % 10;//小時的拆分
        a_4 = shiwei;
        a_3 = gewei;
void write_fen(uchar shu)//寫分鐘函數
        gewei = shu % 10;           //分鐘的拆分
        a_2 = shiwei;
        a_1 = gewei;
void timer()interrupt 1//中斷服務函數
        TH0 = (65535 - 50000) / 256;        // 對定時器0的高8位
        TL0 = (65535 - 50000) % 256;       //和低8位賦予初值
        aa++;     //定時器0每溢出一次aa的值加1,時間為50000*12/12M=0.05S
        if (aa >= 10)
                bb = 10, cc = 0;
                if (aa == 20)
                        aa = 0; miao++; bb = 12, cc = 1;
