查看: 2038|回復: 0
中斷控制四位數碼管
ID:129075 發表于 2016-7-3 19:24 | 顯示全部樓層 |閱讀模式
#include<reg51.h>
unsignedchar code LED_MOD_ANODE[]={0xc0,0xf9,0xa4,0xB0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0xff};
unsignedchar code BIT_CONTROL[]={0x01,0x02,0x04,0x08};
unsignedchar LED_COM[]={0xff,0xff,0xff,0xff};
unsignedchar code key_buf[]={0xee,0xde,0xbe,0x7e,
                            0xed,0xdd,0xbd,0x7d,
                            0xeb,0xdb,0xbb,0x7b,
                            0xe7,0xd7,0xb7,0x77};
unsignedint n = 0;
voiddelay(unsigned char m){
                            for(;m>0;m--){
                                         unsigned char i;
                                         for(i=125;i>0;i--);
voiddisplay(){
               unsigned char j;
               for(j=0;j<4;j++){
                  P0=LED_MOD_ANODE[LED_COM[j]];
                   P2=BIT_CONTROL[j];
                   delay(2);
                   P2=0x00;
voidgetkey(void) interrupt 0 using 1{
       char key_scan[]={0xef,0xdf,0xbf,0x7f};
       unsigned char i=0,j=0;
       EA=0;
       for(i=0;i<4;i++){
              P1=key_scan;
              for(j=0;j<16;j++){
                            if(P1==key_buf[j]){
                            LED_COM[0]=LED_COM[1];
                            LED_COM[1]=LED_COM[2];
                            LED_COM[2]=LED_COM[3];
                            LED_COM[3]=j;
                            k++;
                            if(n>4) {LED_COM[0]=LED_COM[1]=LED_COM[2]=0X10;n=1;}
              break;
                                   }P1=0x0f;EA=1;
voidmain(){
       unsigned char i=0;
LED_COM[0]=LED_COM[1]=LED_COM[2]=LED_COM[3]=0X10;
display();
       P1=0x0f;
       IT0=1;
       EX0=1;
       EA=1;
       while(1){
      display();}
